Author Topic: GTAV will require 65GB of install space for PC  (Read 17532 times)
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: GTAV will require 65GB of install space for PC
« Reply #50 on: Tue, 20 January 2015, 10:43:11 »
True, you can get 480gb ssd from mushkin or pny for like $160. While not top performance models on iops, they are still fine especially as a secondary drive. I think it's kind of funny that you can now buy 1TB for about the same price as I paid for my first SSD which was only 80GB many years ago.
Though I still will hold onto my past comments... unless you really need to buy or are getting a really good sale price on something I would wait. As for NVMe... it's going to be like moving from IDE to sata. It will be a big deal. Sata wasn't designed with solid state in mind, but NVMe is and will address all those shortcomings.
« Reply #51 on: Tue, 20 January 2015, 15:18:10 »
Yeah, I paid $200 for a 250GB only last year, and am not super anxious to throw more money at the same thing in such recent succession.
« Reply #52 on: Tue, 20 January 2015, 16:04:15 »
Please explain how NVMe will affect us Peasants working with low queues..
Samsung web says, improved sequential performance (useless), improved latency from 10us to 3us whooptifreakindoo.. (useless)
This is solely a data centers game..  completely irrelevant to average consumers.
« Reply #53 on: Tue, 20 January 2015, 16:06:56 »
Look at this picture..  the p3700 gots the nvme...
Doesn't do jack ****..
Look at the 4k, bar in the middle..  see how it remains virtually UNCHANGED between nvme and single sata.
Offline tbc
« Reply #54 on: Wed, 21 January 2015, 00:09:49 »
is nvme even enabled on consumer chipsets yet?
i imagine that when nvme becomes standard, people will just buy a new SSD with nvme support and relegate their current SSD to secondary/storage purposes.
« Reply #55 on: Wed, 21 January 2015, 04:37:36 »
You need at least a z97 platform for Nvme support..
But I'm telling ya'll,  it doesn't do anything AT ALL for consumers..
It's a good thing if it's there,  but it's hardly a feature you'd upgrade-to-get.. because it offers zero advantage at low queue depths..
« Reply #56 on: Wed, 21 January 2015, 11:39:40 »
When they won't cost any different... why argue against it though? Also, crystalmark is a really crappy benchmark which none of the serious ssd reviewers even use anymore. Pretty much any other benchmark shows results starting at 90MB/s with nvme drives on 4K random starting at QD2 depending on the drive for the consumer tier stuff with some able to do as much as 200MB/s. Enterprise stuff needs a larger QD but can hit up into the 700MB/s plus. On sequential we're looking at 1GB/s speeds.
That intel drive result you selected is also one of the worst performers available. But I can only assume you did that intentionally for your argument.
Do most people need that kind of performance right now? Surely not... but if it's not going to cost much more than current sata ahci drives there is no reason not to step up. It's going to be the standard sooner than later.
Yeah intel 9 series has nvme natively with m.2 support, though not all boards implemented it fully. Otherwise you need a pci-e ssd (or pci-e m.2 adapter card) and UEFI motherboard. Many of them don't work properly as boot drive on old bios systems, they don't even show up in the boot selection.
« Reply #57 on: Wed, 21 January 2015, 21:40:46 »
It most definitely WILL COST MORE..
If it didn't cost more.. you'd not see any argument from me..
How does upgrading a platform not cost money
How does buying new drives not cost money
Does that New drive translate to improved performance FOR regular people vs their existing SSD drive or cheaper drives without NVME?
Drive speeds at low queue depths is not bottlenecked by ahci..
Drive speeds at high queue depths is..
Since we don't actually use high queue depth in the desktop environments..
ANYONE with current platforms should NOT upgrade FOR THAT FEATURE alone..
I don't disagree that it's an uptick of a feature.. my point is that, that-uptick, is not something which Applies to ANYONE outside of Enterprise.
Offline hking0036
« Reply #58 on: Sat, 24 January 2015, 21:19:26 »
How? It doesn't even look really really great. All these games keep getting bloated but I'm not seeing much improvement at all (watch dogs, CoD Ghosts, etc)
Realforce RF87UB 45g Uniform | Leopold FC660C w/ TMK | IBM Model M - 3/24/1997 | IBM Model F 122 - 11/25/1985 ANSI'd w/ TMK | IBM Model F XT in a box
« Reply #59 on: Sat, 24 January 2015, 21:22:59 »
Conspiracy to sell Larger SSDs.
Offline hking0036
« Reply #60 on: Sat, 24 January 2015, 21:34:04 »
I'm too stupid to figure out how youtube embeds work yet
« Reply #61 on: Sun, 25 January 2015, 00:32:04 »
YouTube linking broken. Someone 's not fixing it
« Reply #62 on: Sun, 25 January 2015, 09:49:37 »
Larger textures are more noticeably better on higher resolution like 1440p or above. Additionally they look better from the start so you don't need to apply as much or any AA or AF in some cases which improves overall performance without the need for the extra post processing. Though, what I don't understand is why procedural generation isn't used more. You get a lot of the same benefits without the huge increase in needed disk space.
As for youtube embed... it's not 'broken' per se, just gimped right now as it won't show up on some browsers without choosing to allow mixed content.
« Reply #63 on: Sun, 25 January 2015, 14:22:58 »
Jeez, not everybody rich and got super CPU power for them procedural trees like u Ivan
« Reply #64 on: Mon, 26 January 2015, 11:02:26 »
It doesn't require a lot of processing power generally if it's implemented properly. It's been around for some time now as a technique so is fairly mature though for some reason is not utilized much. For example
kkreiger, while old from 2004 was 100% procedurally generated and the whole game was only 96k. It looks just as good as most other games from the same period. I'm sure they could do similar level of current games with updated techniques and would be no problem for modern quad cores.
Offline tbc
Offline Ramuq
« Reply #66 on: Thu, 29 January 2015, 03:45:37 »
Guess it's time to invest and a GTA dedicated SSD
« Reply #67 on: Thu, 29 January 2015, 16:29:15 »
That's how all the gangsta playas r0LL
Offline DrHubblePhD
  • I am star stuff
« Reply #68 on: Thu, 29 January 2015, 16:31:28 »
I plan on loading the entire game using a Nintendo e reader
« Reply #69 on: Thu, 29 January 2015, 16:35:31 »
well if you want to do it before you die..
You'd need multiple readers,  and an auto swipe mechanism.. could be kinda cool..
Offline Ramuq
« Reply #70 on: Thu, 29 January 2015, 16:37:45 »
I actually had one of these, I used it all of about twice I think haha. We need some type of eReader to usb connector now...
Offline DrHubblePhD
  • I am star stuff
« Reply #71 on: Thu, 29 January 2015, 16:39:43 »
Can someone confirm the amount of data held on a single card?
Offline Ramuq
« Reply #72 on: Thu, 29 January 2015, 17:45:36 »
No idea how big they can get, but one can hold Mario bros from  the Nes which is about 24 kb. Assuming you you have one 25 kb strip per card it would take 2,600,000 e reader cards to hold the game.
« Last Edit: Thu, 29 January 2015, 17:47:18 by Ramuq »
« Reply #73 on: Thu, 29 January 2015, 18:14:39 »
1mb flash ROM, so it'll take a while :))
Offline vivalarevolución
« Reply #74 on: Sun, 01 February 2015, 16:26:39 »
This thread just inspired me to delete Grand Theft Auto off my computer.
