Author Topic: Pretty good Chip here..  (Read 3202 times)
« on: Tue, 11 August 2015, 12:57:09 »
Since this build isn't for me,  I'm not going to Delid this..
But I honestly think (if I did) it might be capable of 4.9 maybe 5 @ 1.35v
It has passed 16 hours -Aida.stressFPU-  @  4.8ghz,  1.3 volt
Offline evolveS
  • ಠ_ಠ
Re: Pretty good Chip here..
« Reply #1 on: Tue, 11 August 2015, 13:07:21 »
A picture of your computer monitor? In 2015?
y
"money comes and goes, but doubleshots are forever"
-a petty thief
Offline beehatch
  • baehatch
« Reply #2 on: Tue, 11 August 2015, 13:09:23 »
y
because he can
« Reply #3 on: Tue, 11 August 2015, 13:11:23 »
y
because he can
Because he's tp. Tp does as tp likes
« Reply #4 on: Tue, 11 August 2015, 13:15:21 »
y
LOL..
Nothing is installed,
Basically, I'm familiar enuff with overclocking, that I can push the system to 4.4ghz stable before installing the OS..
Then I install the OS,  and start FULL Overclocking right away..
No network drivers, no video drivers, nothing. no internets.
Offline trees
  • I like bagels.
« Reply #5 on: Tue, 11 August 2015, 13:30:06 »
I can figure out overclocking. I have a liquid cooled 4690K and im just lost. I tried clock it to 4.4 and it seemed unstable (crashing in CS:GO)
B.Face HHKB - B.mini - Black/Purple Custom
« Reply #6 on: Tue, 11 August 2015, 14:45:47 »
which motherboard are you using.
Offline trees
  • I like bagels.
« Reply #7 on: Tue, 11 August 2015, 21:20:16 »
I have a MSI Z97-G55 SLI
« Reply #8 on: Wed, 12 August 2015, 00:01:28 »
Here's what you need to do.
read THIS guide here _http://www.overclock.net/t/1490835/the-gigabyte-z97x-overclocking-guide_
Remember, nearly ALL of those values have to be set manually to achieve a high overclock.
The guide is for a gigabyte bios,  SO....
Not all of the settings will be under the same name in the MSI bios,  but post about any you don't understand,  And  I will decipher it for you..
But overall, you can't just set the multiplier and expect it to work.
Even if it works a bit,  you may be OVERvolting,  for example, most AUTO - Overclocking done by the motherboard without user input tends to Overvolt by 0.2volts.
Which means if you try an auto overclock of 4.8ghz,  you might be pumping 1.4-1.45v into the chip
That is very bad,  and you will never be able to stability test it, because it'd run way too hot to pass testing,
Offline trees
  • I like bagels.
« Reply #9 on: Wed, 12 August 2015, 00:05:16 »
I hadnt seen that guide before, so ill definitely take a look!
The weirdest thing for me was, i would run stress tests and things generally looked fine, but when i would play like CS:GO i would get random craashes, that doesnt happen with it turned off.
« Reply #10 on: Wed, 12 August 2015, 00:50:23 »
You need to stress test for more than a few hours.. it has to pass overnight.
« Reply #11 on: Thu, 13 August 2015, 19:50:53 »
Finalized the Overclock today..
Tp4 certified stable @  4800mhz core / 4500mhz uncore
____________________1.304v_________1.208v
Such a shame this chip won't be delidded...     I'm almost certain it's a 49er.
Offline Jokrik
« Reply #12 on: Thu, 13 August 2015, 21:58:20 »
Delid it! /evil
I love my delided 4770k, but than I moved to 6 cores
« Reply #13 on: Thu, 13 August 2015, 22:03:38 »
Delid it! /evil
I'm not going to 6core any time soon
I mean.. I have my 4cpu 24core server..   but for a desktop.. i won't need more than 4.
