Author Topic: Advice needed on a good free DVD ripper/converter  (Read 3085 times)
Offline JackMills
« on: Mon, 06 July 2015, 04:25:47 »
I am looking for a good free DVD ripper/converter.
The purpose is to rip and convert the DVD's for my son so that they can be played on the galaxy tab 2 10.1 tablet during road trips.
Ideally I would like to keep only one audio track and have the movie start at the first chapter, so no menus or features.
And even more ideally it would be a portable application, so no installation needed, just unzip and execute.
Any suggestions?
Offline fknraiden
Re: Advice needed on a good free DVD ripper/converter
« Reply #1 on: Mon, 06 July 2015, 04:29:15 »
try out imgburn
Offline cakewizard
  • "**** me, that cow's got udders!"
« Reply #2 on: Mon, 06 July 2015, 04:52:08 »
MakeMKV
Nothing comes close for DVD ripping.
Cherry G80-3000, Apple Standard Keyboard
OS X, Debian + i3wm. GNU/Linux, pronounced "whatevs".
« Reply #3 on: Mon, 06 July 2015, 10:38:41 »
I'll have to check everything when I get home, but I used DVDShrink (does a straight rip of the DVD) and Handbrake for the conversion.  I forget the name of the software I use to unlock the DVD so I can rip it.
Offline wlhlm
« Reply #4 on: Mon, 06 July 2015, 10:40:52 »
I can recommend Handbrake for ripping and conversion.
Offline JackMills
« Reply #5 on: Tue, 07 July 2015, 02:36:10 »
I gave MakeMKV a try and it does a good job. It is fast and gives a nice overview.
MX Player can play the format, I only needed a different codec for the AC3 audio.
Maybe I should convert the mkv to another filetype to compress them some more, but at the moment I am happy with the results.
As I get Handbrake recommended a few times, I will be giving that a try as well.
Thank you guys for the responses, it helped me a lot.
« Reply #6 on: Tue, 07 July 2015, 12:55:11 »
Um...  try utorrent..  stuff's already converted, and easily playable..  hahahahahahah
Offline jackmercer
« Reply #7 on: Tue, 21 July 2015, 08:22:13 »
Try Daemon Tools , it's really good !
Offline JackMills
« Reply #8 on: Tue, 11 August 2015, 01:35:05 »
I have used MakeMKV to rip, as said earlier and then I converted the mkv to mp4 using handbrake. I was really pleased with the results, and my son too, as I didn't hear him the entire 900km drive because he could see his favorite movies on the tablet. And I didn't have to change DVDs like I used to do with the portable player.
So thank you guys for the recommendations, they helped me a lot.
