Author Topic: Food Label Experts... HALP  (Read 5074 times)
« on: Wed, 10 December 2014, 18:55:18 »
If I add up all the   carbs (incl. fiber), proteins, fats,
and subtract it from the total weight..   The rest is water weight correct??
Offline Hellcatz
Re: Food Label Experts... HALP
« Reply #1 on: Wed, 10 December 2014, 19:00:42 »
LOL wished it work like that but it doesn't. As food gets processed and cooked it often looses weight. Hard to explain but as it cooks it releases partials and reactions happen which uses up some of the ingredients. Not sure if that makes sense but might help.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #2 on: Wed, 10 December 2014, 19:10:04 »
« Last Edit: Wed, 10 December 2014, 19:11:51 by the1onewolf »
« Reply #3 on: Wed, 10 December 2014, 19:18:39 »
You woman
I'm trying to perfect my coconut rice..  last time I checked... Pr0 level cooking is dominated by fat-manly men.
« Reply #4 on: Wed, 10 December 2014, 19:20:45 »
No, I mean if I buy something that's in a CAN..
Offline Hellcatz
« Reply #5 on: Wed, 10 December 2014, 19:21:39 »
google coconut rice recipes?
Offline Hellcatz
« Reply #6 on: Wed, 10 December 2014, 19:22:45 »
it still applies
Offline Novus
  • Mondai nothing~
« Reply #7 on: Wed, 10 December 2014, 19:23:09 »
You woman
Well clearly you ain't at the top so that means you a woman.
Also coconut rice... Really?
« Reply #8 on: Wed, 10 December 2014, 19:39:24 »
You woman
yea..
now that I got my hydration formula down, and my evaporation rate calibrated on the pot I'm using..
All I need to know is how much water is in this can of coconut milk.
Offline Hellcatz
« Reply #9 on: Wed, 10 December 2014, 19:41:49 »
lol ARE YOU OCD?
« Reply #10 on: Wed, 10 December 2014, 19:46:05 »
WTF... why do you care? How does this improve your rice making in any way?
Why do we need a new thread about ****ing rice everyday?
« Reply #11 on: Wed, 10 December 2014, 19:48:47 »
Ok.. this goes back to my hydration function..
I want to PERFECTLY hydrate my rice upon cooking completion @ 58% moisture level..
I have accomplished this using Just water..  this is easy..
However, Now with Coconut milk... it's got oil + proteins + carbohydrates...
That has to be accounted for in the hydration formula..
Offline Hellcatz
« Reply #12 on: Wed, 10 December 2014, 19:48:53 »
in some way it does but not by much
« Reply #13 on: Wed, 10 December 2014, 19:59:56 »
wait wait wait.. totally wiffed.. not a chemist
i totally forgot to account for density..
« Reply #14 on: Wed, 10 December 2014, 20:09:02 »
Ok... soooo
Fats average: 0.9g / cm^3
Protein: 1.35g / cm^3
Glucose: 1.54g / cm^3
My coconut milk has 70g fat, 5g protein, 15g carb..  PER 403mL total
that means  ....
77.77 mL of fat
3.703 mL of protein
9.74 mL of carbs
So.....  that is 91.22mL of Stuff, the rest is Water (311.78 mL)..
HURRAY....
Next year, Tp4 cooks meth....
Offline Hellcatz
« Reply #15 on: Wed, 10 December 2014, 20:37:03 »
funny thing is that you asked a bunch of nerds to help you cook when most of us have a diet of cup noodles and fast food XD (I SAID MOST) not including me oc
« Reply #16 on: Wed, 10 December 2014, 20:47:13 »
Meth is next..
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #17 on: Wed, 10 December 2014, 21:16:14 »
Ok... soooo
that means  ....
77.77 mL of fat
3.703 mL of protein
9.74 mL of carbs
HURRAY....
What about all the water in your carbs, fat and protein?
« Reply #18 on: Wed, 10 December 2014, 21:42:49 »
Ok... soooo
that means  ....
77.77 mL of fat
3.703 mL of protein
9.74 mL of carbs
HURRAY....
ah... well.. I'm prettttty sure the food label is using dry weight of those components..  it wouldn't make sense to use a wet-weight, because then it'd be inflating the numbers..
I'm calculating how much of protein.fat.carb is based on a label form a pre-bought coconut milk can..
I'm  not making my own coconut milk..   if I were to do that.. I guess... I would measure wet and dry weight to determine the volume of water like I did with the rice.
Offline Hellcatz
« Reply #19 on: Thu, 11 December 2014, 18:10:19 »
Your over thinking it Just assume the best case scenario for your equation something reasonable where you will still be able to calculate the amount of water. (CLOSE ENOUGH to the actual value)
It gets really complicated once you try to get 100% accuracy which in the end doesn't really affect the end result be cause your prediction was already close enough
« Reply #20 on: Thu, 11 December 2014, 18:15:46 »
would you happen to know constituents that wouldn't be on the label ?
like. .they wouldn't add concrete powder right ?  if they did, would they have to label it..
Offline Hellcatz
« Reply #21 on: Thu, 11 December 2014, 18:43:31 »
depends where you are but where I live (canada) ingredients under a certain amount do not have to be included in the food label.
Offline Hellcatz
« Reply #22 on: Thu, 11 December 2014, 18:44:45 »
Is it necessary to declare ingredients in “trace”, i.e., incidental amounts? Can sulfites be considered incidental additives?
Answer: FDA does not define “trace amounts”; however, there are some exemptions for declaring ingredients present in “incidental” amounts in a finished food. If an ingredient is present at an incidental level and has no functional or technical effect in the finished product, then it need not be declared on the label. An incidental additive is usually present because it is an ingredient of another ingredient. Note that major food allergens (as discussed under Food Allergen Labeling), regardless of whether they are present in the food in trace amounts, must be declared.
might be a better answer! XP
