Author Topic: The problem with Not sleeping  (Read 3670 times)
« on: Sat, 06 February 2016, 06:12:04 »
is that you don't remember what you did, and whether or not it was actually done..
Offline fanpeople
Re: The problem with Not sleeping
« Reply #1 on: Sat, 06 February 2016, 06:13:48 »
Go to bed Jessica
« Reply #2 on: Sat, 06 February 2016, 06:31:08 »
Go to bed Jessica
Offline azhdar
  • Praise the AZERTY god
« Reply #3 on: Sat, 06 February 2016, 06:37:27 »
answer me pm pls mr cheng
Azerty Propagandiste
Offline fanpeople
« Reply #4 on: Sat, 06 February 2016, 06:43:53 »
Go to bed Jessica
Nope its a reference to somthing else. 5 internet dollars for the person which pixks it
« Reply #5 on: Sat, 06 February 2016, 06:44:41 »
U can use the same technique I sent you in the last pm
The only difference between bowl noodles vs the packet type, is that the bowl type is thinner, to allow it to steep to completion rather than via active heat cooking..
So... fundamentally ,  just reduce cooking time to compensate for the thinner noodle diameter..  but overall.. the process for ideal noodlz is the same..
Offline azhdar
« Reply #6 on: Sat, 06 February 2016, 06:46:04 »
pls read pm tp
Offline jaffers
« Reply #7 on: Sat, 06 February 2016, 07:08:31 »
Its reached the point where I instantly know a tp thread from the subject. You wouldnt even have to put the author's name next to it
Offline Jokrik
« Reply #8 on: Sat, 06 February 2016, 07:13:09 »
isn't that the same problem you get when you drink too much tp?
are you sure that you didn't sleep ?
Offline iLLucionist
  • Topre is Love.
« Reply #9 on: Sat, 06 February 2016, 07:17:16 »
Depends of how much not sleeping. With the right amount of sleep deprivation, I feel like I can focus better.
« Reply #10 on: Sat, 06 February 2016, 14:56:57 »
No way bro, you only feel that way, because not sleeping greatly dampens your judgement..
Offline iLLucionist
  • Topre is Love.
« Reply #11 on: Sat, 06 February 2016, 18:37:45 »
I guess both. There is a whole school of Zen Buddhism dedicated to the effects of sleep deprivation. But yeah I guess overall you are right.. it's like with alcohol: your judgment fails more often than not. But sometimes I get this creative vibe / flow that I really like. Mehh perhaps that's poor judgment as well.
« Reply #12 on: Sat, 06 February 2016, 20:06:17 »
Studies show sleep deprivation creates brief moments of --euphoria--,   That could be what you've experienced..
Offline iLLucionist
  • Topre is Love.
« Reply #13 on: Sun, 07 February 2016, 05:01:45 »
That's what I meant, thanks!
