Author Topic: A quality, but inexpensive keyboard  (Read 10576 times)
Offline Blaise170
  • ALPS キーボード
    • XYZ
« on: Tue, 08 December 2015, 18:59:56 »
I have a particular professor who has helped me a lot throughout the time he has been here. He fondly remembers "clicky" keyboards and bought himself one of the Rosewill boards with Alps clones. He had a lot of problems with it and he went back to a genetic dome board. As appreciation, I'd like to buy him a keyboard that won't fall apart on him like the cheap Rosewill did. My budget is not very high, but I don't really have a specific max. What would you all suggest? A vintage board will be just fine so long as I can get it compatible with AT/PS2/USB. I might get a Model M since it's the classic mech but I'm afraid it might be too large for his desk. I can also do repairs so condition is not extremely important.
Offline trenzafeeds
  • **** off
Re: A quality, but inexpensive keyboard
« Reply #1 on: Tue, 08 December 2015, 19:06:42 »
To be honest I think Model M would be amazing... freaking amazing, and for a great price. Not that much extra room on the desk.
demik will never leave.
Unless he gets banned.
Offline Nover
« Reply #2 on: Tue, 08 December 2015, 19:08:36 »
Get him the Model M. You already considered it and with good reason. It is indeed THE keyboard that comes to most people's minds when they think of a mechanical, clicky keyboard.
If the desk is too small for it, he'll have to make room or get a new one!
SSK, Ducky YOTD
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #3 on: Tue, 08 December 2015, 19:45:52 »
Who wouldn't make room for something as majestic and great-to-use as a Model M?
Offline trenzafeeds
  • **** off
« Reply #4 on: Tue, 08 December 2015, 19:47:24 »
I mean you could always get an M spacesaver, but that's not exactly inexpensive...
« Reply #5 on: Tue, 08 December 2015, 19:51:42 »
I think that there have been multiple Ms at great prices listed here in the past week.
- D Trump 2026-10-24
« Reply #6 on: Tue, 08 December 2015, 19:58:01 »
Model M fits the clicky requirement, price requirement, and presumed nostalgia requirement.  What's not to love?  :3
Offline ctm
  • Hello, world!
« Reply #7 on: Tue, 08 December 2015, 21:32:20 »
If Model M is too large, you can consider Unicomp Ultra Classic. It has smaller frame than Model M. It also has native USB interface and windows key.
Coming:
Ellipse Model F F62.
Offline ideus
  • Björkö.
« Reply #8 on: Tue, 08 December 2015, 21:42:57 »
I'd say Unicomp.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #9 on: Tue, 08 December 2015, 21:43:58 »
Everyone here is telling you right!  It's an impressive keyboard!
Offline E3E
« Reply #10 on: Wed, 09 December 2015, 00:11:11 »
Blaise, I think it's time to go dumpster diving for SSKs. ;)
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #11 on: Wed, 09 December 2015, 12:26:46 »
What would you all recommend for non clicky? I'm not sure if the noise will bother others sop I'll have to discreetly ask him later.
Offline Dernubenfrieken
« Reply #12 on: Wed, 09 December 2015, 12:59:04 »
For something reasonably cheap, a Quick Fire Rapid is pretty great, although the caps leave something to be desired
« Reply #13 on: Wed, 09 December 2015, 13:02:40 »
Not sure what your budget is but it is hard to go wrong with the fullsize leopold with side print pbt caps and mx reds if you want a full size board.
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1400
Offline ideus
  • Björkö.
« Reply #14 on: Wed, 09 December 2015, 13:39:33 »
Get him a modern kishaver... If you find one.
Offline Neo.X
« Reply #15 on: Wed, 09 December 2015, 14:56:09 »
Yes, this rocks.
All those keyboards will be lost in time....
Offline ideus
  • Björkö.
« Reply #16 on: Wed, 09 December 2015, 15:03:13 »
It's a chimera though.
Offline Altis
« Reply #17 on: Wed, 09 December 2015, 20:26:11 »
I've been wondering the same thing for a few people I want to gift keyboards to. Can't seem to find much for a reasonable price for a gift.
