Author Topic: Decided its time for a HHKB pro 2. What do I need to know?  (Read 10672 times)
Offline thefebruaryman
  • turn it off and turn it on again
« on: Sat, 21 February 2015, 16:39:52 »
Hey all. Been using mechanical keyboards for a while now and tried a few. Got me a couple of duckies. And out of all the switches I have used I have most liked the cherry mx blues. But now its time for a HHKB pro 2. For some reason I need to own one.
I am use to UK layout.
My core OS is opensuse with a bit of windows.
I program in python and use ipython and vim for my days work.
And I love my clacks
Offline steve.v
Re: Decided its time for a HHKB pro 2. What do I need to know?
« Reply #1 on: Sat, 21 February 2015, 20:09:42 »
It's all personal preference :D
« Reply #2 on: Sat, 21 February 2015, 20:18:01 »
depends
some people love it, especially on GH
i for one couldn't stand the layout and traded it for a realforce which i'm not too excited about either
for some, it's really as simple as "do you like white or black more" then buy applicable HHKB
« Reply #3 on: Sat, 21 February 2015, 23:28:59 »
HHKB is much easier to use on a Unixy computer than a Windowsy one, because Unix uses Ctrl sequences for cursor motion and Windows does not.
As the HHKB does not have dedicated arrow keys, home, pg up etc., transitioning to it on a Windows computer could take much longer.  I tried for a day, and ended up giving up.  I use function keys, arrow keys, and other cursor navigation keys far too much.
So I took my HHKB home and started using it on my Mac.  Works like a treat.  I have since learned the arrow keys, and that's about all I use on the Mac.  Most other navigation I do with Ctrl sequences (^a beginning of line, ^e end of line and so on).
Using vim you is mostly Ctrl sequences and hjkl for navigation - piece of cake with HHKB layout.
But your biggest problem might be moving away from a UK (ISO?) layout.  HHKB is closest to ANSI, except backspace is where it should be just above Return, and Ctrl is between left shift and Tab, again where it should be.  Once you get used to those two key positions, you will \\\\\\ all the time when you try to backspace on a conventional keyboard (maybe, I do on ANSI, not sure about ISO).
Offline FrostyToast
  • Litshoard
« Reply #4 on: Sat, 21 February 2015, 23:34:33 »
If you really wanted an ISO HHKB then your best bet would be the HHKB JP.
It has an ISO enter as well as a **** ton of other keys.
Quote from: elton5354
Offline Polymer
« Reply #5 on: Sat, 21 February 2015, 23:43:52 »
But the other keys are in different positions and the shift is way way way to the right on the JP HHKB...I think it would take just as much time, if not more, to adjust to the JP version....It also has a shifted row on the bottom...
The extra keys on it are nice..and it has dedicated arrow keys...but if it was great I think more people would be trying to get it on here...
« Reply #6 on: Sun, 22 February 2015, 05:40:09 »
Cheers for all the suggestions. I don't think it will be to difficult getting use to the US layout there are only a few keys that are different. It does make more sense to have the double quote above the single. Having the enter key in easy pinkie reach would be nice as well. Might have to work out what the unicode for the £ sign is though :)
Don't think that the hhkb JP is for me. There are too many changes that would make moving between keyboards a nightmare and a reason for wanting a HHKB pro 2 was so that I wouldn't have to move my right hand as much for the keys I want. Finding this is giving me some odd aches in my wrist.
If I go ahead with getting one I will do a post for the UK users experience ie break in time, pros and cons and work arounds.
cheers again
Offline TopreFan333
« Reply #7 on: Sun, 22 February 2015, 12:10:16 »
Same. Also using a Mac here, and I've found getting used to the arrow keys actually easier than getting used to the Delete key placement.
How are you doing those CTRL sequences? I'm using OPT + arrows to jump back and forward a word at a time, throwing in SHIFT to highlight words as I move.
« Reply #8 on: Sun, 22 February 2015, 12:31:27 »
Basically, HHKB looks cute..
Now when it comes to using it..  You have to get around the limitations by setting up layers via software..  because the hardware layering is clumsy and not optimal..
I've always been against minimalism on keyboards because there are ALWAYS situations where just a few more re-mappable keys will come in handy..
Offline Sencha
  • HHKB Pro
  • MX Reds <3
« Reply #9 on: Sun, 22 February 2015, 13:57:51 »
I'm UK and switched to ANSI a couple of years back. I really dislike ISO now. Personally I love the HHKB and if you got an inkling you may want to try one I doubt it will go away. I know it never did with me, would of saved money if I just caved straight away. :)
Oh and PM'd
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #10 on: Sun, 22 February 2015, 15:03:29 »
remember type - s or go home
Offline ideus
  • Björkö.
« Reply #11 on: Sun, 22 February 2015, 15:25:27 »
The HHKB is like a girl with a hot body with no brains. You may enjoy her company for a night or two, but it would be dead boring for any time after, and she likes to do anything in her own way.
« Last Edit: Sun, 22 February 2015, 15:29:35 by ideus »
Offline gropingmantis
« Reply #12 on: Sun, 22 February 2015, 15:34:34 »
I also use UK ISO (albeit with an ISO HHKB layout) and switching to ANSI is whats putting me off getting an HHKB. Why oh why dont they just make an ISO version? Its not hard.
Offline ideus
  • Björkö.
« Reply #13 on: Sun, 22 February 2015, 15:38:03 »
You can get the GON Happy under $400 with an ISO layout in HHKB style.
« Reply #14 on: Sun, 22 February 2015, 15:42:21 »
Thats what I have! I just wish custom Topre keyboards were possible/easier. Or better yet, this layout with Buckling Spring.
Offline ideus
  • Björkö.
« Reply #15 on: Sun, 22 February 2015, 15:47:44 »
A BS HHKB? Well, you may keep dreaming. Or spend some money to build a handmade prototype with parts harvested from other boards, and some custom made components.
Offline byker
  • Literally Canada
« Reply #16 on: Sun, 22 February 2015, 15:52:00 »
Have you actually owned an HHKB and adjusted to it, or are you just talking **** about it? The layout actually works really well, and is not boring. I use mine as my daily driver and never wish for any other keys.. I have also never had to re-map any keys on it.. For me and many others, it has both the looks and the function.
Offline oledome
  • not batman
« Reply #17 on: Sun, 22 February 2015, 17:08:37 »
Damn that HHKB JP is the hotness.
Offline SpikeBolt
  • √(4) != -2
« Reply #18 on: Sun, 22 February 2015, 17:14:28 »
Which doesn't have Topre switches. Lel
Offline Novus
  • Mondai nothing~
« Reply #19 on: Sun, 22 February 2015, 17:19:10 »
Somehow I doubt you've ever actually experienced that yourself.
« Reply #20 on: Sun, 22 February 2015, 17:21:55 »
Offline Hypersphere
« Reply #21 on: Sun, 22 February 2015, 17:31:16 »
The HHKB Pro 2 layout is efficient and intuitive, but not everyone likes it. Some don't like the return-stroke "clack" of the Topre switches, in which case you might want to consider a Type-S or doing a silencing mod.
« Reply #22 on: Sun, 22 February 2015, 21:23:52 »
you might like it, or you might not. it's a big investment, but luckily if you don't think it's for you then you can resell at a minimal loss.
there isn't really much anybody can tell you, since switch/layout choice is a personal preference.
Offline radio_killah
  • Chinchillin'
« Reply #23 on: Sun, 22 February 2015, 21:28:24 »
You just purchased end game. Welcome to the club.
Offline ideus
  • Björkö.
« Reply #24 on: Sun, 22 February 2015, 21:31:58 »
True: I have never been with a bimbo. :))
Offline TopreFan333
« Reply #25 on: Sun, 22 February 2015, 22:15:43 »
Keep the misogynist crap to yourself, eh?
« Last Edit: Sun, 22 February 2015, 22:20:45 by dchadwick »
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #26 on: Sun, 22 February 2015, 22:18:56 »
Keep the misogynistic crap to yourself, eh?
I'm about 80% convinced he's just in the long term troll now.
Enjoy the thock and brotherhood.
Then be wanting to spend money to get novatouch sliders to get the best part of cherry on the best part of topper.
  • Chinchillin'
« Reply #27 on: Sun, 22 February 2015, 22:20:14 »
Ideus really is turning into Elrick.  :confused:
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #28 on: Sun, 22 February 2015, 22:26:29 »
It's not that hard to swap between the two. I use ISO at work and ANSI at home. Sometimes I prefer ANSI tbh, I only got an ISO mech because i can't change the input language at work. When you accept ANSI into your life, you will find it's a lot easier to enjoy more of the world of keyboards :)
Offline Oobly
« Reply #29 on: Mon, 23 February 2015, 05:18:59 »
Some people report developing finger pain using 45g Topre. It's partly due to the s-shaped force curve of all rubber dome boards that makes it really hard to reduce the force when you bottom out. I'd rather have a nice healthy MX board and live without the "thock".
Also, the layout is a bone of contention. I like some aspects of it, but the arrow and edit key positions suck, IMHO (especially for those who are used to either HJKL or inverted T arrows and have been using them for a long time), and I need to use them a lot in my work. Not being programmable means you can't change them.
They're not easily moddable, and the mods you can do usually require you to buy another Topre board to get parts from (55g domes from Realforce or sliders from Novatouch for instance).
It has a plastic plate, the feet are slippery and you can't get aftermarket keycaps for it (except some artisan caps and some Realforce sets from ebay).
They're expensive. For no good reason.
Other than that, they're okay, I guess.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Bucake
« Reply #30 on: Mon, 23 February 2015, 07:50:13 »
does anyone know if it's 'easy' to sell a hhkb or hhkb type-s? i mean, is there a relatively steady demand for them?
because i've been thinking about getting one for a while, but i don't want to be stuck with it if it turns out i don't like it :D
as for the purple sliders (type-s), what do they actually silence? upstroke, downstroke, both?
