Author Topic: Yoga-Mat Under KB Base for Absorbing KB Noise  (Read 7066 times)
Offline aref
« on: Mon, 23 February 2015, 16:05:04 »
I have a couple yoga mats, and took the older one and cut it into a mat for my TKL keyboards. It works great and silences the one of my KBs by eliminating the key-strike sound from bouncing off my computer tabletop. It's not noticeable with my MX Red keyboard because so much sound comes from the surface of the exposed KB; but on my 55-gram Realforce, it does absorb sound that resonates from the keyboard's base and bounces off my tabletop. This has been an inexpensive, moderately silencing addition for my 87UB. It wasn't noisy, but not it's even quieter than it had been.
The yoga mat I used measures 3/16" thick. The are sold in different thicknesses: 1/8", 3/16", 1/4", and 3/8". I'm sure a 1/8" mat would have worked fine.
« Last Edit: Mon, 23 February 2015, 16:09:09 by aref »
Offline foxer
  • Formerly wadeu
Re: Yoga-Mat Under KB Base for Absorbing KB Noise
« Reply #2 on: Mon, 23 February 2015, 17:08:02 »
I just use a folded up towel. Suffer with sweaty wrists at times so it helps for that, too.
Unbowed, Unbent, Unbroken.
Offline aref
« Reply #3 on: Mon, 23 February 2015, 17:17:04 »
most people use the xtrac xxl
I had the yoga mat on hand, and put it to good use. Xtrac XXL is a good, albeit pricey, product; and it's flat, which would better serve as a large mouse-keyboard-pad. The dimples on the yoga mat might deliver improved acoustics; but it's minor at best when one considers how little sound is generated from the base of a keyboard. Xtrac XXL or another sound absorbing material, they work.
Offline Sygaldry
  • Edema Ruh
« Reply #4 on: Mon, 23 February 2015, 17:20:00 »
I either use a folded up microfiber cloth, which I also use to cover the board when not in use (if I don't, my boards would get covered in cat fur)
Or I use a couple layers of shelf liner
null
Offline aref
« Reply #5 on: Mon, 23 February 2015, 17:45:54 »
I had checked to see if I had shelf liner around, but I used it to stop a couple of keyboards from pinging. Shelf liner would make an excellent sound absorber--good thinking.
« Reply #6 on: Mon, 23 February 2015, 19:43:30 »
I currently use a folded sheet of drawer liner.
Also: https://geekhack.org/index.php?topic=59308.0
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #7 on: Mon, 23 February 2015, 19:59:59 »
I use an extra large mouse mat :)
Offline aref
« Reply #8 on: Tue, 24 February 2015, 10:30:39 »
I was about to order the same from Amazon, it was reasonable, about $10.
Offline cmadrid
« Reply #11 on: Tue, 24 February 2015, 13:24:00 »
http://www.amazon.com/Glorious-XXL-Extended-Gaming-Mouse/dp/B00NOCZTTI/ref=sr_1_7?ie=UTF8&qid=1424795371&sr=8-7&keywords=pc+race+mouse+pad
Xtrac XXL alternative
the xtrac xxl used to be like 24.99..  probably sold elsewhere at that price.. def wasn't $44 like on amazon..
Well, that is good.. it seems like a ripoff at $44.  I like the stitched edge on the Glorious.. I could do without the logo tho
Offline aref
« Reply #12 on: Tue, 24 February 2015, 13:30:31 »
Great find. Price is right, too. The Xtrac is too much money for a mat. But the mats you pointed out are reasonably priced.
Offline smarmar
  • It don't mean a thing if it ain't got that swing
    • Short Stories from an Old Library
« Reply #13 on: Tue, 28 April 2015, 11:15:18 »
One can also use a collectible card game playmat. They can be found for a bit cheaper than most gaming mats but are somewhat smaller. Good for kb coverage, wrist support, and a little left over for mouse action.
http://www.amazon.com/Artists-Magic-Premium-Playmats-DEMONESS/dp/B008RNPS18/ref=sr_1_12?ie=UTF8&qid=1430237487&sr=8-12&keywords=playmat+mtg
1992 IBM Model M | Tesoro Durandal[Browns] | Hi-Tek Series 725[Space Invaders] | Tandy Enhanced[Sliders] | Dell Quiet Keys | Mitsumi[AT]
« Reply #14 on: Tue, 28 April 2015, 11:17:55 »
I use a Tekmat at work
Offline LarsMarkelson
« Reply #15 on: Tue, 28 April 2015, 18:53:35 »
Nice, good usage of an old mat OP. I use a big mat in my kitchen as an anti-fatigue mat. Works great.
Offline Jokrik
« Reply #16 on: Wed, 29 April 2015, 07:25:41 »
I'm gonna try and cut a piece of my wife's yoga mat tonight
Keyboard stuff > important > mad wife
Offline GenKaan
  • Mer caps, mindre käbbel
« Reply #17 on: Wed, 29 April 2015, 08:13:19 »
I got some sort of foam when I picked up my Ducky PBT sets, its just slightly smaller and vanishes underneath the keyboard. Works like a charm and make a massive impact on the sound
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
« Reply #18 on: Wed, 29 April 2015, 08:45:14 »
Solution: get a metal case for your board.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #19 on: Wed, 29 April 2015, 09:27:53 »
Just make sure you put some foam rubber lining in the keyboard too! My first alu case sounded horrible until I put some in.
Offline quake4mhg
« Reply #20 on: Fri, 01 May 2015, 17:31:43 »
I use my worn out goliathus speed :)
