Author Topic: Chinese cars..  (Read 3222 times)
Chinese cars..
« on: Sat, 01 August 2015, 21:13:18 »
So apparently... they got like the same car in china yea, like Lexus?  but instead of say aluminum parts,  they'll swap it out in the China version with steel, "cheaper"
for example a double wishbone suspension
Thank god We have magnets..
Careful buying cars in China folks..
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
Re: Chinese cars..
« Reply #1 on: Sat, 01 August 2015, 21:42:23 »
I went to China a couple years back and i remember seeing off-brand cars made to look like popular selling cars like the Mazda 3 and stuff.
I'll try to find some photo's
GON NerD TKL DTA Edition
Re: Chinese cars..
« Reply #2 on: Sat, 01 August 2015, 21:43:49 »
well if they used different parts for THOSE cars..  that's fine..
but let's say i'm trying to buy a lexus,   and instead of aluminum suspensions I got steel..
Aluminum suspensions probably cost 5x as much to make as steel..
So.. Yea I'd be angry.
Offline KnivesM
Re: Chinese cars..
« Reply #3 on: Sun, 02 August 2015, 00:26:30 »
First thing that came to mind when I saw this thread
https://youtu.be/v-mW1gwQXwk
Angry Chinese man hires 3 guys to destroy his Maserati in front of auto show
Others
Offline heedpantsnow
  • Old enough to know better
Re: Chinese cars..
« Reply #4 on: Sun, 02 August 2015, 00:28:43 »
Not to mention you paid 60% more for some of those brands due to import taxes. And then they switch out the parts. Pfffft.
I'm back.
Offline C5Allroad
  • Formerly HUNTERANGEL121
Re: Chinese cars..
« Reply #5 on: Sun, 02 August 2015, 02:47:53 »
Double wishbone is better than strut.
As the suspension compresses, it doesn't add anymore negative camber.
Re: Chinese cars..
« Reply #6 on: Sun, 02 August 2015, 05:46:36 »
it depends on the car.. for sports cars, you don't have a choice because the height
Offline C5Allroad
Re: Chinese cars..
« Reply #7 on: Sun, 02 August 2015, 13:26:38 »
Evos have multilink rear and McPherson strut front
Sti McPherson front double wishbone rear
S2000 double wishbone on all four corners
Miata double wishbone
Saturn sky double wishbone
M3 front McPherson, rear multilink.
Height doesn't have much say in it
Re: Chinese cars..
« Reply #8 on: Sun, 02 August 2015, 13:36:10 »
Many combinations are possible
But the advantage of double wish,  is lower height..
Offline C5Allroad
Re: Chinese cars..
« Reply #9 on: Sun, 02 August 2015, 13:40:43 »
Height has nothing to do with it. E46 m3 is low, front McPherson strut.
McPherson struts, when a corner is being compressed, the inherent design adds more negative camber, this could be bad, or good depending on the track.
Double wishbone, is more expensive to build, has more parts, but on bumps, roll, and when a corner is compressed, camber doesn't change.
Offline jerue
  • (Whenever that happens :P)
Re: Chinese cars..
« Reply #10 on: Sun, 02 August 2015, 13:41:11 »
Top Gear did a whole bit about this back in Series 18.
The naming was what always got me. BMW X5? How could that be? It's clearly a Shuanghuan S-CEO HBJ6474Y!
But then there's this...which is a little sad I think.
Re: Chinese cars..
« Reply #11 on: Sun, 02 August 2015, 14:09:34 »
but.. mac can't get AS LOW..
Offline C5Allroad
Re: Chinese cars..
« Reply #12 on: Sun, 02 August 2015, 14:25:22 »
You lower a car an x amount, you're going to have to change the roll center. Unless you're talking about stance nation hella flush type stuff.
Double quote on phone...
Re: Chinese cars..
« Reply #13 on: Sun, 02 August 2015, 15:11:30 »
Geely bought the Swedish Volvo cars a couple of years ago, and I think not only for the brand but also for the engineers.
I still haven't heard if quality of Volvo has gone down and/or if quality of Geely has gone up. It takes several years to develop a new car model.
Just because a brand is Chinese does not mean that the quality is "Chinese quality".
Lots of Asian companies have bought up parts or merged with companies in the west. The brand could be Asian, but the engineers could be sitting somewhere in the West with the manufacturing in China ... just like Western brands.
Re: Chinese cars..
« Reply #14 on: Sun, 02 August 2015, 15:25:35 »
It comes down to cost..   but OVERALL..  i think we're on the brink of China making a serious play for the car market...
