Author Topic: Key not registering, problem persists despite replacing switch.  (Read 1246 times)
Offline Vido
« on: Wed, 11 February 2015, 17:19:12 »
As stated in the title, the p key on my keycool 84 is not registering. I swapped this particular switch out, however this did not fix the problem and it turned out that the switch was working after all. Any suggestions are appreciated.
Re: Key not registering, problem persists despite replacing switch.
« Reply #1 on: Wed, 11 February 2015, 17:36:05 »
You need to bridge the key.... likely a crack in the pcb  or a bad solder joint along the run..
plug in the keyboard,  use 2 wires.. and just follow the traces for that key and find the spot where it works..
Offline Vido
« Reply #2 on: Wed, 11 February 2015, 17:45:20 »
Thanks for the quick reply. I'll try this out tomorrow.
