Author Topic: Thinkpads  (Read 38582 times)
Re: Thinkpads
« Reply #100 on: Thu, 08 December 2016, 07:32:24 »
sigh.... you guyz are wasting ur time..  all that  --old stuff-- is c2d... slow as molasses...
your priorities so in sync 100% of the time
I agree sth..  My understanding and comprehension of the modern hardware landscape is unparalleled..
hahahahha...
/this kid is still mad at me from losing arguments to Tp4 on the internet..
Offline sth
  • 2 girls 1 cuprubber
Re: Thinkpads
« Reply #101 on: Thu, 08 December 2016, 07:47:11 »
u_____u
Re: Thinkpads
« Reply #102 on: Thu, 08 December 2016, 07:49:22 »
u_____u
I'm glad you've seen reason ...  feel free bask in the light of Tp4..
Offline Leslieann
Re: Thinkpads
« Reply #103 on: Thu, 08 December 2016, 17:59:22 »
While some Core2 models aren't exactly garbage (most are), I wouldn't buy anything with DDR2 memory.
Spending an extra $30 for the next generation Lenovo to get DDR3 can save you money by the time you add extra ram. As a bonus you get Sata3, which is a big deal if you use an SSD.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Re: Thinkpads
« Reply #104 on: Thu, 08 December 2016, 18:05:24 »
Agree on ddr3..
sata... mmm.. one could live with sata 2 in a laptop..  where's the data gonna go.. fastest thing out of a laptop is usb 3.0 @ 120MB/s ?
Offline Leslieann
Re: Thinkpads
« Reply #105 on: Thu, 08 December 2016, 18:50:53 »
Agree on ddr3..
You can live with it, but I saw pretty nice performance gains switching from a drive capable of Sata2, to a drive that supported Sata3 in a system that supported sata3.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline PollandAkuma
Re: Thinkpads
« Reply #106 on: Thu, 08 December 2016, 19:12:56 »
The advantages of owning a Thinkpad seems to be durability and the ability to upgrade it. But I was thinking, I have a pretty durable Macbook pro from 2011 that'd be a shame to dump, so I was considering upping the RAM and change HDD to SSD. Is it even worth it? Should I get a thinkpad?
Offline vivalarevolución
Re: Thinkpads
« Reply #107 on: Thu, 08 December 2016, 19:21:19 »
I will be upgrading my mother's 2011 Macbook Pro with new RAM and an SSD this weekend.  We'll see how it goes.
My ex-girlfriend did a similar upgrade to her 2010 Macbook Pro and she says that it works great.
All in all, this type of upgrade should not cost more than $200 and probably will extend the life of your Macbook for at least a couple more years.  If you are concerned with Thinkpad features and the latest components, then a Thinkpad is worth it to you.  If you are concerned with raw performance, I think the Macbook Pro upgrade is worth it.
Re: Thinkpads
« Reply #108 on: Thu, 08 December 2016, 19:38:18 »
The macbook is worth upgrading, if that's what you take to the library to impress the females..
Because even a 2011 macbook makes you look wealthier than a 2016 lenovo pleb..
BUHhhhh in terms of performance,  NOTHING pre-sandybridge is worth upgrading....
Re: Thinkpads
« Reply #109 on: Fri, 09 December 2016, 08:51:32 »
I'd get a Thinkpad just for the hype, but first I need to find one  ;D I want to kill myself when my Mac takes one minute to start up and one minute to open Firefox... And another one minute to open word...
What are these "Thinkpad features and the latest components" you speak of? I know only about the trackpoint and the nice keyboard. Seems like getting a X220 would be a good choice for me, since I like that style of keys... Preferably in ISO too haha.
Re: Thinkpads
« Reply #110 on: Fri, 09 December 2016, 08:56:34 »
No .. that's ridiculous.. do not get an x220.. ur insane..  a fully punched out x220 costs ~$400-500 with all the upgrades..
That much money can buy you a modern laptop with quadcore i7
Offline menuhin
Re: Thinkpads
« Reply #111 on: Fri, 09 December 2016, 09:00:59 »
Think about the FHD mod if you have time and patence to DIY, or if you have $$$ (a FHD modded is about double the price of a nice used model of the same spec).
http://hackaday.com/2016/08/26/making-a-thinkpad-great-again/
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Re: Thinkpads
« Reply #112 on: Fri, 09 December 2016, 09:07:29 »
omg.. u guys are insane.. hahahahahahaha
U can get an x230 with 1080p  without all that hassle, AND cheaper..
Yes the x220 is legendary among enthusiasts,  but it's still NOT a very good laptop for modern use.
Ur going to buy one.. and boom oh ****, it doesn't have the latest iteration of the LG ips panel...
So you go to amazon.. buy newest LG panel for $60..
OH NO,  i need 1866mhz ram...   go to amazon $100 for 1866mhz laptop ram..
OH NO.. I need SSD to the max..  go to amazon.. $150 for SSD
OH NO... I needz super duper wifi card.. go to amazon.. $40 for wifi card..
OH NO.. .it won't boot with default bios...   spend 10 hours finding the right bios....
OH NO... it' s still slow because the processor is maxed at 2.6ghz..
.. Proceeds to buy a new laptop $700..
Total cost of x220... $$$$$$$$$$$$$$$$$$$$$$$$$$...
Offline Flyersfan1
  • Hi!
Re: Thinkpads
« Reply #113 on: Fri, 09 December 2016, 09:19:01 »
I thought the x230 was only available in 1376x768? Can I buy a replacement screen for it at a higher resolution?
Quote from: Photekq
Re: Thinkpads
« Reply #114 on: Fri, 09 December 2016, 09:21:18 »
u are right.. i was thinking of x240..
Offline mike52787
  • Alps Aficionado
Re: Thinkpads
« Reply #115 on: Fri, 09 December 2016, 09:24:44 »
Thinking about either a x1 carbon or x260, was considering t460s but the reviews say it has **** battery life. The 1440p screen on the carbon is a very attractive option as well, especially coming from the 1366x768 screen on my x230. one problem, theyre too expensive. optioned like I want them to be, its 1200$+ -_-
Re: Thinkpads
« Reply #116 on: Fri, 09 December 2016, 09:33:49 »
get the carbon.. the x260 is single channel again..
Re: Thinkpads
« Reply #117 on: Fri, 09 December 2016, 10:39:38 »
Are you trying to scare me off Thinkpads? Because i am now wary. Maybe I should just stay with my Macbook since Thinkpads are ****tier in general.
Re: Thinkpads
« Reply #118 on: Fri, 09 December 2016, 10:42:31 »
Macbook has a VERY SPECIFIC purpose....  When you're a student, you go somewhere with ur laptop.. all the pretty girls will look at your laptop and JUDGE YOU..
That's how the Modern world works ..
So as a young-guy, going out into the wild..    You NEED a Macbook..
Lenovo gives you way way way more machine per dollar, but it is for hardcore neckbeards bordering the #Ronery4ever camp...
Re: Thinkpads
« Reply #119 on: Fri, 09 December 2016, 10:47:36 »
Macbook has a VERY SPECIFIC purpose....  When you're a student, you go somewhere with ur laptop.. all the pretty girls will look at you and JUDGE YOU..
That's how the Modern world works now..
Lenovo is for hardcore neckbeards bordering the #Ronery4ever camp...
I don't give a **** what other's think if I have something I'm happy with... Giving it more thought maybe a Thinkpad's not such a good idea since I use music composing software sometimes. Ah, RIP my dreams of a new toy...
no comment on your last statement ha
Offline duynguyenle
  • Personal text? What personal text???
Re: Thinkpads
« Reply #120 on: Fri, 09 December 2016, 10:55:24 »
I'm sure you can run your music software on a Thinkpad, newer X or T models are pretty good and they are quite easy to service.
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Re: Thinkpads
« Reply #121 on: Fri, 09 December 2016, 12:08:23 »
Hahahaha  Yea.. I understand that is the attitude you think is __ Cool __ and it solidifies your ego..
But soon enough, you grow older and realize that the opinion of others is 50% or more of your Reality.
Then it would be too late to start dressing stylish, because you missed out on the college girls experience, and in the real world.. it's all work, and no girls..
Even if you do find a girl after college,,   the relationship price is also now way way higher..
Offline ideus
  • Björkö.
Re: Thinkpads
« Reply #122 on: Fri, 09 December 2016, 12:18:28 »
Your computer is the last thing a girl does care about you.
« Last Edit: Fri, 09 December 2016, 12:22:32 by ideus »
Re: Thinkpads
« Reply #123 on: Fri, 09 December 2016, 12:22:25 »
hahahaha...
we're gonna go through this again?
when was the last time ideus was 19 and at a college library.
Lest we forget also, my sandwich store thread..
Offline menuhin
Re: Thinkpads
« Reply #124 on: Fri, 09 December 2016, 12:26:38 »
+1
(except for the super geeky girls who study computer science and computer engineering themselves; but they tend to have lots of stickers on their laptops and give the laptops pet names etc.)
College experience is not just girls by the way. I joined a fraternity and a few clubs, people I met were mostly outdoor people in those years: climbing, trekking, playing music in a gypsy manner, I swore I never wanted to touch computers again.
Oh, were we talking about ThinkPad by the way?
IBM M13 black
HHKB Pro 2 HasuBT
Re: Thinkpads
« Reply #125 on: Fri, 09 December 2016, 12:36:19 »
+1
That's bull****..
Think about it this way..  You can do all those outdoor things any time..
But ONLY in college are the females pretty open with relationship/cohabitation without significant conditions..
The proximity alone makes relationship cheaply maintainable..
As soon as you leave school... especially in the computer occupation..  ALL NECKBEARDS...  even the women around here haz neckbeards...
SO... yea.. College IS ALL ABOUT the girls...    Education yes,  but MOSTLY you're paying for proximity to females.
Re: Thinkpads
« Reply #126 on: Fri, 09 December 2016, 15:48:41 »
What do you recommend :P
Offline duynguyenle
Re: Thinkpads
« Reply #127 on: Fri, 09 December 2016, 16:27:31 »
Depends on your budget, but I do not under any circumstances, recommend getting a new laptop from Lenovo directly, they tend to be pretty overpriced that way, but you can find T450 or T450s models for like Ł300-400 on Ebay at new or like new condition.
If you've got cash to spare, the X250/260 or the X1 Carbon is really nice (but the X1 is limited in some ways)
Offline Leslieann
Re: Thinkpads
« Reply #128 on: Fri, 09 December 2016, 16:46:57 »
TP's numbers are TP4 numbers... Crazy, like he is.  :))
My X220 was extremely fast, and I had a bit over $300 invested, and that included 2 brand new OEM batteries and a dock.
I paid $170 for an I5 model (higher end I5) with dock, bluetooth, OEM charger, OEM battery, and IPS screen. The owner didn't realize it had an IPS screen (check part numbers).
The speeds of it compared to the I7 were almost no different, however it did lack USB 3, which could be added with a card for very little. I added an efficient 256Gb ssd ($60 already on hand), 16Gb ram ($60) and an OEM battery for $20. Then I learned the original battery had a recall, so Lenovo sent me another for free. I added a 450meg Wireless card for $6 (already on hand). I had no trouble finding bios to whitelist the card (all of 10 minutes).
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Leslieann
Re: Thinkpads
« Reply #129 on: Fri, 09 December 2016, 17:00:34 »
Agreed, never buy Lenovo high end models new as they are overpriced for consumers, used though, they are one of the best bargains you can get.
As for recommendations, it depends on the size you want and what you can spend. I would stay clear of the X240 and T440 as they are locked down in the bios, while everything before and after can be bios modded, at least to whitelist the wifi card. If you want something smaller and more lightweight, you could also consider a Macbook Air. 4Gb models are rather cheap ($300) and plentiful if you want to stick with Mac, however, the screen resolution isn't great but on an 11in screen, a higher density is kind of tricky to get right.  Be sure to read below if you consider this.
Regarding the older Mac
Older Macbooks do just fine with mild upgrades, I worked on a (2010?) C2d Imac with 2gb of ram and a normal hdd,  it actually ran decent. I'm not saying it was fast, but it ran better than a lot of newer Windows systems with double and sometimes even quadruple the ram. Even this year, Mac owners were encouraging people to buy Macbook Airs with only 4gigs of ram. Personally, I wouldn't but that's because I dual and sometimes triple boot mine but I can see how they can get away with it as Mac uses memory super efficiently. 8gb 11in Airs can be found but they can cost more than twice as much, and be much harder to find that perfect one (4Gb outsold 8gb models by about 40:1).
