Author Topic: Separating Ergo Keyboard?  (Read 6904 times)
Offline Dvisic
« on: Thu, 19 March 2015, 20:05:38 »
Quick question (I did some searching, and didn't see an answer...but that doesn't mean it isn't there):
I'm kitting out a cockpit for star citizen. Nothing so elaborate as a simpit, but I probably will have a car style seat and a general cockpit feel. If I wanted to have a split keyboard with easy access without moving my arms a lot, can something like the Goldtouch split keyboard be cut apart at the hinge, adding a longer wire to connect the two halves?
I'm specifically thinking of keyboards like this one:
Thanks,
Dvisic
« Last Edit: Thu, 19 March 2015, 20:09:01 by Dvisic »
Offline engicoder
Re: Separating Ergo Keyboard?
« Reply #1 on: Thu, 19 March 2015, 20:34:45 »
I'm sure it can if your comfortable with soldering.
As an alternative, have you looked at the ErgoDox?
http://ergodox.org/
Offline Dvisic
« Reply #2 on: Thu, 19 March 2015, 22:28:47 »
http://ergodox.org/
I did, yeah, and it looks very cool. It just looks a bit higher on the cost/effort scale. Of course, that assumes I can find a cheap used ergo keyboard somewhere....
Offline Liar
« Reply #3 on: Fri, 20 March 2015, 03:03:54 »
Ergodox can now be preordered pre-assembled from
http://www.ergodox-ez.com/
Though you may not get it until December-ish
Great time to snag one at this price
Offline Oobly
« Reply #4 on: Fri, 20 March 2015, 03:44:43 »
Perhaps a pair of remapped Filco numpads laid out horizontally?
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Dvisic
« Reply #5 on: Fri, 20 March 2015, 03:49:55 »
And why should I believe you?   ;D
Seriously, though, $220 after shipping is a little more than I can justify spending on a keyboard right now.  Especially as I've never really used a mechanical keyboard, so I don't really know that I'll like it any better.
Although there do seem to be rather strong feelings by those who use them....
Phiz
Offline Dvisic
« Reply #6 on: Fri, 20 March 2015, 03:55:42 »
Hmm.  I'll look into that.
As an aside, what is that cool keypad configuration in your avatar??
Offline jacobolus
« Reply #7 on: Fri, 20 March 2015, 04:34:56 »
Offline Oobly
« Reply #8 on: Fri, 20 March 2015, 06:08:06 »
DIY split ergo keyboard: https://geekhack.org/index.php?topic=49721.0
Lots of work, lots of reward :) I'd love to make it into a product, but I haven't enough time for all my keyboard projects!
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #9 on: Fri, 20 March 2015, 07:15:08 »
Have you considered the Kinesis Freestyle? Two halves, can be separated up to 20", and around $100. Not mechanical though.
Offline Lastpilot
  • Power stance
« Reply #10 on: Fri, 20 March 2015, 09:49:00 »
« Last Edit: Fri, 20 March 2015, 09:52:38 by Lastpilot »
« Reply #11 on: Fri, 20 March 2015, 09:49:22 »
Welcome to Geekhack, Dvisic! Your username sounds Slavic. Where are you from?
Davkol in the Czech Republic has a larger Goldtouch with a broken hinge for sale for €15. It is otherwise new and has keys with regular key travel.
If it is anything like the Goldtouch that I had, you would need a relatively thick cable (with many wires) for it though. Shouldn't be a problem to take apart, only more soldering work.
« Last Edit: Fri, 20 March 2015, 09:52:27 by Findecanor »
Offline Dvisic
« Reply #12 on: Fri, 20 March 2015, 11:29:51 »
Nothing so exciting, I'm afraid. I live just outside Portland, OR, USA.  A number of years ago, I was attempting to come up with a username for a forum.  Everything I thought of was taken. Frustrated, I glanced down at my desk. A circular for a local music shop was lying there, with a CD for sale with "Advisory: Explicit Lyrics" on the cover. I took the "dvis" from "advisory" and the "ic" from "lyrics" and, well, the rest is history. I've been using it ever since. :P
Offline monotagary
  • Keycaps > Rent
« Reply #13 on: Fri, 20 March 2015, 12:06:58 »
I think the Virgo keyboard has made a recent debut over in kbdlabs.
http://kbdlab.co.kr/index.php?mid=board_Lsno50&page=6&document_srl=1064154
http://kbdlab.co.kr/index.php?mid=board_Lsno50&page=3&document_srl=1156358
Holy moly, it's even an Alps board too.
« Reply #14 on: Fri, 20 March 2015, 13:15:14 »
That's weird as hell, but I kind of want it.
« Reply #15 on: Fri, 20 March 2015, 13:45:30 »
Phiz
Strong feelings?
How dare you disparage my Love..
JKJK
Um.. There are no "mechanical" 2mm actuating split keyboards on the market @ less than $200..
I think if you're just building a play seat.. that goldtouch you posted is the way to go, since you're not going to be working from it.. just some gaming..
Offline SonOfSonOfSpock
« Reply #16 on: Fri, 20 March 2015, 14:26:50 »
The Kinesis Freestyle is split with a wire in between. They have two different options for separation 9" and 20".
http://www.kinesis-ergo.com/shop/freestyle2-for-pc-us/
Offline davkol
  •  Post Editing Timeout
« Reply #17 on: Fri, 20 March 2015, 15:00:20 »
Tipro daisychain…
…or my goldtouch. ^_~
« Reply #18 on: Fri, 20 March 2015, 15:31:52 »
pretty sure that's not mechanical.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #19 on: Fri, 20 March 2015, 16:09:50 »
Key switch
Peak force: 44 grams
Activation force: 35 grams
Travel distance: 3.9 mm
Switch type: Rubber dome, membrane
Confirmed
