Author Topic: Which current FPS...  (Read 4258 times)
« on: Sun, 14 June 2015, 15:02:34 »
Is like  Halo..
I just want to play something like Halo..  but on PC..
The regular halo still works, but there's no one playing..
Offline paicrai
  • mindblank
Re: Which current FPS...
« Reply #1 on: Sun, 14 June 2015, 15:33:28 »
Is like  Halo..
well there are a lot of people still playing everything after the first ones but theyre not on PC
if you want the first one with lots of people its on XBOne in the MCC
but nothing on PC i can think of that isnt just Halo or Halo 2
THE FEMINIST ILLUMINATI
« Reply #2 on: Sun, 14 June 2015, 15:37:04 »
Is like  Halo..
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #3 on: Sun, 14 June 2015, 15:39:00 »
Step 1. There are better fps, so stop playing halo. You hussy.
Offline paicrai
  • mindblank
« Reply #4 on: Sun, 14 June 2015, 16:06:46 »
Is like  Halo..
*smooch*
Offline lolpes
« Reply #5 on: Sun, 14 June 2015, 16:06:58 »
Well you can play team fortress 2 :)))
« Reply #6 on: Sun, 14 June 2015, 19:27:36 »
Basically,
I'm looking for something fast, -solo-able- and arena like..
  • Live long and prosper
« Reply #7 on: Sun, 14 June 2015, 20:05:21 »
Titanfall
tp thread is tp thread
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #8 on: Sun, 14 June 2015, 20:42:45 »
Offline oledome
  • not batman
« Reply #9 on: Mon, 15 June 2015, 05:03:38 »
Basically,
Serious Sam.
Offline baldgye
  • Will Smith Disciple
« Reply #10 on: Mon, 15 June 2015, 10:06:47 »
Quake.
Halo is like Quake, but not as good. So Quake.
« Reply #11 on: Mon, 15 June 2015, 10:08:44 »
Basically,
Serious Sam.
Is there still a healthy player base on serious sam ?
Offline pr0ximity
« Reply #12 on: Mon, 15 June 2015, 20:00:24 »
Basically,
http://www.quakelive.com
Honestly every other multiplayer FPS is ****. If everyone just played Quake III the world would be a much better place.
1v1 Quake is the chess/go of the FPS world:
(start at 4:00 if you don't want the backstory)
« Last Edit: Mon, 15 June 2015, 20:02:02 by pr0ximity »
« Reply #13 on: Fri, 19 June 2015, 15:39:19 »
Offline Ghibli
« Reply #14 on: Tue, 23 June 2015, 01:15:10 »
CS GO, join the club.
Offline theryaner
« Reply #15 on: Fri, 26 June 2015, 06:18:17 »
CS:GO for sure!
Offline Muffin860
« Reply #16 on: Fri, 26 June 2015, 10:03:13 »
While CS:GO is fun, it's nothing like halo.
IBM Model M
« Reply #17 on: Thu, 02 July 2015, 13:07:30 »
Halo is like Freeze tag,  a continuous string of WIN
CS_Go is like, duck duck go,   you do 1 walk around, and 1 run, and reset.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #18 on: Thu, 02 July 2015, 14:00:41 »
Planetside 2!
Join Emerald TR!
