Author Topic: Keyboard Sleeves/Bags  (Read 2371 times)
Offline slushi
« on: Fri, 09 October 2015, 16:21:58 »
Hello everyone!
First off I just want to say hi to the community. It seems like everyone is pretty helpful and kind. Excited to learn more and eventually contribute here!
Secondly, I was wondering if there was a good place to get a custom keyboard sleeve made. I have PM'd some folks on reddit but haven't gotten any response yet. I have my first custom coming (a b.mini from winkeyless) and was looking for a snug fit sleeve. From the dimensions it looks like I would need to size up to the TKL sleeves if I were to grab one from 1up. However, I'd rather not have my board sliding around in the sleeve and would prefer it to be a snug fit.
Anyone got any advice? I did some quick searching but didn't see too much. I apologize if there is already some resources out there for this.
Thanks in advance!
 HHKB Pro 2
Offline raymogi
Re: Keyboard Sleeves/Bags
« Reply #1 on: Fri, 09 October 2015, 16:55:11 »
1upkeyboards.com
Please feed my addiction.
« Reply #2 on: Fri, 09 October 2015, 17:08:53 »
I roll up my keyboards for travel using only the finest Ralph Lauren bath-towels..
Offline raymogi
« Reply #3 on: Fri, 09 October 2015, 17:13:27 »
Man I should consider that. I usually wrapped up fragile stuff with my used pyjamas.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #4 on: Fri, 09 October 2015, 17:13:37 »
If you're not using Frette towels, you are doing it wrong.
OP, check in the Artisan subforum. There are all kinds of talented geekhackers that make stuff by request. :)
Offline slushi
« Reply #5 on: Fri, 09 October 2015, 17:52:05 »
Will do, I am slowly browsing the artisan forums right now  :thumb:
 HHKB Pro 2
Offline KaminKevCrew
« Reply #6 on: Fri, 09 October 2015, 20:15:52 »
Yeah, the artisan thread is a good place to check. Also, if I recall, there was an Interest Check about some keyboard cases, so you might be able to PM him about it, and get one made for yourself.
Offline slushi
« Reply #7 on: Fri, 09 October 2015, 23:00:51 »
Thats super helpful! I'll look for that thread!
 HHKB Pro 2
Offline SamirD
« Reply #8 on: Sun, 11 October 2015, 12:35:38 »
If you want something a bit more rigid, look at musician keyboard cases.  Some of the smaller ones are quite nice.  I use one for my IBM M.