Offline chyros
  • a.k.a. Thomas
« Reply #18 on: Thu, 10 December 2015, 02:43:20 »
"Quality but inexpensive" pretty much means second hand if you ask me. Obviously it depends on how much you want to spend but a second hand M or Alps board if you want to spend a little less aren't that much or hard to find I think :) .
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #19 on: Thu, 10 December 2015, 07:44:16 »
Yeah secondhand is fine. I have enough MX and Alps keysets that I don't need to worry about that and I can fix most broken PCB traces, etc. Just seeing if there was anything that was around for a decent price but also decent quality.
Offline SamirD
« Reply #20 on: Wed, 16 December 2015, 09:38:05 »
This would be my vote.  If you can find one secondhand too, it won't break the bank.  You may also be able to find an original M for the same price, but it might take some searching.
Offline Jixr
« Reply #21 on: Thu, 17 December 2015, 11:02:07 »
Kinda related, I've given away a few keyboards as gifts, and I'm lucky and can find them used all the time, and just spend a few bucks and get them a spacebar from WASD with their internet name, gamer tag, or something like that put on there. Cheap and personal gift for tech lovers.
Offline losing_ctrl
« Reply #22 on: Fri, 18 December 2015, 07:58:35 »
For inexpensive non-clicky I would include the higher-end KeyTronic keyboards into consideration. I had one of these...
http://www.amazon.com/104KEY-PS2-Keyboard-Black-Wmembrane/dp/B000M0HUNI/ref=sr_1_6?ie=UTF8&qid=1450447026&sr=8-6&keywords=keytronic+keyboard+Designer
...and was VERY impressed. These are simple membrane boards but I found them to be very comfortable and pleasing to type on. KeyTronic offers tons of models of super cheap boards that I haven't tried, but these higher-end Ergo boards are worth the extra money.
Also, we would probably all agree that the best clicky switch is a very personal choice, and it may be hard to match your prof's preference.
Offline chyros
  • a.k.a. Thomas
« Reply #23 on: Fri, 18 December 2015, 09:29:23 »
Eh, to each their own I guess. I don't mind a rubber dome keyboard if it's really good, but all the Key Tronics I've found (and that's a fair few) didn't feel special at all. I've found a few really good rubber dome boards but I wouldn't count any Key Tronics among them.
Offline Altis
« Reply #24 on: Fri, 18 December 2015, 17:08:43 »
I suspect there could be a wide range of them. I've tried many that are nothing special, but I've tried some that are strikingly similar to the feel and even sound of a Realforce 87U in 45g.
I actually keep one in my work car that I use for when I need an external keyboard while on-site (technician-style job). Quite like it, and it was free so I'm not worried about what will happen to it.
Having said that... I'm not sure I'd gift one and I have no idea how the new ones are. I've only used older ones.
Offline losing_ctrl
« Reply #25 on: Fri, 18 December 2015, 18:56:45 »
Your point is well taken. I guess I was thinking that this could be a board that is given with the caveat of, "Here is a membrane board that doesn't suck, to use until you make your next mechanical keyboard investment, because there are so many awesome choices that it could take you awhile before you settle on your next choice." Or something like that. That being said, my personal opinion of this KeyTronic keyboard is that it is truly a cut above - it's been awhile since I had it (I don't remember what happened to it), but I'd like everybody here on GH to try it because it is a great cheap keyboard that made my fingers happy every time I typed on it. FWIW, my two favorite keyboards are my Silver Label Model M, and my RealForce 87U 55g.
« Last Edit: Fri, 18 December 2015, 19:01:08 by losing_ctrl »
Offline SamirD
« Reply #26 on: Sun, 20 December 2015, 23:55:08 »
I too would recommend the Keytronic as a cheap gift, although the better ones are in the same price range as a good vintage board.
I own two vintage Keytronics and they're quite nice--a little lighter than the IBM rubberdome M, but just as much 'snap' so you know when the keypress is occurring.  Keytronic is still around, so I'm sure the same board feel would be available.
Offline Snowdog993
« Reply #27 on: Mon, 21 December 2015, 09:54:10 »
Whoa!  I need a drink!  How did it go from Model M to rubberdome?