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Re: Thinkpads
« Reply #130 on: Fri, 09 December 2016, 20:15:07 »
Tp4tissue likes to troll about Thinkpads, take it easy, guys.
Re: Thinkpads
« Reply #131 on: Fri, 09 December 2016, 20:22:02 »
Latest components is stuff like 6th gen processors, DDR4 RAM, better wi-fi card, etc.
Beyond what you mentioned about Thinkpads, they are durable, easily upgradeable compared to a Mac, lower price, more options and customization.  Generally what Thinkpads are known for.
Re: Thinkpads
« Reply #132 on: Sat, 10 December 2016, 00:33:44 »
How dare u...
Tp4 haz x220 mastery lvl 999....
Leslieann is giving you --off hand-- pricing which only works if you had all those things laying around..
Which is far less realistic a pricing quote than my list.
Offline Leslieann
Re: Thinkpads
« Reply #133 on: Sat, 10 December 2016, 02:29:33 »
Receipts from when I built mine.
155145-0
155147-1
I don't remember which exact card I used (I sold my X220 for $450 a few months ago) but here is one for comparison.
450meg wifi card  Intel 5300 or 6300 $7.50 - Ebay
« Last Edit: Sat, 10 December 2016, 02:35:13 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline duynguyenle
Re: Thinkpads
« Reply #134 on: Sat, 10 December 2016, 07:07:58 »
Just chiming in with my ebay'd T440s from last year:
You do have to hunt around for deals like this, Buy It Now prices tend to be around Ł300-400 for newer models, but the newer models do have some quality of life-type improvements over the venerable X220 that does make it the experience better (mainly improvements in CPU and battery life, larger and more responsive trackpad). Stay well away of the X240/T440 series as someone noted the locked down BIOS and what I view as a cardinal sin (removal of track point buttons above the trackpad), but that laptop was for my brother to do his university work and he doesn't care too much for the track point.
You can get a like-new T450 right now for Ł350 buy it now price, which is a pretty decent deal.
Re: Thinkpads
« Reply #135 on: Sat, 10 December 2016, 08:03:21 »
That's the wrong ram.. need 16gb 1866 to fully xperience the glory of x220
Gotta get on the wifi AC if you buy a card today.
there are several different versions of the IPS, the first 2 iterations had banding issues..  Only the later ones were fixed.
SSD side, 512gb is recommended to get any productivity suite going on there.
Offline Leslieann
Re: Thinkpads
« Reply #136 on: Sat, 10 December 2016, 17:47:11 »
No, you don't need that ram. With 16gb it's still plenty fast compared to anything in it's class even today. Would it be faster, of course, but it's not required to make a beast of a laptop.
Wireless AC is useless unless you have a file server to store large files, most people are not transferring that much data back and forth on a laptop. N150 is enough to stream HD, 300 is enough to stream HD while transferring files or surfing.  Beyond that you get diminishing returns every step up.
IPS, Lenovo puts manufacturing dates right on the bottom of the laptop, mine had no banding. If you work outdoors, get IPS, if you work indoors, especially at night liek i do, you may actually prefer the TFT. In low light settings the IPS is like having a flashlight shone in your face. Screens are $60 and a 10 minute swap.
Drive size,
There are six 480-512gb drives currently on Newegg for $109), that's only $40 more. Not a big deal.
That said, I get by just fine on 256, even with triple boot, Solidworks and Photoshop, as would 90% of people (in my experience, most people have less than 200gigs on their system). Productivity suites do not require 200 gigs of data.  At any rate, the X220 allows for 2 drives to be installed, you can easily add a second drive later if you need the space. The T420 you can ditch the dvd and add a second drive.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline duynguyenle
Re: Thinkpads
« Reply #137 on: Sat, 10 December 2016, 18:01:09 »
Drive size,
Psst, I think he's trolling  :p
Re: Thinkpads
« Reply #138 on: Sat, 10 December 2016, 20:05:45 »
How dare u...
My bad, I will return to bowing down in worship.
