Author Topic: Heat Experts  (Read 3695 times)
Heat Experts
« on: Sun, 11 January 2015, 17:49:20 »
Do they make infrared heaters in the 200 watt range..
I'm only looking for a foot warmer, as the puter's above the garage.. colder floor than rest of the house..
But all the infrared heaters seem to be in the 400+ watts range..  a bit much for what I need.
Re: Heat Experts
« Reply #1 on: Sun, 11 January 2015, 18:17:48 »
Cut off feet - problem solved
Offline Tym
Re: Heat Experts
« Reply #3 on: Sun, 11 January 2015, 18:24:09 »
Get a dog, and call it something cool, mines called Shadow.
Re: Heat Experts
« Reply #4 on: Sun, 11 January 2015, 18:31:09 »
We named one dog gravy and the other peanut.
Offline Tym
Re: Heat Experts
« Reply #5 on: Sun, 11 January 2015, 18:35:51 »
Was that a Spam decision or a Spam-Jr decision?
Re: Heat Experts
« Reply #6 on: Sun, 11 January 2015, 18:36:50 »
We name all our pets with food or food related names.
Re: Heat Experts
« Reply #7 on: Sun, 11 January 2015, 18:40:04 »
this is shortsighted... what happens when apocalypse gets goin' n ur hungry...
Offline engicoder
Re: Heat Experts
« Reply #8 on: Sun, 11 January 2015, 18:40:44 »
Get an adjustable heating pad and some big fuzzy socks
Re: Heat Experts
« Reply #9 on: Sun, 11 January 2015, 18:41:49 »
Your shadow dog emits infrared ?  200watts of it? u realize that's 172 Calories / hour..
I highly doubt shadow dog can push that kinda power level...
Re: Heat Experts
« Reply #10 on: Sun, 11 January 2015, 18:42:50 »
arn't these things dangerous?  you got all that fuzz around a heating element..
Offline Tym
Re: Heat Experts
« Reply #11 on: Sun, 11 January 2015, 18:44:42 »
Dogs **** on feet, dogs are warm.... Therefore feet are warm.
Offline Tym
Re: Heat Experts
« Reply #12 on: Sun, 11 January 2015, 18:45:23 »
Sit! I meant sit! I swear I meant sit!
Re: Heat Experts
« Reply #13 on: Sun, 11 January 2015, 18:56:11 »
If not... then that must be the "extreme fetishism" I've witnessed in in ya'll brits....
Re: Heat Experts
« Reply #14 on: Sun, 11 January 2015, 19:23:12 »
Good thing the cats name is charcoal.
Offline heedpantsnow
  • Old enough to know better
Re: Heat Experts
« Reply #15 on: Sun, 11 January 2015, 19:26:26 »
In China they have these things:  it's a wooden box with a incandescent light bulb inside and a platform just above that your feet rest on. Then you wrap your feet and the box in a blanket. Very very warm and pretty power efficient. Used it for a long time in Tibet with no heat.
Dunno if they're available where you are but worth a shot maybe?
I'm back.
Re: Heat Experts
« Reply #16 on: Sun, 11 January 2015, 19:51:03 »
box with a light?   No they don't have this in my country.. but.. I could sure as hell build one..
Hrrrmmmmmmmmmmmm......................... Hrmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
Offline trizkut
Re: Heat Experts
« Reply #17 on: Sun, 11 January 2015, 19:56:06 »
You mean like a kotatsu?
Re: Heat Experts
« Reply #18 on: Sun, 11 January 2015, 20:27:07 »
The kotatsu seems to use an infrared lamp.. Screw that.. lightbulbs are 25cents.
Re: Heat Experts
« Reply #19 on: Sun, 11 January 2015, 20:32:32 »
The Chinese excel at finding something everyday and cheap and finding new uses for them.
They need these bc many still live in the countryside with no central heat and no insulation.
TP I replied to your PM about the box.
The beauty of it was bc of the blanket you didn't need much wattage.
I'm back.
Offline tbc
Re: Heat Experts
« Reply #20 on: Sun, 11 January 2015, 20:45:30 »
Which of your pet's called 'spam'?
Offline GL1TCH3D
Re: Heat Experts
« Reply #21 on: Mon, 12 January 2015, 07:32:23 »
Usually I wear ski socks and slippers at home (computer is in basement where it's fairly chilly in the winter with no heating).
