Author Topic: Thick PBT Costar Stabilizer Problems  (Read 5617 times)
Offline Keytrun
« on: Wed, 03 June 2015, 02:43:00 »
I've always had a tough time getting the lube just right / positioning ect to get my thick IMSTO Cherry profile PBT caps working on my filco MJ2 TKL. I read that sanding the inside can do the trick. What kind of sandpaper? Does sanding the inside front change the outside look / feel of the key caps in any way? I don't care about resale. Could I use a nail file? Which type of sandpaper? Any advice whatsoever would really help. I just want to make sure there are 0 drawbacks - assuming I'll never sell them. Thanks!
Offline phoenix1234
Re: Thick PBT Costar Stabilizer Problems
« Reply #1 on: Wed, 03 June 2015, 03:05:25 »
Don't modify the keycap, modify the Costar stabilizers wire instead.
I like linear switches
Offline Keytrun
« Reply #2 on: Wed, 03 June 2015, 03:16:35 »
It seems like it would be a lot easier to sand the inside of a keycap than properly bend a wire. Right? There's no drawback to sanding it is there? Which part of the inside needs to be sanded?
Offline phoenix1234
« Reply #3 on: Wed, 03 June 2015, 03:30:24 »
If you prefer sanding the keycap, the part should be sanded is the one touch the Costar stabilizer wire.
Offline Keytrun
« Reply #4 on: Wed, 03 June 2015, 03:44:10 »
How would you go about doing the wire? Can you answer any of my other questions about specifics?
Offline phoenix1234
« Reply #5 on: Wed, 03 June 2015, 06:23:38 »
It depends, in my opinion, bending the wire is cheaper and easier. In my case, I manage to bend the wire in order to avoid the bottom keycap hit the Costar stabilizer wire. Imsto PBT is just a small grinding, it even happens more obviously with Leopold PBT keycap.
Sanding will make the keycap lighter and it may reduce the value of keycap even it only happened at the bottom. It is up to you. If you don't mind, you can sand it.
If you prefer sanding the keycap, the part should be sanded is the one touch the Costar stabilizer wire. You must figure it by yourself by pressing the keycap to the bottom until it touches the wire. It is where you should sand it. You can use a small jewelry file in order to sand the keycap, a nail file could be ok but it would be very hard to use.
Offline Keytrun
« Reply #6 on: Wed, 03 June 2015, 07:39:17 »
How would you even go about bending the wire? I tried using an exaxto knife and took some of that bottom area out only to still have the same provlem.
« Reply #7 on: Wed, 03 June 2015, 09:23:34 »
I've had 2 of the thick pbt sets so far..
Both used on my costar stabs,  no conflict..
Could you put up a ruler to the inside and outside of the Cap-in-question..  also the stem.. check if the stem is maybe pushed forwards/backwards
It might be the stabilizer side that's offset and not the cap..
Offline Keytrun
« Reply #8 on: Wed, 03 June 2015, 09:46:15 »
How do you mean the stabilizer side and not the cap? It's the cap that is getting hung up on the bar I'm pretty sure. It's really hard to tell. This is a pretty well documented issue with thick PBT and costar. It's mainly my left shift that's really bad.
« Reply #9 on: Wed, 03 June 2015, 10:06:11 »
I haven't had the issue with 2 separate thick pbt sets, tried on several wire stabilizer boards
So, i was just wondering if it maybe it was the stabilizer side that is slightly off.
Offline Keytrun
« Reply #10 on: Wed, 03 June 2015, 10:25:36 »
Can you be more specific about what you mean in regards to the stabilizer side being off? Things I can check for what I can do? What happens is is that it gets to the bottom and it sits and it's hard to get back up. It's mushy and such and doesn't consistently pop all the way back out.
« Reply #11 on: Wed, 03 June 2015, 10:36:41 »
hahaha, do the ruler thing..   or a small piece of straight edge..  dark colored paper even, as long as it's a factory edge.
you only need to test   Either the cap,  or the stabilizer..
Because if it's not one,  it's the other.
Offline Keytrun
« Reply #12 on: Wed, 03 June 2015, 10:40:39 »
The stabilizers are brand new from WASD.
http://imgur.com/a/ln1nW Is what I'm looking at.
« Last Edit: Wed, 03 June 2015, 10:51:00 by Keytrun »
« Reply #13 on: Wed, 03 June 2015, 11:49:29 »
The ones in those pictures are not the imsto PBTs..
I don't know if these come from the same maker.. \
it has nothing to do with the wear level of te WASD stabilizers.
It has to do with the Steel punchout they go into.
If that's off even by half a millimeter, it could be more susceptible to contact the caps.
Offline Keytrun
« Reply #14 on: Wed, 03 June 2015, 13:29:13 »
I just got home with some sand paper. Sanded the inside of the key and everything seems to be working. I'll put the rest of the keyboard together later.
« Reply #15 on: Wed, 03 June 2015, 14:12:34 »
are these the "ducky"  caps  (round edge),  or the square edged imsto ones.
Offline Keytrun
« Reply #16 on: Wed, 03 June 2015, 17:24:48 »
Square IMSTO
Offline lucidinertia
« Reply #17 on: Sun, 20 November 2016, 10:00:12 »
I know this is an old thread necro, but I found a solution here in the differing opinions that worked very well.
I bought thick PBT keys, NPKC brand, that had binding issues on backspace, enter, shift ... the usual stabilized keys.  I ended up finding a solution by using a rat-tail file and filing down the front inside of the keycap.  It took a few tries to get it right, but now every key is buttery smooth.
Hopefully this helps someone out.  I would not recommend bending the stabilizing bar as that would not help the binding issue.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #18 on: Mon, 21 November 2016, 20:59:59 »
Here I found the old threat that describe the issue:
https://geekhack.org/index.php?topic=31861.msg827711#msg827711
and
https://geekhack.org/index.php?topic=31861.msg836990#msg836990
But yes sanding down the front lip will help it.  :)
