Author Topic: Blendtec vs Vitamix  (Read 11564 times)
Blendtec vs Vitamix
« on: Wed, 03 December 2014, 19:39:39 »
Ok.. So now I've thoroughly evaluated both..  and every other 1500 watt blender on the market..
Ever since the Vitamix Black dust fiasco.. I've since went through them ALL..
Just got the blendtec..  Yup.. Rubber dust..
The Jar on the Blendtec is a toy compared to the Vitamix..   However..... the vitamix produces more black dust..
THe Blendtec base pulls more power from the wall..  but I can't really tell if it's m0re powerful..
I think the blendtec motor is probably a chinese motor.
I took apart the Vitamix, and indeed the motor is a swedish motor.. laser engraved.
Offline FreeCopy
Re: Blendtec vs Vitamix
« Reply #1 on: Wed, 03 December 2014, 19:55:35 »
I can't help myself in asking about the Vitamix, but will it blend?
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
« Reply #2 on: Wed, 03 December 2014, 20:04:52 »
Blendtec because I like their videos. IMO both are unnecessary and overpriced since I just buy the $14.99 blenders from Big Lots, use them once or twice, then just toss them. I've found I only use the blender a handful of times a year so this way is technically much more cost effective.Saves you from cleaning them too!
If you time it right sometimes you can get them BOGO. I have 4 blenders in my closet right now :))
« Reply #3 on: Wed, 03 December 2014, 20:19:15 »
I lust deeply for a Blendtek and look forward to the day when I can own one. It is my Model F of a blender. Everything else is just a toy.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
Offline munch
« Reply #4 on: Wed, 03 December 2014, 20:19:46 »
vitamix is more fun. thermomix are cool too.
« Reply #5 on: Wed, 03 December 2014, 20:25:03 »
Dah...  dude it's like only $250 at costco right now.. that's keyboard price..  it's not the fancy model.. but it uses the same motor.
Offline Flyersfan1
  • Hi!
« Reply #6 on: Wed, 03 December 2014, 20:25:14 »
Their videos always make me laugh...."OOOH...PHABLET SMOKE..DON't BREATHE THIS!"
Quote from: Photekq
Offline FreeCopy
« Reply #7 on: Wed, 03 December 2014, 20:26:31 »
I will have to buy two. There is absolutely no way I could own one of those without dropping random objects into it until it stopped working.
Keyboards
« Reply #8 on: Wed, 03 December 2014, 20:26:39 »
The vitamix blade hub is built much better...  however, the best blade hub i've seen so far is the "cleanblend- blade hub.. all japan"  however, the cleanblend blender itself is a piece of ****.. it started putting out blue smoke only the 8th time I used it..
« Reply #9 on: Thu, 04 December 2014, 08:28:58 »
Ok after some thorough testing..
The Blendtec is absolutely Epic Fail..
There is too much "exposed" rubber..
Which means.. if you blend anything that may be hard,  like ice..
The ice will act like grinding chips against the rubber encased central post..
So.. if at any point you run this machine a bit too dry, or with enough sturdy hard stuff,   the rubber post will disintegrate INTO the blend..
So.....  sigh.........................
« Reply #10 on: Thu, 04 December 2014, 08:39:36 »
What about the Ninja blenders?
« Reply #11 on: Thu, 04 December 2014, 09:02:24 »
dah... that thing is probably "the worst" out of the blenders I've tried..
The large center post.. when you do that, you lose tons of power because now you're distributing it up where it's not needed.
The transfer mechanism is also plastic.. that's bound to crack after some heat-stress..
There's also been numerous reports of the internals shaft cracking around the blade..
THe issue is.. I feel ALL of these blenders could be fixed.. but somewhere, cost became an issue even at $300-600,  and they just went,  oh well...
Offline heedpantsnow
  • Old enough to know better
« Reply #12 on: Thu, 04 December 2014, 20:22:20 »
I've heard unless you're doing nut butters just use a cheapo. More money for other things, like a sous vide cooker.
