Author Topic: Try Squeegee post Showering.  (Read 2042 times)
« on: Mon, 20 July 2015, 21:08:52 »
So, I just figured this out.. Also thoroughly tested it.
25% less water by weight,  testing 2 towels.
If Squeegee after a shower..  it's like on a car window, but on yourself, using your hands..
I've found that it dramatically reduces the hydro-load of the towel..
Reduced drying time, means less bacterial buildup on the towel..
technique Also works on hair.
Offline Invaderevan
Re: Try Squeegee post Showering.
« Reply #1 on: Mon, 20 July 2015, 21:11:06 »
I've been doing this for a while, I think i read about it somewhere. works like a charm!
WTTF Ribbits, Ashen V2 MX, Bronins
« Reply #2 on: Mon, 20 July 2015, 21:13:16 »
I had probably mentioned it before, but today is the first time I actually  un-lazied.. and weighted two identical new towels.
Also, I guess it's cuz I bought 2 identical new towels..
« Reply #3 on: Mon, 20 July 2015, 21:20:54 »
So you showered twice just to test your hypothesis?
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #4 on: Mon, 20 July 2015, 21:27:49 »
tp4 just so fresh n' so clean.
Offline Axollott
« Reply #5 on: Mon, 20 July 2015, 21:34:21 »
I started doing this while living in Cancun. The place is so hot that if you go to the beach, you can forget to bring a towel. Just run your hands over your skin and let the sun do the rest. In less than 5 mins you are dry. I started doing the same thing after showering and just kept doing it till present day. Makes drying way quicker.
« Reply #6 on: Mon, 20 July 2015, 21:47:42 »
No, I just re-wet after I weighted the first towel.
Offline njbair
    • nickbair.net
« Reply #7 on: Mon, 20 July 2015, 21:48:40 »
Been doing this since I was a teenager. I don't bother squeegeeing my legs, though. I just sort of kick them to fling the water off. Works pretty well.
The other thing I do, to save time, is I only mostly dry off when getting out of the shower. Then I wrap my towel around my waist and shave. Usually I air dry the rest of the way while I'm shaving.
My boards:
