Author Topic: Any Sub 3MS Input Lag Monitors Out There?  (Read 2186 times)
Offline Ghibli
« on: Tue, 23 June 2015, 15:38:48 »
144Hz + (signal processing + pixel response) =< 3ms Link source  ;D
Offline Latin00032
Re: Any Sub 3MS Input Lag Monitors Out There?
« Reply #3 on: Tue, 23 June 2015, 20:09:07 »
You might have to use g-sync or freesync. And that's only for PCs.
Let me find a website that I think shows this info.
Offline Latin00032
« Reply #4 on: Tue, 23 June 2015, 20:25:26 »
I looked into it.
You might be able to get close to 3.5ms if you use a good g-sync monitor and nvidia card. It might be closer to 4ms in reality.
But, I actually think it would be better using a crt to get low input lag. It would have to be an old VGA signal. It's harder to get this setup considering crt is mostly phased out.
Offline Ghibli
« Reply #6 on: Tue, 23 June 2015, 22:16:05 »
Better off going w/a 144Hz rate 3MS monitor then you are w/a CRT.
so it's not  < = 3   ...  LOL
He can add. 3ms:
However, their measurement method isn't entirely accurate.
4MS on http://www.prad.de/new/monitore/test/2015/test-acer-xb270hubprz-teil10.html
Now we wait for more reviews...
« Last Edit: Tue, 23 June 2015, 22:19:40 by Ghibli »
« Reply #7 on: Tue, 23 June 2015, 22:42:18 »
He can add. 3ms:
Average,  So it's not like that all the time..
And are they measuring in the center of the screen?  what about the bottom ?
Offline Ghibli
« Reply #8 on: Sun, 19 July 2015, 10:03:00 »
Winner:
Cheaper as well.
