Author Topic: Milk + Coffee Maker  (Read 1758 times)
Milk + Coffee Maker
« on: Tue, 03 March 2015, 10:05:57 »
What would happen if you ran milk through a coffee maker instead of water to make coffee?
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Milk + Coffee Maker
« Reply #1 on: Tue, 03 March 2015, 10:10:56 »
You'd probably end up with a bunch of curdled milk inside the coffee machine and result in some really ass 'cappuccino'.
« Reply #2 on: Tue, 03 March 2015, 10:13:23 »
Yeah that's what I was thinking to.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #3 on: Tue, 03 March 2015, 10:15:52 »
My mom had to throw ours out after I did that when I was like 6.  Might be able to clean it with some vinegar afterwards though.
« Reply #4 on: Tue, 03 March 2015, 10:47:28 »
hahahahaha... yup.. the oil will stick to heaters inside and get really gross..
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #5 on: Tue, 03 March 2015, 13:56:03 »
As a certain somebody would say this is worse than a Teepee thread :p
Offline Mandolin
  • Crystal Connoisseur
« Reply #6 on: Tue, 03 March 2015, 13:59:53 »
I did this once too and trashed it.
You need a coffee maker with a milk receptacle (I have an Oster Prima Latte and can recommend it)
Oster BVSTEM6601S-049 Coffee Maker
I think it's the same as this: http://www.amazon.com/Mr-Coffee-Espresso-Automatic-BVMC-ECMP1000/dp/B007K9OIMU/
« Last Edit: Tue, 03 March 2015, 14:07:07 by Mandolin »
Artisan keycap Maker
Working on
- Custom keycaps
- Artkeycaps V2 sale
- Due chihuahua and demoncat orders
- Boobiecaps
- Optic fiber embedded keycaps
- Others
« Reply #7 on: Tue, 03 March 2015, 14:00:30 »
Now that is fancy.
Offline Novus
  • Mondai nothing~
« Reply #8 on: Tue, 03 March 2015, 14:01:15 »
Bonavita
Offline Mandolin
« Reply #9 on: Tue, 03 March 2015, 14:18:43 »
I also ruined a couple of thermos by doing that. Milk would filter through the gasket. You should rinse it thoroughly with a chlorine dilution afterwards, but even then, rubber don't take well [rotten] milk.
In the meantime, heat the milk separately, then add it.
Working on
- Custom keycaps
- Boobiecaps
- Others
