Author Topic: How long do mouse buttons last?  (Read 4711 times)
Offline MGH
« on: Tue, 16 December 2014, 18:55:56 »
Specifically G502, but I'd be interested in other mice too
Offline Grendel
Re: How long do mouse buttons last?
« Reply #1 on: Tue, 16 December 2014, 22:07:38 »
Omron D2F switches -- 1million operations min. @ 60/min. Interestingly the spec sheet shows a curve that starts at 4m (under Engineering Data.) ASUS specs 20m clicks for the Gladius (same switches..), fishy.
Edit: the G502 D2FC-F-7N switches are rated to 5m clicks according to this (under 7.1.)
« Last Edit: Tue, 16 December 2014, 22:32:45 by Grendel »
- I'm game !
Offline CeeSA
« Reply #2 on: Wed, 17 December 2014, 15:14:19 »
I dislike any Omron switch atm. If you ask me mouse switches overall (not only Omrons) are very low quality products.
I also think that current generations are really worse. Back in the days, the Omrons in the IME 3.0 were very good. Even the switches in the MX518 generation were better than todays omrons.
Buy a lot of 10 omrons and try to find 2pcs that feel the same way.... Good luck.
« Reply #3 on: Wed, 17 December 2014, 17:12:27 »
the made in japan ones i got seems pretty consistent.. perhaps it's only the china version that's not so great?
Offline daerid
    • Rossipedia
« Reply #4 on: Sat, 20 December 2014, 14:28:03 »
I love the way my G502 switches feel. Hopefully they last a decently long time.
Offline MGH
« Reply #5 on: Sat, 20 December 2014, 15:23:07 »
If they break, I'll probably either figure out a way to replace only the switches or just shell out and get another one
