Author Topic: Advice on upgrading my gaming rig  (Read 2325 times)
Offline chemicalenergetics
« on: Mon, 24 November 2014, 13:21:48 »
Hi this is my current gaming rig:
Asus H97 Progamer MBoard
intel i5 4690 3.50GHz
Crucial 256GB SSD
WesternDigital 1TB HDD
G.Skill Ripjaws X 16GB RAM ( 2X 8GB)
Asus Strix GTX970 4GB
Superflower 600W PSU
My question is, is this rig sufficient to run all games smoothly on Ultra settings, as well as whether is there a need for me to upgrade to a i7 4700 3.60GHz and whether it will make a difference to the performance of my current rig.
Thanks in advance!
Offline Badwrench
  • ummmm.....I forgot
Re: Advice on upgrading my gaming rig
« Reply #1 on: Mon, 24 November 2014, 13:57:33 »
For 1080p, that will be more than enough.  No reason to upgrade the cpu.
Even at 1440p, that will play very high settings on most games (probably with the AA turned down a touch though).
Offline The Mad Professor
  • Ex Scientia, Rabies
« Reply #2 on: Mon, 24 November 2014, 15:11:48 »
The amount of money you would spend to upgrade from an i5 to an i7 would not be justified by the miniscule amount of game performance increase.
A 4690 is the best bang for your buck for gaming, and the components you listed are all just fine for the purposes of gaming.
The only upgrade I would consider is adding a GTX970 for SLI operation, but that would be for the really high-end games.
Mad Science means never stopping to ask "What's the worst that could happen?" - Schlock Mercenary
Offline Grim Fandango
« Reply #3 on: Mon, 24 November 2014, 15:25:31 »
Honestly there is nothing in that build that I would upgrade at this point. I think you are aware that this build is easily sufficient for pretty much any game out there right now.
As you go for more expensive high-end components, you face diminishing returns. At some point, you start paying a lot for small increases in performance. That is why I personally never feel like going way over midrange-ish components and why I think that replacing or adding anything in your current build is not worth it.
Maybe it would be more interesting to invest in peripherals instead. No doubt you have a great keyboard (this is, afterall, Geekhack) but investing in great headphones, mic etc. can make the experience so much better. Beyond that there is the chair, desk etc. Personally I spend a lot on those kinds of things, and I feel it adds much more than an expensive almost meaningless increase in performance.
« Last Edit: Mon, 24 November 2014, 15:36:35 by Grim Fandango »
« Reply #4 on: Mon, 24 November 2014, 22:11:32 »
Crucial 256GB SSD
Thanks in advance!
WTF... ok.. Proper list..
Asus Z97 PRO
intel i5 4690K 4.7GHz OVERCLOCKED
Noctua NH D14 or D15 COOLER
Crucial 256GB SSD (get M500, or MX100)  best bang for buck
Hitachi 4TB HDD Cool spin..
G.Skill Ripjaws X 2400mhz 16GB RAM ( 2X 8GB)
