Author Topic: Can't wait till Season 7 hits  (Read 3812 times)
Offline bueller
  • MX baller
  • Church of the Ergo Clear
Re: Can't wait till Season 7 hits
« Reply #1 on: Mon, 24 November 2014, 22:47:26 »
And we give a **** about this because?
« Reply #3 on: Mon, 24 November 2014, 23:06:23 »
We do?!?
Offline Coreda
« Reply #4 on: Mon, 24 November 2014, 23:13:25 »
That is one black as theme.
« Reply #5 on: Mon, 24 November 2014, 23:33:34 »
Stealth mode :))
Offline Coreda
« Reply #6 on: Tue, 25 November 2014, 00:03:22 »
Stealth mode :))
I know understand what he meant by this:
haha.. I think I've already ripped out as many elements as possible with my current skinning.. which is applied to every interface on my pc.. not just gh..
« Reply #7 on: Tue, 25 November 2014, 00:19:33 »
« Reply #9 on: Tue, 25 November 2014, 03:27:35 »
Dark theme is much easier on the eye..
Here full screen this screen shot..   and compare it to the page you're looking at right now..
You can read both quite easily.. but the black allows your eyes to relax
82622-0
Offline azhdar
  • Praise the AZERTY god
« Reply #10 on: Tue, 25 November 2014, 03:32:18 »
it's barely readable for me , but I guess you got used to it .
I prefer to use : https://justgetflux.com/ to rest my eyes .
Azerty Propagandiste
« Reply #11 on: Tue, 25 November 2014, 03:35:23 »
Is your display properly calibrated ?  if your contrast point is too high or your gamma is too low, the grey on black won't be very visible..
Offline azhdar
« Reply #12 on: Tue, 25 November 2014, 03:39:32 »
lmao no idea
« Reply #13 on: Tue, 25 November 2014, 03:43:54 »
lmao no idea
yikes bro..  check this page..
Can you faintly see the first box..  [1]  on the top left
http://www.lagom.nl/lcd-test/black.php
Offline azhdar
« Reply #14 on: Tue, 25 November 2014, 03:52:32 »
lmao no idea
No , 1 to 7 are fully black to me .
And based on other test my display is ****ed up , had no idea .
« Reply #15 on: Tue, 25 November 2014, 03:59:47 »
lmao no idea
Hrrmm.. well der's the problem.. hehe..
Worry not..  Ok.. if you're  FINE with how the color intensity look on your computer, then you can skip gamma.
Just change the Brightness and Contrast..
So
on the black page INCREASE the brightness from your video settings (don't use the hardware setting on your screen, they work differently)..  until you can faintly  see box 1
http://www.lagom.nl/lcd-test/white.php
on the white page..  LOWER your CONTRAST setting form your video settings, until you can see the pattern in the last box on the bottom right  254..
if your video settings break into Channels like rgb.. just adjust them evenly..
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #16 on: Tue, 25 November 2014, 08:50:22 »
I have my GH theme set to the garish white and orange theme because I think it's awesome.
« Reply #17 on: Tue, 25 November 2014, 14:01:07 »
lagom.nl is great.
TP4 quit using utorrent already.
season 7 of what now?
also: one of my monitors is far reading Gh and IRC and is really old and not calibrated. The other one is newer, much better and is properly calibrated. I can see box #1.
Finally: low contrast themes area really great for some uses. For example my shone saves a ton of power displaying black on dark grey, and I don't blind myself when I read at night.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #18 on: Tue, 25 November 2014, 14:36:05 »
Things I have learned today: both my monitors suck; I can't see black box 1 on either of them. But the one I thought actually sucked, ended up doing better in the tests. Go figure.
« Reply #19 on: Tue, 25 November 2014, 16:25:02 »
Those test don't tell you if your monitor sucks...
It can SUCK, and still look pretty decent once calibrated properly.
THose test just tell you whether you're well calibrated.
  • Live long and prosper
« Reply #20 on: Tue, 25 November 2014, 16:55:08 »
I prefer this: http://www.staggeringbeauty.com/
MUCH easier on the eyes...
WARNING: If you are prone to seizures, please DO NOT VIEW THIS.
tp thread is tp thread
