Author Topic: Ergodox problem (teensy)  (Read 2081 times)
Offline Wayward
« on: Tue, 28 July 2015, 15:36:09 »
Hi guys, I'm new here. I'll try to write in a good english (I'm french  :thumb:)
So, I have bought an Ergodox at Massdrop (https://www.massdrop.com/buy/ergodox) and built it by myself. The soldering is ok.
I follow the assembly instructions (https://www.massdrop.com/ext/ergodox/assembly.php) but I'm stuck at Step 17.
I connect the USB, and the teensy blinks every 2 seconds. But when I push the teensy reset button, the light goes off and nothing happens.
« A Reboot OK message should flash on the Teensy Loader » but nothing happens.
I don't know how to solve this problem. If there is somenone who could help me, he'll be nice.
It's my last resort to make it run  :(
Thanks  :thumb:
Offline Wayward
Re: Ergodox problem (teensy)
« Reply #1 on: Wed, 29 July 2015, 10:28:12 »
Bump.
« Reply #2 on: Fri, 31 July 2015, 17:18:54 »
did you follow the flash instructions exactly?
you need to flash the .eep after the regular firmware.
