Author Topic: You will never be as cool as this guy  (Read 5643 times)
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« on: Wed, 14 October 2015, 20:11:55 »
As this guy playing moonlight sonata on his pressure sensitive RealForce.
Offline jerue
  • (Whenever that happens :P)
Re: You will never be as cool as this guy
« Reply #1 on: Wed, 14 October 2015, 20:34:29 »
I will never be as cool as this guy with a pressure sensitive Realforce, forget the Sonata :P
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2 on: Wed, 14 October 2015, 20:49:09 »
That was pretty bad ass
Offline LXXXIX
  • Just remember all caps when you spell the man name
« Reply #3 on: Wed, 14 October 2015, 20:52:26 »
What's next to the RF almost looks like a Ducky.
Offline Melvang
« Reply #4 on: Wed, 14 October 2015, 20:58:45 »
Would it be possible to do something like this with a Wacom?
« Reply #5 on: Wed, 14 October 2015, 20:59:27 »
Brb, burning all my keyboards. My collection is a lie.
« Reply #6 on: Wed, 14 October 2015, 21:05:19 »
You were wrong all along. Topre is love. Topre is life.
« Reply #7 on: Wed, 14 October 2015, 21:08:01 »
Chill fam
Offline livingspeedbump
    • KeyChatter
« Reply #8 on: Wed, 14 October 2015, 22:49:28 »
Well, it would be on a Realforce now wouldn't it.
<- My Collection (so far)
Offline Coreda
« Reply #9 on: Wed, 14 October 2015, 23:02:32 »
This is a pressure based switch or just the regular Realforce? Doesn't sound much different than regular MIDI controllers.
Offline Oobly
« Reply #10 on: Thu, 15 October 2015, 04:39:21 »
Nope, Wacom uses a single stylus / pressure device. A pressure sensitive capacitive multitouch trackpad could work, though, like this thing: https://www.kickstarter.com/projects/1152958674/the-sensel-morph-interaction-evolved
https://geekhack.org/index.php?topic=74955.0
But you're better off buying a nice Roland midi controller keyboard. Right tool for the job works best every time.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #11 on: Thu, 15 October 2015, 06:40:00 »
I agree..
I've tried to play fur elise on a qwerty mapped with piano keys before,   while it will work.. and I could imagine pressure sensitivity working also.
It's was very difficult to get into the proper rhythm because the spacing is some ways at odds with the pacing of the music..
That' isn't to say it's IMPOSSIBLE,   just not yet practical.
« Reply #12 on: Thu, 15 October 2015, 06:48:52 »
Thats the new backlit type heaven, I believe it will have clear mx compatible topre stems.
Offline LXXXIX
« Reply #13 on: Thu, 15 October 2015, 06:49:53 »
Will it be cheaper than a Novatouch? Hmmmmm.
Offline osi
« Reply #14 on: Thu, 15 October 2015, 07:04:13 »
Offline Bromono
  • Wanabe Cicerone
« Reply #15 on: Thu, 15 October 2015, 16:51:18 »
It is pressure based. It's new from Topre.
Just saw an article and saw the video and thought it was neat
Source: http://techreport.com/news/28415/topre-latest-keyboards-are-colorful-sensitive-to-pressure
« Reply #16 on: Thu, 15 October 2015, 17:06:24 »
Isn't Topre an analog input (the switch triggers at a specific capacitance)?  Seems to me like you could make it "pressure sensitive" by reading the capacitance as a function of time and having faster inputs register as "higher pressure".  Which wouldn't require any new hardware, just a new controller.
But I dunno.  :))
Offline njbair
    • nickbair.net
« Reply #17 on: Thu, 15 October 2015, 17:24:09 »
But I dunno.  :))
What we're all calling "pressure" is actually velocity, as it relates to the piano (and the MIDI standard). I can very slowly depress a piano key and keep going until I'm applying significant pressure, but the note will be quiet because it was played with a low velocity.
So while pressure is not a function of time, velocity absolutely is, and that's what we're really talking about here
My boards:
« Reply #18 on: Thu, 15 October 2015, 17:32:25 »
But I dunno.  :))
Well yes.  But my point was that, unlike an MX switch which is a discrete input, the Topre switch should be an analog continuous input so it's actually possible.  :thumb:
Good point about pressure vs speed on the piano, I was goofing that one up in my mind.  Aren't those MIDI pads pressure sensitive (tangential curiosity)?
Offline njbair
    • nickbair.net
« Reply #19 on: Thu, 15 October 2015, 17:43:33 »
But I dunno.  :))
Actually the MIDI spec calls it velocity, as a parameter of the NOTE ON instruction with a value between 0 and 127. This makes sense for most emulated instruments, but there are some oddball instruments that use it for different effects. AFAIK the MIDI spec doesn't actually specify how it's supposed to be used.
My boards:
