Author Topic: Any tips to improve typing speed (wpm, wps)  (Read 3472 times)
Offline ANightOnCloudNine
« on: Sat, 26 September 2015, 23:25:38 »
My goal is to get 100 wpm, I used to be really good at tpying when I was like 8 but I got into consoles and came back, I used to be able to type 80 words per minute, now I type 50 words per minute which is embarrassing to me.
Online tp4tissue
Re: Any tips to improve typing speed (wpm, wps)
« Reply #1 on: Sun, 27 September 2015, 01:52:52 »
generally,   play 10fastfingers . com   register and play the advanced mode
the normal mode doesn't make you fast with less common words.
Once you get a bit faster,  if you want some indepth information,  read 'the guide'
https://geekhack.org/index.php?topic=67941.0
« Reply #2 on: Sun, 27 September 2015, 02:07:49 »
Thanks guy
Online tp4tissue
« Reply #3 on: Sun, 27 September 2015, 02:32:47 »
Thanks guy
Offline swimmingbird
  • keyset hoarder
« Reply #4 on: Tue, 29 September 2015, 09:57:13 »
Thanks guy
Started touch typing seriously back in February - where I was around 30wpm - now on keybr I usually get 90-110 wpm and about 85-95 on 10fastfingers and typeracer
Still not sure whether to make the switch to using my right thumb with the space bar like in your compendium....
Online tp4tissue
« Reply #5 on: Tue, 29 September 2015, 14:37:00 »
Um...  you don't have to switch to right thumb,  but it makes for superior key balance, and its not really as hard a switch as adjusting any other finger..   because you're probably not already using your right thumb on any other key.
For example, if suddenly I want to start using  my ring finger for " i ",  that would be a large switch because I'd be making a large shift in many words and rhythm..  to use it in a different way also means , you're actively remembering to cancel a predefined muscle reflex which will take time to disassociate.
Whereas the right thumb doesn't do anything, so it's unencumbered and free to adapt easily.
  • keyset hoarder
« Reply #6 on: Tue, 29 September 2015, 15:23:38 »
Tempted to give it a shot but it seems to mess with the muscle memory of my right hand when I do it
