Author Topic: QMX-Clicp  (Read 7556 times)
Offline xiaodian317
QMX-Clicp
« on: Mon, 30 November 2015, 23:13:44 »
QMX-Clip by GMK
I get one sample.
Do you like it?
Offline quake4mhg
Re: QMX-Clicp
« Reply #1 on: Mon, 30 November 2015, 23:46:56 »
Yes! I got mine from MD, with 2x orings & jailhouse blue, it further reduces my actuate distance. Good for online FPS :D
Offline ideus
  • Björkö.
Re: QMX-Clicp
« Reply #2 on: Thu, 17 December 2015, 12:45:56 »
Any more feedback on this?
Offline Hyde
  • White Tofu Extraordinaire
Re: QMX-Clicp
« Reply #3 on: Thu, 17 December 2015, 12:58:10 »
Yeah like do they feel nice?  Is the sound reduction good?
:D
Offline Giorgio
Re: QMX-Clicp
« Reply #4 on: Sat, 19 December 2015, 18:05:13 »
Sound reduction is very good, similar to an apple aluminium keyboard, and much more silent than the new cherry red silent switches. Especially for the big stabilized keys.
And the feeling is good, better than orings, which in my opinion are too mushy.
Offline Giorgio
Re: QMX-Clicp
« Reply #5 on: Sat, 19 December 2015, 18:07:04 »
Too bad that I haven't received any recent update from uniqey...
Offline livingspeedbump
    • KeyChatter
Re: QMX-Clicp
« Reply #6 on: Sat, 19 December 2015, 22:56:58 »
I had a set a long while ago. IMO they are relatively useless, obviously due to the fact they can only be used with plate PCB mount keyboards, and those are few and far between.
But, I will say that they did make MX Blacks feel quite nice. I usually am not a linear fan, but I did enjoy how they felt/sounded with blacks.
They do make the bottoming out quieter, and they do reduce travel distance LESS than both o-rings and EK pads, so if you have a plate PCB mounted keyboard, these were the best option imo.
EDIT: Sorry! tired when I wrote this from Star Wars crap. PCB mount only.
« Last Edit: Mon, 21 December 2015, 22:23:39 by livingspeedbump »
<- My Collection (so far)
    • KeyChatter
Re: QMX-Clicp
« Reply #7 on: Sat, 19 December 2015, 22:57:42 »
Offline ideus
  • Björkö.
Re: QMX-Clicp
« Reply #8 on: Sat, 19 December 2015, 23:49:55 »
Thank you very much for the feedback, if someone has a set of these clips that do not need them anymore, I will be very glad to get them.
    • KeyChatter
Re: QMX-Clicp
« Reply #9 on: Sat, 19 December 2015, 23:51:58 »
darn. gave my test set away or I'd have given them to ya
Offline ideus
  • Björkö.
Re: QMX-Clicp
« Reply #10 on: Sat, 19 December 2015, 23:53:47 »
No worries, I am sure some fellows out there would not need them anymore.
Re: QMX-Clicp
« Reply #11 on: Sun, 20 December 2015, 15:29:19 »
Question..  Does this do anything for "rebound" noise..
As in, does that rubber insert Pre-press the stem slightly such that the rebound noise is reduced..
Re: QMX-Clicp
« Reply #12 on: Sun, 20 December 2015, 15:31:11 »
I had a set a long while ago. IMO they are relatively useless, obviously due to the fact they can only be used with plate mount keyboards, and those are few and far between.
They do make the bottoming out quieter, and they do reduce travel distance LESS than both o-rings and EK pads, so if you have a plate mounted keyboard, these were the best option imo.
Think you meant PCB mount not plate mount. :thumb:
Offline ideus
  • Björkö.
Re: QMX-Clicp
« Reply #13 on: Sun, 20 December 2015, 15:37:22 »
These clips have been designed to work on PCB mounted switches, because their skirts come down over the top of the switch and they clipped on the bottom part of the top, therefore the plate does make interference with the clips, if it is installed because it seats exactly on the same edge of the top.
    • KeyChatter
Re: QMX-Clicp
« Reply #14 on: Sun, 20 December 2015, 15:49:49 »
Yup, sure did. Must have been loopy from being up 3 days straight for that little star wars movie.
Offline Giorgio
Re: QMX-Clicp
« Reply #15 on: Sun, 20 December 2015, 16:16:34 »
It silences completely the downstroke and the upstroke.
Re: QMX-Clicp
« Reply #16 on: Sun, 20 December 2015, 21:45:47 »
Could  you make a video of this comparison..
Hold the switch down,  then pick your hand up as fast as you can.. whip it ..
Offline Giorgio
Re: QMX-Clicp
« Reply #17 on: Mon, 21 December 2015, 01:29:00 »
   https://vid.me/FZQ6
I will soon post a longer video
Offline ideus
  • Björkö.
Re: QMX-Clicp
« Reply #18 on: Mon, 21 December 2015, 11:37:14 »
   https://vid.me/FZQ6
Thank you for this, and a longer one would be even better, what type of switches are those?
Re: QMX-Clicp
« Reply #19 on: Mon, 21 December 2015, 22:19:40 »
   https://vid.me/FZQ6
well alrite.. I'm convinced..   Ready to throw money...
Does this work on plate mounted or is it pcb-mounted xclusive.
I could easily cut a new plate for my ergodox to accomodate this.. I got lazers now.
    • KeyChatter
Re: QMX-Clicp
« Reply #20 on: Mon, 21 December 2015, 22:22:11 »
   https://vid.me/FZQ6
I was tired when i wrote this "plate" earlier and meant PCB mount. PCB Mount only.   :thumb:
