Author Topic: Poker II and tiny screws  (Read 2397 times)
Offline mougrim
« on: Sat, 20 December 2014, 15:54:08 »
OK, so I decided to led-mod my Poker II, butn there is a slight problem - leftmost screw isn't unscrewing, and I think I ruined it by my screwdriver (now screwdriver just turning inside slot, which is almost round). Sigh. Do I have any chance to unscrew it by myself?
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline Geroximo
Re: Poker II and tiny screws
« Reply #1 on: Sat, 20 December 2014, 16:12:15 »
Lay a rubber band over the screw and try again. Maybe that helps.
« Reply #2 on: Sat, 20 December 2014, 23:26:56 »
Try a flat head..
if the top is exposed, you might be able to glue something to it and turn it
if the top is still in the hole, either drill it.. or VERY carefully try the glue..
Offline mougrim
« Reply #3 on: Sun, 21 December 2014, 00:59:04 »
Try a flat head..
Well... I'll think about flathead... If not, maybe I'll try glue - or solder. If I manage to land a drop of solder on the head and insert a screwdriver before it's solid.. maybe, just maybe, it might work.
« Reply #4 on: Sun, 21 December 2014, 08:08:25 »
Try a flat head..
solder, you might melt the surrounding plastic.. so becareful with that
Offline strict
  • TKL Zealot
« Reply #5 on: Sun, 21 December 2014, 09:06:53 »
You could also try something like easy out screw extractors which are basically just reverse cut drill bits. They dig into the stripped screw and pull it out the more they dig in.
Offline mougrim
« Reply #6 on: Sun, 21 December 2014, 09:32:35 »
Thanks for the tips - in the end flathead + some force done the trick :)
Offline heedpantsnow
  • Old enough to know better
« Reply #7 on: Sun, 21 December 2014, 12:03:26 »
Sometimes dealing with a PCB + plate is like that old game "Operation" lol.
I'm back.
Offline mougrim
« Reply #8 on: Sun, 21 December 2014, 15:20:57 »
Exactly :) In my opinion PCB + plate clearly superior to plate - mounted, but dat screws...
Offline Hogesyx
« Reply #9 on: Tue, 23 December 2014, 02:51:24 »
If you no longer care about reusing the screw, extractor works great, or just use a generic drill bit to break the screw head then use a plier to remove the rest of the screw from the thread hole.
For a non destructive method, I had use epoxy before. Basically I epoxy my screwdriver to the screw and unscrew it the next day, when I need to fix the item back, I screw it back with the screwdriver and break the epoxy.
Novatouch TKL | Ducky YOTR (Brown) | Ducky Shine (Brown)
Poker II (Red) | GH60 revchn (Clear)
