Author Topic: Where is a good place to buy a CM QFR?  (Read 3346 times)
Offline Lazerxzz
« on: Wed, 25 March 2015, 11:55:04 »
Newegg and amazon are out of stock unless I pay $30 more and the only ones in-stock are brown /blue switches and I want reds. I tried bestbuy but they only have the older model.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
Re: Where is a good place to buy a CM QFR?
« Reply #2 on: Wed, 25 March 2015, 12:17:30 »
I'm always surprised when TP posts out of off topic. :)
I believe CM has been having some supply issues of late. They seem to be out of stock almost everywhere.
« Reply #3 on: Wed, 25 March 2015, 12:21:03 »
It's primarily because there hasn't actually been ANY innovation in mech key since the Ergodox..
And since we've determined that most people arn't actually ready for the Egdx, I've temporarily suspended the-Crusade..
As far as information regarding all the other stuff here,  it's just rehashes upon rehashes..
Not much to talk about..
« Reply #4 on: Wed, 25 March 2015, 12:23:17 »
Are we sure CM hasn't discontinued the QFR?
Offline inanis
    • SEALWoodworking
« Reply #5 on: Wed, 25 March 2015, 12:25:10 »
They very well may have in favor of the QFR-i. I'm not too up on the latest CM offerings, so you are probably right.
« Reply #6 on: Wed, 25 March 2015, 12:26:31 »
They're probably thinking.. putting the bottom line so low makes their other stuff a tough sell..
It's like when AMD came out with the HD 48xx series,  the $300 HD 4870 card bested nvidia's $500 monster..
Over night, price crash.
In the realm of Mech key..  You're not realllly getting that much more for your money beyond the QFR..
Offline ctm
  • Hello, world!
« Reply #7 on: Wed, 25 March 2015, 13:29:51 »
It seems the stock of mechanical keyboards are quite unstable.
Coming:
Ellipse Model F F62.
Offline Huxley2500
« Reply #8 on: Wed, 25 March 2015, 13:35:41 »
R.I.P. Quickfire Rapid
Offline Lazerxzz
« Reply #9 on: Wed, 25 March 2015, 14:19:22 »
Yeah just going to order a k65, been looking for hours gave up.
Offline inanis
    • SEALWoodworking
« Reply #10 on: Wed, 25 March 2015, 14:25:29 »
Why not get the QFR-i? At least that has a standard bottom row. Hell, why not get any TKL with a standard bottom row....
Offline Lazerxzz
« Reply #11 on: Wed, 25 March 2015, 14:27:51 »
Don't have over $105 to spend :(
Offline saturnotaku
« Reply #12 on: Wed, 25 March 2015, 14:30:37 »
Then I would suggest bookmarking an eBay search (they come up there occasionally), the classified section here, and /r/mechmarket on reddit.
Offline inanis
    • SEALWoodworking
« Reply #13 on: Wed, 25 March 2015, 14:40:09 »
I would encourage you to look around for something more standard then settle for the K65. Obviously you can do whatever you want, and perhaps that bottom row doesn't bother you, but it does limit your options going forward. There are options out there that will come in under $100, though you might have to compromise on using clone switches, such as Kailhs. Or as saturnotaku mentioned, look in the Classifieds or check eBay. That non-standard bottom row really sucks, in my opinion.
Offline Lazerxzz
« Reply #14 on: Wed, 25 March 2015, 14:50:47 »
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=264  thoughts?
Offline saturnotaku
« Reply #15 on: Wed, 25 March 2015, 15:20:08 »
Offline Altis
« Reply #16 on: Wed, 25 March 2015, 19:13:48 »
Are you in Canada, by chance?
I saw a bunch of them at Canada Computers the other day in Ottawa. Might be able to get them from there. (keep in mind the Canadian dollar is pretty weak right now so if you're buying from the US it might work out pretty inexpensive).
Offline inanis
    • SEALWoodworking
« Reply #17 on: Wed, 25 March 2015, 19:20:17 »
There are also a few TKL boards available through Massdrop right now. I know it isn't everyone's favorite place, but $65 for a Keycool 87 is pretty good.
https://www.massdrop.com/buy/keycool-87-backlit-mechanical-keyboard?mode=guest_open
