Author Topic: Rice part-II, Presoaking and Hydration  (Read 60312 times)
« on: Sat, 06 December 2014, 08:51:17 »
HYDRATION formula:
To Determine perfect amount of water to cook rice..
You must determine the water loss due to cooking time.  This must be done experimentally.
The formula serves as a guide as to the baseline of water needed assuming 0%-evaporative loss.
w = r(p-s)/(1-p)
w = r(p-0.12)/(1-p)
r : weight of rice (g)
s : % moisture level of uncooked rice (may assume 0.12 -the industry standard-)
p : % final hydration level, ideally between (0.58 and 0.64)<-- your choice
w : volume of additional water (g or ml)
Pre-soaking
An overnight experiment to find necessary PRE-soaking time for rice..
It is necessary to pre-soak, pre-hydrate rice, because this greatly improves the evenness of the rice texture after cooking.
The purpose is.. too long... is a waste of time.. too short and you don't get max pre-hydration.
Experimental results:
Interval soaked (minutes) vs % increase in water weight.
30 minutes,_______________________22%
45 minutes,_______________________27%
60 minutes,_______________________29%
75 minutes,_______________________30%
90 minutes,_______________________34%
120 minutes,______________________29%
180 minutes,______________________29%
2x overnight bowls,___________30% and 33%
SO it seems maximum rice soaking peaks @ about 1 hour..
No need to soak for Overnight ..  UPDATE,  you should soak minimum of 6 hours to MINIMIZE the water needed for full cooking,  useful for making Sushrr, or Max-Calorie rice bulking..
Re: Rice part-II, Presoaking
« Reply #1 on: Sat, 06 December 2014, 10:10:21 »
Question guys..
evaporation loss..
Is there a way to calculate this or does it have to be determined empirically ..
I realize every pot is different, but what if I have a good round pot, and I'll be steaming the rice on an Inner container..
such that the water level is slightly over the rice, and the surface is a smooth flat surface, and NOT beneath the rice..
can I use  gs = Θ A (xs - x) / 3600  ??
because, the issue here is,,  humidity ratio..  and area..
« Reply #2 on: Sat, 06 December 2014, 17:00:34 »
Only if you're using older brittle rice or eating glutenous rice, in which case: why haven't you made the change to basmati rice yet?
« Last Edit: Sat, 06 December 2014, 17:02:10 by noisyturtle »
« Reply #3 on: Sat, 06 December 2014, 17:46:54 »
Because sushi rice is the best kind?
« Reply #4 on: Sat, 06 December 2014, 17:54:35 »
But it's so bad for you. Full of glutenous sugars, empty calories, and carbs :(
4 bowls of white rice = 50 teaspoons of sugar
Plus white rice prevents the body's absorption of certain vitamins. Zinc/iron/B vitamins
« Reply #5 on: Sat, 06 December 2014, 17:56:23 »
You're eating the crappy bleached kind. The authentic dehusked kind is a lot better.
To be fair though, if I can't get the nice kind I'll eat basmati.
« Reply #6 on: Sat, 06 December 2014, 20:02:08 »
Rice _IS NOT_  and _HAS NOT_  ever been -Bad for You-
If you need energy.. rice has that in spades..
But if your life is just  ass + chair..  then you may become overcharged..
Rice overall, is still one of the more natural energy solutions.. vs highly processed flours and flour products..
Offline Firebolt1914
  • POM Overlord
« Reply #7 on: Tue, 09 December 2014, 17:38:45 »
Mixed rice is the best rice :). Although a simple bowl of white rice is never ever bad. It's fun being korean sometimes cause of all the rice.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #9 on: Tue, 09 December 2014, 17:45:41 »
Picture foodie pron this plz
Offline Novus
  • Mondai nothing~
« Reply #10 on: Tue, 09 December 2014, 17:46:03 »
what's mixed rice.
Mixed rice is purple rice
  • POM Overlord
« Reply #11 on: Tue, 09 December 2014, 17:47:07 »
what's mixed rice.
Yeah, but usually mixed rice has more peas and other bits than just purple rice.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #12 on: Wed, 10 December 2014, 08:08:36 »
Jesus guys, i feel like i'm missing out and been doing this wrong my entire life cause i literally have just been washing rice and throwing it in the rice cooker EVERY time i make rice. i've never pre-soaked or anything, does it really make that big of a difference?
GON NerD TKL DTA Edition
« Reply #13 on: Wed, 10 December 2014, 10:09:40 »
Presoaking gets a more even cook..
be sure to also apply my hydration function to achieve perfect liquid levels
You will also need to account for evaporation.. this has to be done empirically.
This won't work for a rice cooker.. only pot
For anyone that doesn't want to find -s-,  just assume it's 0.12
Market forces would push producers to keep moisture level there anyway.. so it's a fine assumption.
I tested 3 different types of rice in the house.. they all fall around 12%..
w = r(p-s)/(1-p)
w = r(p-0.12)/(1-p)
s : % moisture level of uncooked rice (may assume 0.12)
Offline Blackehart
Re: Rice part-II, Presoaking and Hydration
« Reply #14 on: Mon, 29 August 2016, 11:22:09 »
Necrobump...
sophistimacated formulas for cooking rice?
Granted I live below sea level....
put rice in non-stick pot.
add water.
check water level by inserting clean middle finger.
Let rice level out and touch the rice.
Water should be at or just slightly above first knuckle.
Throw pot on stove on high till it boils feverishly (big boils).
Throw cover on.
Lower heat to low.
Let simmer for 10 mins (12 if it more than half the pot).
Turn heat off and let sit covered for 5 mins (or just leave it there till you're done cooking your stir-fry or whatever else you got going).
Yes, I've been tempted multiple times to buy a nice rice cooker...but this method hasn't failed me.
