Author Topic: What to do to get closer to the Ultimate Topre experience with a Novatouch?  (Read 1910 times)
Offline Nikelu
  • Don't read this!
I heard that PBT keycaps bring a lot to the game,but too thick and the thock will be less loud.What to do with a stock Novatouch to improve it
Offline Dee1
I suggest doing spicebar's landing pad mod. The stock Novatouch has the loud upstroke due to the plastic mx-switch slider hitting the plate. I have done this to mine, and the result is really nice. The classic topre "thock" sound is still very satisfying after this doing this. :)
The stabilizers could use some lubing as well to fix the rattling.
Nope.. the only acceptable topre board is the uTron.
Everything else is N00br
Offline IonutZ
  • Stay awhile and listen
    • SC
Buy a Realforce!
Offline MJ45
  • HHKB Pro
Buy a Realforce!
qft
Then some are putting the Novatouch experience into Topre's (slider swapping).
Offline KeypressGraphics
  • Dare to Dream
    • Keypress Graphics
Cannibalize its' sliders for the HHKB you're about to purchase. :)
May all your key presses strike true.
  Choc Mini         HHKB