Offline SpikeBolt
  • √(4) != -2
« Reply #31 on: Mon, 23 February 2015, 08:01:39 »
Whenever I see one for sale on DT it sells in a couple of days...
Offline ideus
  • Björkö.
« Reply #32 on: Mon, 23 February 2015, 08:03:55 »
The possibility to re-sell a HHKB is the best motivation to get one? interesting :))
Offline paicrai
  • mindblank
« Reply #33 on: Mon, 23 February 2015, 08:12:25 »
THE FEMINIST ILLUMINATI
Offline SpikeBolt
  • √(4) != -2
« Reply #34 on: Mon, 23 February 2015, 08:15:56 »
Who said it was the best motivation? It's just reassuring to know that if you fail to adapt to the layout or the switches you can get most of your money back. It's just a safety net, that's all.
Offline ideus
  • Björkö.
« Reply #35 on: Mon, 23 February 2015, 08:20:05 »
Of course.
Offline Ludovician
« Reply #36 on: Mon, 23 February 2015, 09:03:36 »
What is DT? I'm trying to sell one right now.
Edit: Deskthority?
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
Offline ideus
  • Björkö.
« Reply #37 on: Mon, 23 February 2015, 09:08:47 »
Edit: Deskthority?
Yes.
Offline Zensuji
« Reply #38 on: Mon, 23 February 2015, 11:53:13 »
I myself have sold two HHKBs on DH in the last month. First went in a couple of days and the second in a couple of hours. In fact both times ended up having multiple people wanting them. Then the 55g and 45g Topre I sold took nearly up to a week. But even then what's a week?. Trying a HHKB is a very easy no risk thing (unless you end up buying loads of them LOL). The only reason I sold those two was to grab a Type-s for noise levels. The HHKB is by far my favourite board. Grab one!!
Offline ideus
  • Björkö.
« Reply #39 on: Mon, 23 February 2015, 12:19:24 »
The best board is the one I want to keep using. Isn't it?
No, wait, pay for something just for the sake of trying it, just be sure there is a "market" of people that want to do the same thing.  :p  Don't care at all about wasting time, nor money, this is a hobby after all, so the most time and money you waste the better (!?)
« Reply #40 on: Mon, 23 February 2015, 12:21:07 »
But how can you know which board is for you if you don't try them out?
Offline ideus
  • Björkö.
« Reply #41 on: Mon, 23 February 2015, 12:25:52 »
There used to be something called common sense, and other thing called basic principles of Economy. Or, we are in a distorted field where those myths do not apply anymore?
« Reply #42 on: Mon, 23 February 2015, 12:38:59 »
Like most of your replies that makes absolutely no sense whatsoever.
If someone wants to buy a keyboard to try and they have the means to do so why not? They may or may not like it however if they never try it they won't know if it is the one for them.
True they can make an educated guess based on all of the feedback found in this forum to get a good idea of what keyboard might work best for them but ultimately some things are only learned through experience.
Offline ideus
  • Björkö.
« Reply #43 on: Mon, 23 February 2015, 13:03:11 »
A respectable opinion as any other. Of course, each one expends their money and time as they please. However, it is true as well that some products just do not provide a surplus -a value in excess- for the money you pay for them. In the other hand, buyer's remorse compensates for bad decisions, most of the time.
Offline SpikeBolt
  • √(4) != -2
« Reply #44 on: Mon, 23 February 2015, 13:46:29 »
I don't care if I overpay for a product, if I like it more than anything else then it's worth it to me. It may or may not be worth it to you but that hardly matters. Buy what you want, respect people who buy what they want. As SpAmRaY said you can't really evaluate something without trying, specially on something as subjective as how "x" feels.
Offline TopreFan333
« Reply #45 on: Mon, 23 February 2015, 15:19:43 »
People's weird offense at the very idea of the HHKB aside, the point of some of these posts is that can be resold for close to the original price pretty easily, so it's not a huge risk to buy one if you find the layout or feel (or whatever) is not for you.
« Last Edit: Mon, 23 February 2015, 15:24:27 by dchadwick »
Offline TopreFan333
« Reply #46 on: Mon, 23 February 2015, 15:22:46 »
You realize "value" is a completely subjective metric, right?
Offline ideus
  • Björkö.
« Reply #47 on: Mon, 23 February 2015, 16:55:54 »
Topreism is one of those aspects of life that are so strange, so unique, that us mere mortals are unable to understand.  :thumb:
« Reply #48 on: Mon, 23 February 2015, 16:58:41 »
Methinks someone needs to spend a month with a HHKB.  I had major doubts and thought it was Kool-Aid until I borrowed one.  Now it's my go to board at home while I'm running Ergo Clears at work.
Offline exitfire401
  • The Force is Re/\l
« Reply #49 on: Mon, 23 February 2015, 17:00:18 »
I hated them at first. Then I made one 55g.   :thumb:
