Author Topic: MOBO Ram  (Read 2435 times)
Offline Dr.Chipotle
MOBO Ram
« on: Sat, 04 April 2015, 17:00:05 »
So i found these two different rams
g. skill rip jaw part# F3-10666CL7D-8GBRH
g. skill rip jaw part# F3-10666CL9D-8GBRL
With the two differnt numbers and letters, would it matter which one i got?
Offline FreeCopy
Re: MOBO Ram
« Reply #1 on: Sat, 04 April 2015, 17:02:30 »
Personally I'd go for the one ending in H for the lower CL and the color.
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
Offline user 18
Re: MOBO Ram
« Reply #2 on: Sat, 04 April 2015, 17:10:29 »
Assuming your board supports it, the former will be faster.
Avatar by ashdenej
Re: MOBO Ram
« Reply #3 on: Sat, 04 April 2015, 17:40:06 »
Also remember,  the autodetect goes by the SPD table,  but that doesn't mean it'll pick the right table..
So make sure to tune it manually,  or if it has xmp, enable xmp.
Offline Dr.Chipotle
Re: MOBO Ram
« Reply #4 on: Sat, 04 April 2015, 18:23:19 »
Well my board supports the first one, but im not sure if it supports the second one
