Author Topic: At what age...  (Read 3636 times)
At what age...
« on: Sat, 11 April 2015, 08:35:01 »
Did you learn that slapping the computer chassis from the outside doesn't make it work m0re betters.. ?
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
Re: At what age...
« Reply #1 on: Sat, 11 April 2015, 08:36:01 »
But it does?
Offline belac
Re: At what age...
« Reply #2 on: Sat, 11 April 2015, 08:41:07 »
we had a computer in college that responded very well to slapping the chassis. you could hear the hd starting to spin down and if you didn't whack the **** out of it, the thing would lock up and you could kiss your work goodbye (this was pre-autosave and document recovery days).
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: At what age...
« Reply #3 on: Sat, 11 April 2015, 08:43:05 »
As soon as I built my own. Didn't fancy risking breaking 1800 pounds of electronics.
Re: At what age...
« Reply #4 on: Sat, 11 April 2015, 08:56:15 »
1800 gpb ?  was this before or after august 2008
Offline katushkin
  • Just the guy
Re: At what age...
« Reply #5 on: Sat, 11 April 2015, 08:58:21 »
July 2011
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
Re: At what age...
« Reply #6 on: Sat, 11 April 2015, 18:12:34 »
I also realized that unloading my rounds on the monitor doesn't actually save the world.
Re: At what age...
« Reply #7 on: Sat, 11 April 2015, 18:27:32 »
I still slap my case fans when they decide to rattle, and it does work.
Offline Novus
  • Mondai nothing~
Re: At what age...
« Reply #8 on: Sat, 11 April 2015, 18:39:18 »
Just noctua.
Re: At what age...
« Reply #9 on: Sat, 11 April 2015, 19:11:48 »
Tried them too. I've yet to find a case fan that doesn't start to rattle when placed horizontally. At this point I've probably tried about 7-10 different brands and all develop a rattle after about a week or two.
Re: At what age...
« Reply #10 on: Sat, 11 April 2015, 19:25:36 »
Just noctua.
Noctua uses a much better driver-chip than other fans which either "whine" or "click" @ low rpm..
That's truly their only advantage.. all that other "aerodynamic" stuff they advertise, I feel is pure bull****..
Re: At what age...
« Reply #11 on: Sat, 11 April 2015, 19:26:30 »
Really?
Noctua rattles for you?
Hrrrrmmm.... all of them, or just 1..  which way did you put it..  air blowing down or air blowing up
Offline fanpeople
Re: At what age...
« Reply #12 on: Sat, 11 April 2015, 19:30:37 »
As a child, the television wrapped in wood grain coloured laminate responded positively to slapping. literately it would be an as**** and you would give it a hard slap and the picture would come back. This worked for some other devices also but I cannot exactly remember which ones. I am not old either, still in 20s, mid 20s. How technology changes I don't even go near my flat screen let alone slap it.
Re: At what age...
« Reply #13 on: Sat, 11 April 2015, 19:32:51 »
I remember my old crt had a cracked pcb.. that when you hit the tv, it'd connect back up. .hahahah
Re: At what age...
« Reply #14 on: Sat, 11 April 2015, 19:49:12 »
Really?
Yup, bought a pair of r8-1800's for the top of my case (blowing up/out) and both started to rattle by week 2. I later installed them vertically hoping I could still use them but the rattle was permanent no matter how I set them up. It only stops if I press my finger down hard in the middle, and only if you hold it there. Same deal with Cougar, a bunch of Cooler Master Models, and the couple Scythe fans I've tried. All rattle like a spoon in a garbage disposal.
« Last Edit: Sat, 11 April 2015, 19:50:50 by noisyturtle »
Re: At what age...
« Reply #15 on: Sat, 11 April 2015, 20:10:27 »
Really?
I think you just need to oil them..
because they might sit on the shelf for a long time.
Offline fanpeople
Re: At what age...
« Reply #16 on: Sat, 11 April 2015, 20:17:18 »
It was probably a similar issue with all that older stuff, bad connections jolted back into place.
Offline tbc
Re: At what age...
« Reply #17 on: Sat, 11 April 2015, 21:57:24 »
Really?
are you sure your case is flat?
i wonder if one corner is 'lower' than the others (according to gravity, not the floor)
Re: At what age...
« Reply #18 on: Sat, 11 April 2015, 23:56:44 »
But it makes you feel better, and thus less bothered that the computer is not working better, hence giving the appearance that it is working better.
