Author Topic: That der new Intel 3D memory.  (Read 4122 times)
« on: Tue, 28 July 2015, 16:45:49 »
http://www.engadget.com/2015/07/28/intel-3d-memory-1000-times-faster/
1000x faster
10x more durable
I guess we shouldn't buy any new SSDs this year, and just wait it out....
I already got too many SSDs.
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: That der new Intel 3D memory.
« Reply #1 on: Tue, 28 July 2015, 16:47:34 »
You should sell all your SSDs to spend the $1000 you are going to need to buy a 65gb version of this new memory if you really want it this year.
Buy SSDs now. Wait three years for this to be reasonably priced.
« Reply #2 on: Tue, 28 July 2015, 16:52:40 »
When will we get 1000x more dense for more TB's/$?
« Reply #3 on: Tue, 28 July 2015, 16:54:38 »
maybe never,  because it's possible the internet will get fast enough that no one needs local storage.
Offline trizkut
« Reply #4 on: Tue, 28 July 2015, 16:55:13 »
who will be able to afford all the bandwidth though?  :))  data cap woes are real.
« Reply #5 on: Tue, 28 July 2015, 16:57:15 »
Not to mention a vast majority of the USA still doesn't have true 'broadband' internet.
« Reply #6 on: Tue, 28 July 2015, 17:01:40 »
Does anyone understand the difference between the Samsung 3D nand vs the Intel?
  • Live long and prosper
« Reply #7 on: Tue, 28 July 2015, 17:22:09 »
one is samsung... the other is intel
tp thread is tp thread
« Reply #8 on: Tue, 28 July 2015, 18:17:30 »
Gah.. it's so obvious now..  How haz I not seens it befor
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #9 on: Tue, 28 July 2015, 19:30:37 »
I am still wondering how far off we are from light based computing and storage.
« Reply #10 on: Tue, 28 July 2015, 19:34:15 »
Well,  the 3d stacked cells work exactly like how Light-based crystal storage would work, except you don't need to shine a laser through it..
basically  we won't get to LIGHT,  until we need HUGE amounts of storage..
You can only make these stacks so big, before latency becomes a huge problem..
So with a "light crystal", the advantage would be the possibility for a much larger block..
We'd need to get processor speeds up to that sky-net level before it'd be necessary though..
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #11 on: Thu, 30 July 2015, 13:50:54 »
This is going to be hybrid, will come in DDR4 compatible DIMM form factor to have one unified pool instead of dram+nand storage. This will hopefully be available for the debut of Skylake E. Coupled with the next gen HBM based nvidia gpu on pci-e 4.0... going to be killer.
« Reply #12 on: Thu, 30 July 2015, 13:52:22 »
Tp keep the nerd **** out of off topic pls
« Reply #13 on: Thu, 30 July 2015, 14:16:01 »
I'm pretty sure HBM is faster and of similar technology.
not sure why they wouldn't just put it into the next CPU
and Charge $800 for the base model
I would totally still pay $800 for the CPU with ~8-16GB of HBM
I think even $1000, is reasonable.
like,  HBM is 200-1000Gigabyte/s       vs ddr3, 4  which is around 50 gb/s on 4 channels tops
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #14 on: Thu, 30 July 2015, 21:22:18 »
I'm actually at this point right now with my fiber optic internet.
I used to keep all my steam games on local drive but now they literally download in minutes so it doesn't matter to delete and download games but i keep wanting bigger SSD's just because lol
GON NerD TKL DTA Edition
« Reply #15 on: Thu, 30 July 2015, 21:24:57 »
I am ashamed that I have 3x 1TB ssds ...  seriously, they're not even half full ...
Yes, I have a computer problem
Offline njbair
    • nickbair.net
« Reply #16 on: Thu, 30 July 2015, 21:47:41 »
Wait, so your memory and storage will be the same thing? That's awesome.
I remember as a kid loading Doom into ramdisk. It loaded so fast. I thought SSD's were finally bringing us to that point, but it looks like this might close the gap even further.
My boards:
Offline Oobly
« Reply #17 on: Mon, 03 August 2015, 09:25:31 »
I wonder how they're going to cool it... maybe micro pipes with liquid? Traditional flat chips expose enough surface for traditional cooling, but a 3D chip exposes very little surface of each layer.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #18 on: Mon, 03 August 2015, 09:39:58 »
They're 3D chips, but those layers are touching..  so flat cool will be fine..
ALTHOUGH.....  it'd be kinda cool if they NEEED watercooling for Overclocking like back in the DDR 1 days.
hahahahahah
Offline Oobly
« Reply #19 on: Mon, 03 August 2015, 10:01:07 »
hahahahahah
Silica has a VERY poor thermal transfer coefficient (thermally grown silica TC = 1.3 W/mK)... So the heat won't transfer THROUGH the layers. It's gonna need some form of heat transfer mechanism to cool the inner layers.
For comparison, aluminium has a TC of 205 W/mK, copper = 401.
Even my single layer DDR3 needs heat spreaders.
The other option is to run it really slow... but that kind of defeats the purpose of the design.
« Reply #20 on: Mon, 03 August 2015, 10:02:18 »
hahahahahah
I'm 99% sure modern ddr3 doesn't need heatspreaders..  and that it's all fo-sho..
Offline baldgye
  • Will Smith Disciple
« Reply #21 on: Mon, 03 August 2015, 10:28:27 »
Can't be that far, intel's Light Peek tech was being worked on being internalised from my understanding (before it launched on macbooks etc)
Offline Oobly
« Reply #22 on: Tue, 04 August 2015, 04:37:07 »
An optical data interconnect is not related to optical transistor or logic gates, so it doesn't really mean we're any closer to optical processing or storage.
And even if current DDR3 chips don't need heat spreaders they still get hot and need cooling and won't last that long if covered by thermal insulation, especially if that insulation is also producing heat (each layer will both insulate and generate heat). So, I wonder how they are cooling the layers.
