Author Topic: Pinkies and touch typing  (Read 12228 times)
Offline bcredbottle
« on: Wed, 03 June 2015, 07:18:41 »
I'm learning touch typing. On the one hand, using pinkies (for P and Q) keeps your fingers on the home row. On the other, it's a huge reach, and it is way less work to just use the ring finger for those keys. Does anyone here touch type without pinkies?
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
Re: Pinkies and touch typing
« Reply #1 on: Wed, 03 June 2015, 07:22:30 »
Pinkies all day everyday. You have to spread the keyboard love throughout all the fingers.  :-*
Offline nmur
  • ಠ_ಠ
« Reply #2 on: Wed, 03 June 2015, 07:27:16 »
I think it's pretty common to do that, even more so if you're placing your wrists on a wrist pad.
A while ago, I forced myself to hover my hands as I type rather than letting them sit on a rest. As part of that, I started using my pinkies. I've found that I don't need to angle my wrist as much as I used to when I would use my ring finger.
« Reply #3 on: Wed, 03 June 2015, 08:56:49 »
Yes it is commonly taught to use the pinky for those keys HOWEVER
those guys are n00bers,, and they're WRONG..
use   RING -finger for  -Q-  and  -P-
It is faster, and it does not get in the way of common wrist rolls..
Offline mstechfreak
« Reply #4 on: Thu, 04 June 2015, 03:19:46 »
I use pinkies as well. :-) I learned to touch type in http://www.typingstudy.com . I think it was very very useful.
Offline bcredbottle
« Reply #5 on: Thu, 04 June 2015, 06:33:08 »
I think the pinkies feel like such a reach because I have DSA caps...
« Reply #6 on: Thu, 04 June 2015, 06:43:41 »
Pinky is good for  -a- -z- -:-  -.-   l-r-shift,  enter, /
Ring is good for   -q- -p- backspace -\-
Offline Oobly
« Reply #7 on: Thu, 04 June 2015, 07:07:53 »
I tend to use mine only for Shift, \, Enter and Ctrl. But I never learnt "proper" touch-typing technique, so... Not an expert on touch typing ;)
ohmagerd... change 'em. Cherry profile (for steeply angled boards) and sculptured SA profile (for closer to flat boards) are awesome. I don't mind the "flat" aspect of DSA (in fact I really enjoy typing on my Penumbra set with all Row 3 alphas), but somehow the small tops combined with the flatness trips me up.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
