Author Topic: Super Stealth Trick  (Read 2427 times)
Super Stealth Trick
« on: Sun, 05 July 2015, 11:18:21 »
So like most of ya'll,  I got a bazillion computer fans..
I've always h8ed ballbearing fans, because they make this bzzzzzz noise.
So today,  I took one of them,  and just Popped off the "retainer clip" (the white ring/ could be metal in some fans), oiled it up.  and ran it WITHOUT the clip..   No more bzzzzz noise..
It would seem that without the retainer putting pressure on the bearing, the fan essentially turns into a "half sleeve bearing fan"..
I've tested this on multiple ball bearing fans of all sizes..  the trick works on all of them
So,  This is good news for all ya'll looking for silent fans..
Offline exitfire401
  • The Force is Re/\l
Re: Super Stealth Trick
« Reply #1 on: Sun, 05 July 2015, 11:19:38 »
That's actually a neat tip. Thanks. I'll keep that one in mind.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #2 on: Sun, 05 July 2015, 11:21:46 »
And they said tp4 was useless. YOU WHERE ALL WRONG.
Offline trizkut
« Reply #4 on: Sun, 05 July 2015, 11:41:16 »
savior of the vitamix is now savior of the case fan
Offline heedpantsnow
  • Old enough to know better
« Reply #5 on: Sun, 05 July 2015, 12:05:25 »
What if the vitamix is really just a case fan? ( ͡° ͜ʖ ͡°)( ͠° ͟ʖ ͡°)ᕦ( ͡° ͜ʖ ͡°)ᕤ( ͡~ ͜ʖ ͡°)
I'm back.
Offline paicrai
  • mindblank
« Reply #6 on: Sun, 05 July 2015, 17:05:27 »
buzzfeed get on it
THE FEMINIST ILLUMINATI
« Reply #7 on: Mon, 06 July 2015, 06:12:25 »
So what does the retainer clip actually retain?
And is it likely to fly off at high speed if it is no longer being retained?
Offline fanpeople
« Reply #8 on: Mon, 06 July 2015, 06:23:28 »
Don't be silly, you can always replace damaged hardware but silence is bliss. Just remember to get the bulk pack of GPUs next time your down at the local MSI wholesaler.
« Reply #9 on: Mon, 06 July 2015, 06:25:19 »
The retainer holds the spinning part against the hub.
For example, most new laptop fans also don't have this retainer..
so, the retainer isn't necessary for most fans,   the reason they include it is so the fan blade doesn't fall out, and so the customer doesn't have to put it back and put more oil in.
I've tested all orientations,   For anything upto 3000 rpm, it should be fine..
However,  if you got a really HEAVY blade, super high rpm fan,   obviously you can't put that with the blade side down because it may shoot out.
But side mount is good for up to 3000 rpm, maybe even more depending on the fan.
for small fans, orientation doesn't matter, it's gonna be good regardless, the blade isn't heavy enough to fall out.
I don't have any 5000 rpm fans to test right now, because the only 5000 ones I have are in the server, and I'm not pulling one of those.. LOL, they're loud regardless of mods.
« Reply #10 on: Mon, 06 July 2015, 06:34:41 »
I don't have a fan handy to look at; does the force of the air from the fan pull it away from the hub or push it towards it?
I'm back.
Offline neverused
« Reply #11 on: Mon, 06 July 2015, 08:28:15 »
By far, the most well written and informative tp post of all time.
