Author Topic: Which key distance do you prefer?  (Read 2527 times)
Offline burli
    • My Neo 2 Blog
« on: Wed, 20 January 2016, 04:34:31 »
hi, the default distance between Cherry MX keys is 19.05mm. Cherry ML is 18mm.
Which distance do you prefer?
I love the Neo 2 Layout and splitted matrix keyboards. Never want to go back
Offline bocahgundul
  • a seal
Re: Which key distance do you prefer?
« Reply #1 on: Wed, 20 January 2016, 04:39:08 »
What the hell mang? you have a really sensitive finger i would say
Offline burli
    • My Neo 2 Blog
« Reply #2 on: Wed, 20 January 2016, 05:15:44 »
I have big hands. I have problems on a Cherry G84. My daughter likes the G84. So it's a legitimate question
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #3 on: Wed, 20 January 2016, 06:23:52 »
I've done a fair amount of experimenting on spacing and found that the ML horizontal spacing may be too tight for the largest hands but is workable for most (90%?) people. The biggest obstacle is familiarity. Many will think it is too close because it is non-standard, but I find it faster and more comfortable because of reduced hand movement. The vertical spacing can be even closer and has even less restrictions on hand size.
Offline tronbeaver
« Reply #4 on: Wed, 20 January 2016, 09:04:46 »
95%.
Math majors rule.
« Reply #5 on: Wed, 20 January 2016, 09:20:00 »
I don't think the key base is a deciding factor.  since it doesn't really affect how big the "top" surface can be..  Because you can even taper it outwards from the base if you like...
Offline kurplop
« Reply #6 on: Wed, 20 January 2016, 10:29:33 »
95%.
Math majors rule.
Only if you include children.
It doesn't matter how big the keycap's footprint is but the spacing does affect the amount of reaching necessary and how cramped the fingers are in home position.
The size of the cap top is critical however. When I've made undersized keycaps in the past, I've had to be careful with the design to keep the top surface small enough to avoid hitting a neighboring key. I found that flatter laptop style cap profiles, while they work in that application, don't allow enough clearance for the mechanical switch's greater depth of travel.
« Reply #7 on: Wed, 20 January 2016, 12:38:37 »
I prefer the regular 3/4" horizontal spacing. I think that vertical spacing could be smaller without impacting the feel.
« Last Edit: Wed, 20 January 2016, 12:40:39 by Findecanor »
Offline Homenubbie
« Reply #8 on: Wed, 20 January 2016, 12:47:40 »
Uh, no.
Offline jacobolus
« Reply #9 on: Sun, 14 February 2016, 15:19:28 »
Personally I think the side-to-side distance between keys is okay, but the front-to-back distance is wider than necessary.
Especially if you use a column-staggered layout where the columns align with finger extension, it’s quite workable having ~17mm distance between keys, or maybe even less. It helps to have a clear step between keys, and relatively small keytops with more space in between them.
