Author Topic: Samsung Migration tool ffffffffff  (Read 2491 times)
« on: Wed, 21 January 2015, 20:19:47 »
So I used it righ...
It works righ....
Then all my backup images fail righ....
Cuz it changed log file size of my system reserve to 54000 instead of 2048.. the entire reserve is only 100mb.. OBVIOUSLY shadow copy will fail in this instance..
WTF.. who does that...  coreans that's who...
If anyone else has this problem just change the logfile size back, and it should all come together, OR if for whatever reason samsung filled the partition with something else that you can't see or access,  use something like partition-magic and make that reserve partition larger, like 200mb