« Last Edit: Tue, 22 December 2015, 11:19:04 by Snowdog993 »
Offline livingspeedbump
    • KeyChatter
« Reply #28 on: Mon, 21 December 2015, 16:53:40 »
The MK.com branded keyboards are really good for the price. They are all essentially Ducky keyboards.
KBP makes good, cheap boards. For more popular brands, Cooler Master has been my "go-to" cheap boards for a while. Very good for the money.
<- My Collection (so far)
« Reply #29 on: Mon, 21 December 2015, 16:57:12 »
I'm still a fan of the full size Leopold, it comes with thick PBT caps and has a dampened case for only $120 and its simple and not flashy.
Offline jcoffin1981
« Reply #30 on: Mon, 21 December 2015, 18:10:16 »
A keyboard is a very personal thing.  You may try to get a few words of a hint in the right direction before going out and making a purchase.  It's like buying a handbag, wristwatch, or winter coat for a person.  These are things the owner really has to choose for themselves.
« Reply #31 on: Mon, 21 December 2015, 22:18:29 »
GO unicomp,, because if you get an M,  there's a chance it's disgusting, and dirty, and you have to clean all the 70s and 80s jizz off of it.
New Unicomp, it works, it has usb, you're good to go.
Offline piemancoder
« Reply #32 on: Mon, 21 December 2015, 22:57:56 »
You could try and get a Unicomp or even an older Model M and do a floss mod if he wants a quieter board.
Yoda grammar best has
Offline crj3012
« Reply #33 on: Wed, 30 December 2015, 13:45:42 »
Don't forget to check thrift stores and Craigslist for Model M's.
Offline SamirD
« Reply #34 on: Thu, 31 December 2015, 10:32:53 »
I just saw that some brand new Keytronic boards are going for <$8 from the official store:
https://keyboards.keytronic.com/home/shop/shop.asp?h_ck=T48502
That's a deal on a really nice rubberdome.
    • KeyChatter
« Reply #35 on: Thu, 31 December 2015, 15:16:17 »
Ive tested a few of the MK.com branded keyboards. They aren't massively cheap, but they are cheaper than their direct competition and have proven to be quite good.
Used Model M's often go for $50 or so on Ebay, and that is a great deal for what you get.
    • KeyChatter
« Reply #36 on: Thu, 31 December 2015, 15:17:27 »
Also, if you buy a Model M and it doesnt work, chances are you can get it working for quite cheap. Unicomp still sells everything from the spring housings to the membrane assembly and replacement keycaps, all for quite cheap  :thumb: Their shipping is also really fast :D
Offline neverused
« Reply #37 on: Thu, 31 December 2015, 15:25:13 »
Make one (still needs work):
    • KeyChatter
« Reply #38 on: Thu, 31 December 2015, 15:28:35 »
whoa. need more pics  :eek:
Offline neverused
« Reply #39 on: Thu, 31 December 2015, 15:33:35 »
I'm working on it as I find time between works and kids, usually after midnight. It should be done soon, all the electronics are done, just still making the case even smaller.
I think I'm going to approach CPTBadAss about putting it in tactile zine before I post a full log here. My biggest issue is finishing the case since I have no experience in filling/painting, which will be necessary given how much I have to cut away.
@OP this can be done easily too.
Offline SamirD
« Reply #40 on: Thu, 31 December 2015, 18:36:34 »
...about putting it in tactile zine...
What's this?  Link?
    • KeyChatter
« Reply #41 on: Thu, 31 December 2015, 18:39:09 »
What's this?  Link?
CAPTBadAss does it all himself  :thumb:
Offline SamirD
« Reply #42 on: Thu, 31 December 2015, 18:52:37 »
What's this?  Link?
Very cool.  How does one read it?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #44 on: Thu, 31 December 2015, 19:03:04 »
Thanks for the suggestion but I really wasn't looking for rubberdome.  ;)
Offline ideus
  • Björkö.
« Reply #45 on: Thu, 31 December 2015, 19:08:46 »
It is looking cool so far.
Offline neverused
« Reply #46 on: Thu, 31 December 2015, 19:10:50 »
Thanks! My plan is to make that chimera come to life soon, but with a better layout. More info shortly.
