Author Topic: USB Device Malfunction and Google Chrome Problem  (Read 3735 times)
Offline berserkfan
« on: Sat, 10 January 2015, 09:56:27 »
Once again I have gotten my incompetent self into a bit of a spot.
I have been receiving lots of alerts like this. USB device malfunction.
But I can’t figure out what device has malfunctioned. And the ‘click here for assistance in solving this problem’ thing is totally unhelpful.
Any ideas?
Another problem that I have been getting, is Google Chrome telling me constantly that some page or other is ‘not responding’ and I must kill it. This is starting to get very irritating because it interferes with my work. The page in question can be any page – yahoo mail, google mail, nytimes, bbc news, geekhack.org, taobao proxy, etc. I’m at my wits end to solve this problem because of the disruptions it causes.
Can anyone suggest a fix?
Re: USB Device Malfunction and Google Chrome Problem
« Reply #1 on: Sat, 10 January 2015, 10:02:42 »
For the chrome issue is your adobe flash plugin up to date?
« Reply #2 on: Sat, 10 January 2015, 10:36:09 »
Hrrrm... could be virus/spyware/hijack..
Update bios..  reformat.. update drivers..
« Reply #3 on: Sat, 10 January 2015, 17:36:46 »
I have had numerous USB hubs fail, both powered and unpowered ones, even "good" brands.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
Offline Tactile
« Reply #4 on: Mon, 12 January 2015, 10:34:39 »
What operating system? If Windows, do you also hear the chime indicating a device disconnected? Do you have any devices plugged into a USB 3 port? If so, you might want to disable "link power management". This feature is causing trouble for lots of folks (including me, until I learned to disable USB 3 power management).
Here's just one example...
http://wdc.custhelp.com/app/answers/detail/a_id/9588/~/a-usb-3.0-drive-randomly-disconnects-and-reconnects-from-a-pc
REΛLFORCE
Offline berserkfan
« Reply #5 on: Mon, 12 January 2015, 12:29:53 »
OK, none of the devices are USB3.
No disconnection either. As I pointed out, everything is working. So I don't understand why I am getting the notice that 'USB device malfunctioned'.
In the past I got that notice with certain unreliable adapters/ whenever the USB connection was loose. But that's not the case for this current problem.