EDIT: this is for white rices; bhasmati, plain long, jasmin, etc....brown rice takes too long :p
^_^
« Reply #15 on: Mon, 29 August 2016, 13:37:55 »
Necrobump...
add water.
Throw cover on.
Lower heat to low.
^_^
This works fine for smaller quantities but it's hard to adjust because the evaporation and cooking rate is non linear..
In the end, it's gonna be a bit of trial and error anyway,   but overall , the purpose of putting numbers on it, is to create a baseline.
Offline iLLucionist
  • Topre is Love.
« Reply #16 on: Tue, 25 October 2016, 05:12:24 »
This. Is. F**KING GENIUS.
« Reply #17 on: Tue, 25 October 2016, 20:40:15 »
Rice is a must have in the Sifo's diet.
Offline YoshiCaps
  • yes, oh god no.
« Reply #18 on: Sat, 03 December 2016, 21:55:05 »
if you soaked it overnight it would get mushy. I have a pressure cooker so I can cook it in 20 minuetes no soak
wich is good for beans and rice cause beans have to be soaked as well
« Last Edit: Sat, 03 December 2016, 22:08:24 by yoshilikesmxbrowns »
hi.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #19 on: Sat, 03 December 2016, 23:26:52 »
9/10, TP...excellent work  :)) :)) :))
Offline iLLucionist
  • Topre is Love.
« Reply #20 on: Sat, 29 April 2017, 10:35:01 »
TP honest question. Why does every recipe state that I should wash my rice till water is clear before I steam my rice manually? Why does the rice need to be cleaned / clear water? Because typicall quick cook rice is just poor boiling water, cook for 8 minutes, separate water, let rest for another 10 mins.
« Reply #21 on: Sat, 29 April 2017, 11:24:30 »
It's a throwback tradition.
by washing the rice, you remove some surface starch and that leads to a small difference in final rice texture.  it will be less sticky offering more clarity and grain separation.
rice also did not used to be as clean as is processed in our modern industrial facilities. there was dust and debris and often weevils (rice/grain bugs).
For these reasons it was prudent to wash rice.
However,  modern day rice, because it's already presorted, the grain composition is very good and cracking is low, so this leads to very low leeching of starches into the cooking water vs old rice.
Modern rice will produce a good final cooked texture even without diligent washing..
It's also much a cleaner product today.
« Reply #22 on: Sat, 08 August 2026, 20:35:17 »
Another issue with sushrrr..  is the Hydration lvl of the rice.
Humans are naturally hardwired to detect and Pursue, HIGH caloric density.
Restaurants use alot more water to cook their rice, because they know they have to have it LAST-all-day in a warmer.
This leads to rice that is Overly plump.  You can feel this when you eat their sushr, the rice is soft, loose and not wholesome.
WHEREAS, at home, if you use the MINIMUM amount of water using Tp4's patented Hydration Formula (in sig),   You produce a significantly more Jelly bean like rice.
Remember,  Sushr has the additional problem that they have to ADD roughly 150ml rice(raw) of 5%vinegar TO 600g (raw rice) for seasoning.
Even if you account for evaporation,  150ml is about a centimeter of water.
So, getting the minimum possible FROM the pot is critical.
Restaurant versions use way more water, 20-30% more.
« Reply #23 on: Sun, 16 August 2026, 09:27:21 »
Just sayn'  in case there's ne doubt where obesity comes from.
USA stats, The rice people eat 100-150lbs of rice per year,  LOWEST obesity rate.
317908-0
« Reply #24 on: Fri, 21 August 2026, 07:30:55 »
The average metabolism is 2000 calories a day.
90% of that should come from carbohydrates,
TO, prevent DIABETUS//atherosclerosis//stroke//cancer, (diseases of affluence).
THEREFORE, 1800calories, @ 3.7cal per gram, = 486.49g of rice per day.
177,578.57g per year, 391.46lbs of rice.   :D
//_ Tp4's guide to an impeccable life.
//_ BIG RICE!!
« Reply #25 on: Wed, 26 August 2026, 20:14:47 »
When you add something like onions or scallions to cook w/ the rice in the rice maker, should you add slightly less water to account for the water in the veggies?
« Reply #26 on: Wed, 26 August 2026, 21:36:49 »
You should do that. Just fry those in oil, and put on top is easier.
The difficulty in including stuff cooking above the rice, is that some material absorb water and gel up, this causes unpredictable rates to occur in the native rice.
If you put something inside the rice, that's even more unpredictable.  You end up with over/under hydrated rice going around the foreign object.
« Reply #27 on: Sat, 05 September 2026, 07:58:21 »
Reheating rice, shouldn't be a mystery.
Just take the old rice, all 1 block, don't need to break it, pour drinkable water straight down the middle, about a full cup, get the whole outside wet, but starting from the middle.
Now, put a plate over the bowl, pour out as much water as will drip out the side.
Leave covered, and Microwave for 3 minutes fullpower, if rice is 2cups or less, go 4 minutes if 3cups or more.
« Reply #28 on: Mon, 07 September 2026, 09:12:03 »
The thing with advanced rice cookers.
The whole thing is a cauldron of forever chemicals, and all that "plastic" in the hot heat path, microplasix + evaporated plasticizers .
Hrrrmm...
The only other option is the 1 button cookers, the stainless version which just has a glass cap and nothing else, not even a silicone seal.
With stainless pressure cookers even, those still have the silicone gasket.
The benefit is uniform rice texture, buhhhh honestly, the difference isn't that hughhg, if you presoak the rice for at least 1-6 hours.
Minor drawback however is that it DOES stick. So you have to soak the pot for a minute before getting the extra rice off. Hrrrm.
318094-0
« Reply #29 on: Tue, 08 September 2026, 22:39:30 »
