Author Topic: Serial port  (Read 2167 times)
Serial port
« on: Sun, 08 November 2015, 11:47:05 »
So....
Can someone tell me why  an adapter with FGPA circuit is more expensive than one with an off the shelf chip like Oxford PCIe952
the FGPA one costs 2x as much..  But I honestly have no idea why.. it may just be a new product..
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: Serial port
« Reply #1 on: Sun, 08 November 2015, 11:51:34 »
Is this a usb to serial (db9) adapter? The cheap adapters suck with putty/console but I'm not sure what you're using it for..
Re: Serial port
« Reply #2 on: Sun, 08 November 2015, 12:05:58 »
i need to communicate with a fanuc.
it's an expresscard adapter,  not usb.
Re: Serial port
« Reply #3 on: Sun, 08 November 2015, 19:18:03 »
Is everyone not usings serial port these days?
Re: Serial port
« Reply #4 on: Sun, 08 November 2015, 19:54:15 »
I'm using a USB to serial adaptor.
Offline hudson0804
Re: Serial port
« Reply #5 on: Mon, 09 November 2015, 03:02:20 »
+1
However i have to carry two as one of them refuses to work with NT version 6.1 and above...
Re: Serial port
« Reply #6 on: Mon, 09 November 2015, 03:27:01 »
+1
Why not just carry the one that DOES work with NT 6.1+?
Offline hudson0804
Re: Serial port
« Reply #7 on: Mon, 09 November 2015, 07:05:16 »
In my mind my sentence made sense.
One cable works 6.1 and up but does not work 6.0 and down.
Hence two.
Offline keshley
    • Blog n stuff
Re: Serial port
« Reply #8 on: Mon, 09 November 2015, 10:16:57 »
ExpressCard seems overkill for this application.
I haven't used anything requiring RS-232 in ages, but seems like a USB adapter would be cheaper/easier. Any particular reason you're looking at ExpressCard?
I'm guessing the price difference is likely due to demand. There's probably a lot less demand for the adapter with the FPGA circuit.
HHKB Pro 2       Pok3r
