Author Topic: Best cheap and easy to do mods to change my cherry mx blue experience?  (Read 4274 times)
Offline Nikelu
  • Don't read this!
Which orings are better? How easy it is to put shelf cloth or how it is called?How and what materials do I need to lube my keyboard and what do I get from that? Landing pads arent available in Greece anyway,so that must be pretty much it
Re: Best cheap and easy to do mods to change my cherry mx blue experience?
« Reply #1 on: Mon, 30 March 2015, 18:55:45 »
I hate O-rings.  Might as well get rubber domes.
Shelf liner is damn easy to put it. Some like the checkered, I prefer the more solid.
For lubing, I recommend Krytox.
Offline KHAANNN
« Reply #2 on: Mon, 30 March 2015, 19:01:06 »
Just this: http://www.ebay.com/itm/120pcs-Keycap-Rubber-O-Ring-Switch-Dampeners-RED-For-CHERRY-MX-Free-Shipping-/261268631414
I suggest not stuffing your keyboard with stuff, I haven't noticed any improvements in my stuffing experiments, it just makes it harder to re-open the keyboard
Offline Nikelu
  • Don't read this!
« Reply #3 on: Mon, 30 March 2015, 19:06:48 »
Hm looks like I can find this stuff easily,DUPONT makes these so I guess they are everywhere in the correct shops.But what's the process of lubing. Just take a paintbrush and put the krytox where exactly ?[(serious answers only)] I never seem to find a decent video on youtube of someone performing the mod.
Offline Nikelu
  • Don't read this!
« Reply #4 on: Mon, 30 March 2015, 19:10:22 »
What is the thickness of these? I  will try to find similar ones because only one shop brings those to Greece.
Offline KHAANNN
« Reply #5 on: Mon, 30 March 2015, 19:24:24 »
1.5mm it says, they are the thinnest and softest o-rings I've seen
They lube the switches after removing/desoldering each one (or before soldering them on, for DIY keyboards)
It's really risky and unnecessary for blues
I suggested these o-rings, as I use them on MX Green's and enjoy them a lot, they are light enough to not mess with the click action
Offline mason
  • have fun with her, ryan
« Reply #6 on: Mon, 30 March 2015, 20:52:38 »
Yeah shelf liner is pretty easy.. you can probably get it done in less than 30 minutes.
« Reply #7 on: Tue, 31 March 2015, 00:37:02 »
are they softer than the blue ones from wasd
Offline Nikelu
  • Don't read this!
« Reply #8 on: Tue, 31 March 2015, 04:28:52 »
Hey KHAANNN all o-rings available for me are 1,6mm. But from the 3 options the 2 say smth like hardness(not sure if accurate translation from german to english) 40A and the other one says 50A. Which should I choose?
Offline KHAANNN
« Reply #9 on: Tue, 31 March 2015, 08:42:31 »
it should be 50a>40a in hardness, I would go with 40a, the WASD ones are also 40a as far as I know
you can also buy small amounts of both, test them, and use the ones you like
Offline henz
  • What?
« Reply #10 on: Tue, 31 March 2015, 08:54:32 »
imsto is offering silica balls that you put into the switch, im in the process of remodding a pair of blues with  these balls and also put 85 g springs into them.
Edit: You  can also go buy some lube in your hardware store.
Offline KHAANNN
« Reply #11 on: Tue, 31 March 2015, 11:37:42 »
I also ordered some imsto balls, but they just shipped, the delays are high, how do you like them?
I'm guessing blues+85g is pretty much = greens
I don't think he's going to open up his keyboard tho, I think he's looking for external mods instead, as I've read his previous threads
Offline Nikelu
  • Don't read this!
« Reply #12 on: Tue, 31 March 2015, 12:24:49 »
Ordered the 40A 1,6mm :D Thanks for the advise.Will see if these suit me,but would be another experience for sure. Will see about modding later,now I can't afford tools and internal modding.
« Reply #13 on: Tue, 31 March 2015, 12:29:45 »
I would not recommend that.  Most the lubes will cause issues or are dramatically inferior to Krytox.
Also keep in mind that lubing Blues runs the risk of making them stop clicking.