Offline Leslieann
Re: Thinkpads
« Reply #139 on: Sun, 11 December 2016, 03:23:48 »
Drive size,
You know the saying you know hes lying because his lips are moving...  With Tp, you know he's trolling when his fingers are moving.
« Last Edit: Sun, 11 December 2016, 03:26:51 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Re: Thinkpads
« Reply #140 on: Sun, 11 December 2016, 07:57:32 »
How dare u...
Re: Thinkpads
« Reply #141 on: Fri, 23 December 2016, 21:22:08 »
So I got one of them Thinkpad Yoga 260s.   Dual booting with Ubuntu Gnome to have some Linux touch screen action.  Not bad when most of the touch screen stuff actually works.
Re: Thinkpads
« Reply #142 on: Wed, 08 August 2018, 11:00:09 »
Has anybody seen these Chinese replacement motherboards for old Thinkpads?
They look very sweet at first glance... Modern i7-HQ CPU (not socketed), dual SO-DIMM slots, dual M.2. slots and SATA.
Offline no, the other guy
  • actually, this guy
Re: Thinkpads
« Reply #143 on: Wed, 08 August 2018, 12:03:41 »
I looked at Thinkpads but didn't like the direction Lenovo was going
Three years after, ThinkPads have:
  • a worse display than the IBM models
  • a worse keyboard than the IBM models
  • a worse reputation than the IBM models
I bought a cheap T60 a few years ago. I still keep it for random things (although it has become too weak to be used for actual work). It is still fine, except the aging cooler and the notorious lack of USB ports. Which is ongoing as far as I have seen...
<armin> i have the impression the only reason the mx red switch was invented was drunk people
Unicomp PC122 (review) * IBM Model F XT * Dell AT101W
Offline ideus
  • Björkö.
Re: Thinkpads
« Reply #144 on: Wed, 08 August 2018, 12:10:30 »
The chance to put one of these good old TP to work again is nice. But, the site and all is very confusing. Also, it seems that demand is much higher than supply and that is a death combo for final consumers, price-wise.
« Last Edit: Wed, 08 August 2018, 12:39:03 by ideus »
Re: Thinkpads
« Reply #145 on: Wed, 08 August 2018, 15:39:29 »
If you're in it for the Fashion of something-Old,  Hipster style..
Sure..
But , it's not very practical.. You can get a newer laptop with Much better batteries for that price..
Offline Leslieann
Re: Thinkpads
« Reply #146 on: Wed, 08 August 2018, 19:21:47 »
I looked into these and other mods that are available, there is always a compromise somewhere as you are modifying an OLD laptop. Batteries, replacement parts, support, costs, and then there are the things you don't even think about, like how modern media is all widescreen. These are often low production numbers and you have no idea where it's made. I'm not saying these mods are not cool and do extend the life of a product, but at what cost and compromise.
$740 for a 5th gen I5 X200?  Don't forget you will have to buy new ram so let's make it a $850.
Do you have any idea what kind of used notebook you can get for $850? Certainly one that will cream this in any test you can throw at it.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline ideus
  • Björkö.
Re: Thinkpads
« Reply #147 on: Wed, 08 August 2018, 21:37:29 »
Those prices make this a bad choice economic-wise. It is always better just to buy a new lappy. I really do not see the point to resurrect an old hardware if for the same money you can get brand new everything. I really like my old X61T but it does not make sense to invest good money in such an old piece of hardware.
Re: Thinkpads
« Reply #148 on: Wed, 08 August 2018, 21:41:26 »
If the primary task is to watch movies, then maybe a Thinkpad wasn't then best choice in the first place.
The point of resurrecting an old ThinkPad would be the screen's aspect ratio ... and of course the keyboard.
« Last Edit: Wed, 08 August 2018, 21:43:37 by Findecanor »
Offline ideus
  • Björkö.
Re: Thinkpads
« Reply #149 on: Wed, 08 August 2018, 21:57:50 »
I am a thinkpad fan-boi. But, truth be told, keyboard alone does not justify to tolerate the other low spec hardware, particularly the old materials in batteries. I am writing this with my favorite custom keyboard wired to the T460s docked with a nice high res display. I will never be able to do the same with my old X61T even with the upgraded mother board. My current setup has a dedicated graphics card, 20G or RAM the fastest NVme SDD. What motivation I may have to retroing to my old TP for a price?
