Author Topic: Idle Laptop  (Read 3414 times)
Idle Laptop
« on: Mon, 23 March 2015, 20:12:15 »
What would you guys consider acceptable idling temperature for Laptops
Since the damn things are designed to run 100-C...
I feel like, 60-C might even be ok for idle (nothing running cept windows)
It wouldn't really hit that unless you turn the fan off with a control app.
Offline tbc
Re: Idle Laptop
« Reply #1 on: Mon, 23 March 2015, 21:36:36 »
60 is fine.  40 is awesome.  80 is absurdly dangerous - do not use.
Re: Idle Laptop
« Reply #2 on: Mon, 23 March 2015, 22:12:34 »
I can hit 40-45 Idle if I leave the fan on..
It can even drop to 35-40 when the c1-state kicks in
Just wondering if disabling it is wise.. it will idle @ < 65 with the fan off and light browsing.
Offline ctm
  • Hello, world!
Re: Idle Laptop
« Reply #3 on: Wed, 25 March 2015, 15:23:22 »
The CPU temperature of ASUS laptop (don't but ASUS. The quality is poor) is about 60 to 70. But it's not really idle because I am running BOINC which causes about 15% CPU workload.
Coming:
Ellipse Model F F62.
Re: Idle Laptop
« Reply #4 on: Wed, 25 March 2015, 15:36:29 »
I think it's fine to run boinc on laptops, but not "plastic" laptops, because the heat tends to warp the plastic over time. hahahaha..
Offline ctm
  • Hello, world!
Re: Idle Laptop
« Reply #5 on: Wed, 25 March 2015, 15:55:57 »
My old Thinkpad was "plastic" and it seems to be fine after running BOINC for two years. My current ASUS has a metal plate so I guess there won't be problems with this. (But its quality is really poor. In one year of use, I encounter battery problem twice. The laptop does not recognize the battery and I have to remove the battery to plug in again, which is not so easy because it does not have a removable battery design and I have to disassemble the laptop to do so. Also at the time of about one year of use, its screen hinge broke down for no reason. So now it's basically a desktop that looks like a laptop. I use external monitor, keyboard and mouse :D Hopefully It will survive at least two more years before I get a new computer.)
Coming:
Re: Idle Laptop
« Reply #6 on: Wed, 25 March 2015, 19:05:53 »
are u sure it was plastic and not a magnesium alloy?
Offline ctm
  • Hello, world!
Re: Idle Laptop
« Reply #7 on: Wed, 25 March 2015, 19:43:49 »
I believe the outer case is plastic, because it feels like plastic. Maybe the inner frame is metal. I am not sure.
Coming:
Re: Idle Laptop
« Reply #8 on: Wed, 25 March 2015, 19:45:49 »
The magnesium may feel like plastic because of the lacquer coating.. but it's probably magnesium if it was a "for work" series laptop
Offline ctm
  • Hello, world!
Re: Idle Laptop
« Reply #9 on: Wed, 25 March 2015, 19:52:39 »
You are right. I just google it and find it's indeed made of magnesium alloy with a coating. That explains why Thinkpads are so tough :).
Coming:
Re: Idle Laptop
« Reply #10 on: Wed, 25 March 2015, 19:54:12 »
LOL, yea don't try banging them around though, the later models like my x220 doesn't have the inner carbon fiber layer,  which means it's strong but brittle.
Offline ctm
  • Hello, world!
Re: Idle Laptop
« Reply #11 on: Wed, 25 March 2015, 21:40:25 »
I miss how solid my old TP was.
Coming:
Re: Idle Laptop
« Reply #12 on: Wed, 25 March 2015, 21:44:45 »
Well, I think pretty much any laptop with Core2duo 2.0+ Ghz is fairly usable "today".. so your old thinkpads arn't really obsolete.
But anything BEFORE c2d, or less than 2ghz would feel pretty slow.
Offline ctm
  • Hello, world!
Re: Idle Laptop
« Reply #13 on: Thu, 26 March 2015, 07:54:45 »
Especially when running Linux with a light weight desktop environment like XFCE  :cool:.
Coming:
