Author Topic: A little help please?  (Read 4526 times)
Offline phosphor
« on: Wed, 12 August 2015, 12:51:27 »
I've been looking for weeks now for my first mechanical keyboard and i know i'm being picky but i cant seem to find anything close. I was hoping someone might have a suggestion. Im looking for something without backlight leds, strange angles and odd extra buttons or knobs. i just want a basic full or tenkeyless that doesnt cost an arm and a leg. Hopefully a cherry mx brown. anybody have any suggestions?
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
Re: A little help please?
« Reply #1 on: Wed, 12 August 2015, 12:54:56 »
You could get a WASD V2 with MX Browns. It is about as non-bling as you can get.
Offline aicrono
    • A Touching Experience
« Reply #2 on: Wed, 12 August 2015, 12:56:35 »
You're best bet is trying to pick up a used Filco Majestouch 2 on eBay. I got my TKL Majestouch 2 Ninja w/ MX Blacks for $70 off of eBay, so I'm assuming similar deals are still out there.
If you are strictly buying new, this will probably serve you well: http://www.newegg.com/Product/Product.aspx?Item=N82E16823201083
I have had the V1 of this board for years and its still clacking along.
Offline merlin64
    • MechMerlin
« Reply #3 on: Wed, 12 August 2015, 13:30:50 »
I highly recommend a KUL ES87. Got lots of good reviews.
Offline Data
« Reply #4 on: Wed, 12 August 2015, 14:39:01 »
I came to say this, but it was already said.
« Reply #5 on: Wed, 12 August 2015, 14:40:07 »
Some suggestions:
- Coolermaster QFR
- Filco Majestouch
- Some of the Ducky models
- Kul ES87
- WASD V2
I really like Ducky boards and I own a Filco Majestouch. Love Filco.
« Reply #6 on: Wed, 12 August 2015, 14:41:08 »
Filco, KUL, or QuickFire Rapid. Or grab a Ducky, and leave the backlighting turned off.
Offline tigersharkdude
« Reply #7 on: Wed, 12 August 2015, 14:57:44 »
CM Storm - Quickfire Rapid. It's exactly what you asked for; very minimal, no extra keys, no knobs, no lighting, can be had in MX brown
Ive had mine for about 1.5 years and have no issue
Offline Defect
« Reply #8 on: Wed, 12 August 2015, 15:09:32 »
Like many have said,
KUL ES87, Filco, QFS, QFR.
You can find used QFRs for as low as $40 shipped, on average $60 shipped.
« Reply #9 on: Wed, 12 August 2015, 16:20:34 »
The issue with used QFRs has been 1 or 2 broken keys..
They're easy fixes  for many of Geekhackers,  but not all.
Offline saturnotaku
« Reply #10 on: Wed, 12 August 2015, 16:22:00 »
I second the recommendation for the WASD v2. It's about as no-nonsense as you can get and is extremely well made. It's available as a TKL or full-size in just about every Cherry MX switch you can get. You can customize the keycaps to say whatever you want, have them completely blank, or get the keyboard without any caps at all so you can add whatever set you want. It also has a set of hardware DIP switches to change the layout, including Dvorak, Colemak, Mac, Windows key disable, and more.
Offline KaminKevCrew
« Reply #11 on: Wed, 12 August 2015, 16:38:57 »
The WASD is definitely a good suggestion! Also, if you're okay with a glossy front, the Daskeyboard model S is a good one. I've heard they don't use Cherry any more, but my ultimate 4 w/browns certainly does, so I think they still use Cherry switches.
Offline clacktalk
  • circa 2015
« Reply #12 on: Wed, 12 August 2015, 16:41:13 »
any board without cherry stabilizers will guarantee you sadness and discomfort, so i guess pick whichever one already suggested that has them
diary of a clacktalk
radio_killah: too much frank
Offline phosphor
« Reply #13 on: Wed, 12 August 2015, 16:51:39 »
Wow. There's a lot of suggestions i haven't found yet (the KUL es87) and they look nice (seriously, the KUL and the WASD are tasty) they're all outside my budget. At most, i can swing $100 plus flat rate shipping so as nice as the WASD looks, it'll have to wait.  :(
Somehow i mist the Cooler Master Quickfire, and that's certainly an option, but does anyone have an opinion on the Max Keyboard Nighthawk?
And backlighting does raise the price, right?
Offline phosphor
« Reply #14 on: Wed, 12 August 2015, 16:55:59 »
Oh yeah, and i'm Linux only if that makes any difference.
« Reply #15 on: Wed, 12 August 2015, 16:57:42 »
But does anyone have an opinion on the Max Keyboard Nighthawk?
Thought you didn't want backlighting? And yes.
« Reply #16 on: Wed, 12 August 2015, 16:58:24 »
I'd stay away from brands other than the ones we've been recommending. There is a reason everyone is echoing the same comments. :)
Offline phosphor
« Reply #17 on: Wed, 12 August 2015, 17:17:41 »
I want to avoid backlit keyboards to keep the price low, but i'm not opposed to a white backlit if i can find one in my range.
Like i said, i'm being picky.
« Reply #18 on: Wed, 12 August 2015, 17:23:14 »
Mentioning your budget is helpful. A new member's perspective on things might be very different from a veteran member's.
You said you wanted a keyboard "that doesnt cost an arm and a leg." To some of us that have paid close to $1000 for a single keyboard and its accoutrements, a stock keyboard which costs $200 or less might meet your requirement. Some collectors have paid $2000 or more for rare specimens. Another new member said they had an "unlimited budget" for a gaming keyboard, which turned out to be about $300. It's simply a matter of perspective.
Offline saturnotaku
« Reply #19 on: Wed, 12 August 2015, 17:32:02 »
OP actually did mention it:
« Reply #20 on: Wed, 12 August 2015, 17:44:58 »
Just came across that post. I'm more into headphones, and the things you can get in that area, but I've been trying to get more into keyboards, and I've been realizing that you can spend about as much on a keyboard as you can on a headphone. Although I think headphones still take the cake for cost (if you include DACs/amps, etc.) Yeah, definitely excellent to have a budget.
For ~$100, I would go for something like the Rosewill posted above, OR go for a 60% board, since they are so much cheaper. If you could deal with all of the different layers, something like a Pok3r or poker 2 is pretty close to $100, or you could even just buy one in good condition, used. That would probably end up working just fine (again, if you can manage the different layers.)
« Reply #21 on: Wed, 12 August 2015, 20:49:21 »
If you can't really swing the cream of the cream, the CM Quickfire Rapid is probably the ideal choice.
- Plato
Offline Oobly
« Reply #22 on: Thu, 13 August 2015, 03:21:47 »
If you want new, the Quickfire Rapid is the best for under $100 or possibly a Ducky Zero. You could also get a WASD V2 barebones TKL (87-key), but then you have to find a keycap set for a fair price. That said, though, the stock keycaps on most boards are pretty rubbish and if you get a barebones you can put a really nice set on straight away and you're not paying for junk keycaps.
Second hand, you could get a Filco Majestouch 2 or similar.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #23 on: Thu, 13 August 2015, 03:37:51 »
I would probably go with one of these, were it me.
« Reply #24 on: Sun, 16 August 2015, 05:10:28 »
KeyCool used to be a fairly good option, with PBT keycaps standard.  But then they changed to Kailh switches or something, and I don't know if they are considered as great any more.
My older KeyCool with MX reds (white case, white PBT keycaps) is still going strong.
