Author Topic: Battery cases..  (Read 1482 times)
Battery cases..
« on: Tue, 18 August 2015, 01:40:46 »
So.. Like I never bought one of these..
Are they supposed to stay plugged into the phone?
Is it constantly trickle charging the phone's internal battery ? or is there a switch..
Offline raymogi
Re: Battery cases..
« Reply #1 on: Tue, 18 August 2015, 01:45:31 »
On/off switch. When you charge it with the case on, it will fill the phone's battery first, then the case.
Please feed my addiction.
Re: Battery cases..
« Reply #2 on: Tue, 18 August 2015, 01:48:06 »
do they all have an on off switch?
Offline raymogi
Re: Battery cases..
« Reply #3 on: Tue, 18 August 2015, 01:50:16 »
I believe most do. Even those I purchased 3 years ago have switch, so all the newer ones gotta have it too.
Offline baldgye
  • Will Smith Disciple
Re: Battery cases..
« Reply #4 on: Tue, 18 August 2015, 01:52:55 »
My otterbox battery case has an on/off switch and it's pretty new (few months old).
Re: Battery cases..
« Reply #5 on: Tue, 18 August 2015, 01:53:39 »
alrite, gotcha..  thanks
