Author Topic: New internet...  (Read 15144 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
Re: New internet...
« Reply #50 on: Wed, 27 May 2015, 18:33:20 »
I would need new antennas though, right? Or am I wrong lol
If I were to buy the 6300, I can just slot it in with no new antennas?
« Last Edit: Wed, 27 May 2015, 18:35:48 by HUNTERANGEL121 »
Re: New internet...
« Reply #51 on: Wed, 27 May 2015, 18:37:27 »
It's the same antennas..
If you get 6300, you will only get 2 streams with the 2 antennas that's already in the alienware.
You would need 1 more antenna..
But
If you get the 7260 ac,  you can just use the 2 antennas that are already installed..
Offline C5Allroad
Re: New internet...
« Reply #52 on: Wed, 27 May 2015, 18:38:14 »
But
So where do I get antennas?
Maybe mom won't notice her laptop isn't as quick if I swap lol
Re: New internet...
« Reply #53 on: Wed, 27 May 2015, 18:40:42 »
But
Um... LOL hahahaha
the Laptop MIGHT have a locked bios.. it's more likely to have a locked bios than the desktop is.
but if they're both alienware,  i guess maybe it'll work just fine, since the alienware would recognize the dell brand cards..
IDK man, you just gotta try it in this case..
You can't steal an antenna from the laptop though,  it's wired up through the screen and behind the bezel.
that's an hour to get it out,  you might as well just pay the $2 to buy a new one.
Also there are people selling FAKE 2.4ghz antennas as 5ghz antennas..
THere's no way to tell on Amazon..
You jsut have to buy it and test it.
Offline C5Allroad
Re: New internet...
« Reply #54 on: Wed, 27 May 2015, 18:43:06 »
But
Um... LOL hahahaha
They're both dell lol
I'm just confused on how the hell to route it and mount it. Do I route those cool antennas like on my Asus router? And drill some holes?
So this http://www.amazon.com/Super-Power-Supply%C2%AE-TL-WR1043ND-WZR-HP-G450H/dp/B00DTXGT1E/ref=sr_1_10?s=electronics&ie=UTF8&qid=1432770119&sr=1-10&keywords=5ghz+antenna
and http://www.amazon.com/Intel-Centrino-Ultimate-n-633anhmw-802-11a/dp/B00HRLRJUO/ref=sr_1_1?s=electronics&ie=UTF8&qid=1432770247&sr=1-1&keywords=intel+6300
theoretically will work... Right?
Re: New internet...
« Reply #55 on: Wed, 27 May 2015, 18:47:39 »
If you get the intel 6300, and need a third antenna,  you also need     http://www.amazon.com/U-FL-RP-SMA-Pigtail-Antenna-Cable/dp/B005UWD0EG/ref=pd_bxgy_147_img_y
to connect between the wifi card and the external antenna..
The x51 has 2 external antennas right?
Never mind.. it doesn't come with external antenna.
So basically,  you just gotta buy the pigtail- interconnect, the antenna  and drill 1 hole
But here ,, the confounding variable is,  now you have to test both the antenna, AND the pigtail connector for 5ghz operation..
Because , the sellers are sleezy.. and may try to pass off 2.4ghz parts as 5ghz..
Because they DO WORK,  despite having a dramatically reduced performance.
Offline C5Allroad
Re: New internet...
« Reply #56 on: Wed, 27 May 2015, 18:54:36 »
Sweet, thanks lol...
Although, after all this... I'm weighing my options... Holes, or card.. Tanks bb
Re: New internet...
« Reply #57 on: Wed, 27 May 2015, 18:59:10 »
IMHO,  drilling holes in your house is most worth it... for bulletproof internet...
Wireless, I'd stick with the intel 6300 + antennas + interconnect, so I don't need to buy a new router.
Offline C5Allroad
Re: New internet...
« Reply #58 on: Wed, 27 May 2015, 18:59:56 »
Well, off to home depot to buy some fancy 4ft drill bit.
Re: New internet...
« Reply #59 on: Wed, 27 May 2015, 20:42:28 »
Why do you need a 4ft drill bit?
Offline C5Allroad
Re: New internet...
« Reply #60 on: Wed, 27 May 2015, 20:43:29 »
Drill through the floor, and route it under the house lol. Not sure about rodents though.
Re: New internet...
« Reply #61 on: Wed, 27 May 2015, 20:44:25 »
Rodents? The hole should only be big enough for the wire to fit through.
Offline C5Allroad
Re: New internet...
« Reply #62 on: Wed, 27 May 2015, 20:45:29 »
Right but under the house, there are two huge doors we can open to crawl under. But I wonder if rodents will get hungry
Re: New internet...
« Reply #63 on: Wed, 27 May 2015, 20:46:34 »
Ah it'll only tickle if they're small, just don't let them smell your fear.
Offline C5Allroad
Re: New internet...
« Reply #64 on: Wed, 27 May 2015, 20:47:17 »
How do I make sure I don't smell like fear?
Re: New internet...
« Reply #65 on: Wed, 27 May 2015, 20:56:03 »
Drink this Everyday for a month...
Offline C5Allroad
Re: New internet...
« Reply #66 on: Wed, 27 May 2015, 21:01:00 »
Energy drinks aren't my thing...
But, how in the living hell do I get rid of cmd saying gateway.2wire? Done with att lol
Re: New internet...
« Reply #67 on: Wed, 27 May 2015, 21:02:28 »
Ur gonna need that Nergy to fight off the mole people living under your house.
Re: New internet...
« Reply #68 on: Wed, 27 May 2015, 21:04:29 »
LOL that's amazing.  :))
You have very thick floors, HA.  :O  I'm not at all familiar with the design of homes without basements (except for cabins), so pardon my ignorance.  But 4ft seems way more than you would ever need...  O.o
Offline C5Allroad
Re: New internet...
« Reply #69 on: Wed, 27 May 2015, 21:06:22 »
Our homes are elevated lol. We can get away with 2ft probably. Our house is I think 3ft up? Something like. 3  steps to the main level, and then an extra step so like 3-4th up Lol
Re: New internet...
« Reply #70 on: Wed, 27 May 2015, 21:11:46 »
Yeah 12-18 inches is usually more reasonable.
Offline C5Allroad
Re: New internet...
« Reply #71 on: Wed, 27 May 2015, 21:13:35 »
Yeah 12-18 inches is more reasonable.
Measured out to about 40ft needed for the cable. All kinds of excited. Feels like I still have att.
Re: New internet...
« Reply #72 on: Wed, 27 May 2015, 21:15:12 »
And you have to drill through that entire thickness with a single bit?  If you have a crawl space below the house, shouldn't you only have to go through the thickness of the floor (12-18 inches, as Ray said) and then you'll be in the clear to reach it from below?
Offline smknjoe
Re: New internet...
« Reply #73 on: Wed, 27 May 2015, 21:16:06 »
Houses without basements are built just like houses with basements (unless you have a concrete slab like most houses here in Texas) except the earth is not excavated beneath it. You shouldn't need to drill through more than a couple of inches.
...flooring material (carpet, wood, etc.), sub-floor which is plywood 3/4", and that's about it for most non-slab houses in the South. You have floor joists for structural support, but you don't need to drill through those.
« Last Edit: Wed, 27 May 2015, 21:26:24 by smknjoe »
SSKs for everyone!
Offline C5Allroad
Re: New internet...
« Reply #74 on: Wed, 27 May 2015, 21:17:38 »
No clue why he wants 4ft. Shouldn't be more than a foot.
Offline C5Allroad
Re: New internet...
« Reply #75 on: Wed, 27 May 2015, 21:22:52 »
It's been a while since I've been in cmd... This is normal. Right? Also... On comcast... Is the username the network name? Can't login...
« Last Edit: Wed, 27 May 2015, 21:28:22 by HUNTERANGEL121 »
Re: New internet...
« Reply #76 on: Wed, 27 May 2015, 21:29:44 »
is this cable, fiber ?  what is this.
Offline C5Allroad
Re: New internet...
« Reply #77 on: Wed, 27 May 2015, 21:32:12 »
Cable. But me trying to connect to the router to change settings isn't letting me...
Why can't I just log in with network name and pass? Ugh...
« Last Edit: Wed, 27 May 2015, 21:34:49 by HUNTERANGEL121 »
Re: New internet...
« Reply #78 on: Wed, 27 May 2015, 21:41:33 »
What are you trying to change? Also many consumer routers don't always allow access via command line/Telnet unless you configure it from a web GUI first.
Offline C5Allroad
Re: New internet...
« Reply #79 on: Wed, 27 May 2015, 21:43:08 »
Well, I had a server set up for assetto corsa. All the ports were set. But now I kinda have to do it again. Oh well.
Offline Oobly
Re: New internet...
« Reply #80 on: Thu, 28 May 2015, 10:05:59 »
Move your PC to the router room and hook it up with wire. Or move the router to your room. Wireless sucks.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Re: New internet...
« Reply #81 on: Thu, 28 May 2015, 10:13:42 »
But then he can't play video games when he's suppose to be doing his homework.
Offline C5Allroad
Re: New internet...
« Reply #82 on: Thu, 28 May 2015, 10:23:49 »
Exactly. That and my room has a window that serves for nothing. It could be noon and I wouldn't even know.
Re: New internet...
« Reply #83 on: Thu, 28 May 2015, 10:25:53 »
You'll know...  noon is when Joey messages you for m0re dota..
Offline C5Allroad
Re: New internet...
« Reply #84 on: Thu, 28 May 2015, 10:26:40 »
I know its noon when I wake up at noon. Then it's time for breakfast
Re: New internet...
« Reply #85 on: Thu, 28 May 2015, 10:34:13 »
Oh god..  perhaps we all need an Intervention..  and get internet outside of our rooms.. hahahahaha...
Offline C5Allroad
Re: New internet...
« Reply #86 on: Thu, 28 May 2015, 10:36:02 »
We have internet outside our rooms. Smart phones bruh
Re: New internet...
« Reply #87 on: Thu, 28 May 2015, 10:42:33 »
Game over..
Offline C5Allroad
Re: New internet...
« Reply #88 on: Thu, 28 May 2015, 10:44:57 »
Game over..
English teacher doesn't see phone.
Only difference is there's light around me.