I'm back.
« Reply #13 on: Thu, 04 December 2014, 20:49:56 »
If you want to make "smoothies" that are truly smooth then you need a lot of speed and horsepower. Low-power blenders chop fruit up into "pulp" but the chunks are still large. If you can get all the pieces down to extremely small sizes, you get the true benefits of fiber without having to eat bushels of chaff.
Offline munch
« Reply #14 on: Fri, 05 December 2014, 00:58:56 »
so tp4, does this mean you'll try the Thermomix for us next? :p
« Reply #15 on: Fri, 05 December 2014, 06:04:47 »
I live under a rock.. I've never heard of it till now..
Just watched the video..  this thing isn't a blender.. it's more of a mixer.. ?
« Reply #16 on: Fri, 05 December 2014, 06:37:13 »
I love the Blendtec urban legend of the Starbucks barista accidentally dropping in the shot glass and the blendtec blending it up....smooth. Marketing genius!
I'm back.
Offline Coreda
« Reply #17 on: Fri, 05 December 2014, 06:43:24 »
I'm enjoying these blender impression posts.
« Reply #18 on: Fri, 05 December 2014, 07:00:11 »
I don't think it will be smooth.. but i'm quite sure it will blend to a degree.. would take a LONG while before the particle size gets small enough to be edible though..
« Reply #19 on: Fri, 05 December 2014, 07:03:27 »
I don't think it actually happened; I think it is an urban legend started by their marketing department
I'm back.
Offline munch
« Reply #20 on: Tue, 16 December 2014, 19:07:35 »
http://www.seriouseats.com/2014/12/high-end-blender-test-equipment-breville-vitamix-blendtec-review.html
kenji is pretty legit, vitamix seems like a winner even if not by a lot
« Reply #21 on: Mon, 23 March 2015, 15:17:30 »
We need an update TP?
« Reply #22 on: Mon, 23 March 2015, 17:54:58 »
What do you need to know ? I've got all the answers.
Offline paicrai
  • mindblank
« Reply #23 on: Mon, 23 March 2015, 17:56:41 »
why do you keep asking then
THE FEMINIST ILLUMINATI
« Reply #24 on: Mon, 23 March 2015, 17:57:34 »
I'm thinking of getting the refurbished blendtec from Walmart for $249.99, I've got ~$180 in gift cards to use.
« Reply #25 on: Mon, 23 March 2015, 18:22:53 »
You can get a NEW blendtec for $250 at costco, and it comes with that long warranty
I wouldn't bother getting the used one.. "though technically, they all come with new jars"
Usage scenarios..
If you're making lots of "liquid-y" stuff.. I would wait for the vitamix sales.. refurb 5yr warranty ~$300
If you're making mostly "sludg-ee" stuff.. They both work equally well.
The LID on the blendtec is a bit harder to work with.. so if you do LARGE VOLUMEs all the time,  Go with the vitamix..
« Reply #26 on: Mon, 23 March 2015, 19:48:46 »
We have a Blendtec and use it 3-5 times per week. We love it. Grinds up anything way smoother than anything we've ever used before (cheapos, Ninjas).
I'm back.
« Reply #27 on: Mon, 23 March 2015, 20:08:31 »
I think the Ninja is in principle a superior design..
But the center shaft should've really been made out of steel..
The plastic coupling is just.. sigh.....
« Reply #28 on: Mon, 23 March 2015, 20:10:03 »
Usage scenarios..
Closest Costco is over an hour away and the refurb has a 7 year warranty.
« Reply #29 on: Mon, 23 March 2015, 20:21:15 »
It's up to you.. I'm just saying if the cost difference is negligible, why risk the "cooties"
also.. the "lid" issue is really important.. if you're going to be spinning ALOT, get the vitamix
I was making large batches of soy-milk,  and it was more time consuming using the blendtec lid system.
