Author Topic: Computer Sounds  (Read 3366 times)
Computer Sounds
« on: Wed, 24 February 2016, 06:57:28 »
Does your computer sometimes make new noises, that you've never heard before.. and you're just thinking in the back of your mind..  well, that's that,  it's got computer cancer..  gonna plan to buy a new pc..
Just before this post, my computer made a --meeeeiiiep-- noise..
Offline jaffers
Re: Computer Sounds
« Reply #1 on: Wed, 24 February 2016, 07:05:05 »
My hard drive makes strange sounds. But I know it has been dying for a while... I'm just... sentimental (broke)
Offline 27
  • The Maple Man
Re: Computer Sounds
« Reply #2 on: Wed, 24 February 2016, 08:22:33 »
Sometimes I think it's my PC, but it usually ends up to be my cat doing something near it.
IG: https://www.instagram.com/27mechs/                                        Website: http://www.mech27.com/
Offline Lokomotivet
  • (⌐■_■)
Re: Computer Sounds
« Reply #3 on: Wed, 24 February 2016, 08:55:48 »
(Older) AMD processors are like this:
| ISO |
Re: Computer Sounds
« Reply #4 on: Wed, 24 February 2016, 10:25:30 »
I have had the fan in the PSU starting to wear out and make loud noises. That is something that is not recommended that you would fix yourself.
Re: Computer Sounds
« Reply #5 on: Wed, 24 February 2016, 12:00:29 »
This is normal, just solder in a new fan...
Offline jd29
Re: Computer Sounds
« Reply #6 on: Wed, 24 February 2016, 13:01:46 »
My hard drive has been clicking for a while now. Still waiting on it to die.
This. If you're worried about capacitors, just let it sit unplugged for about a day and they'll discharge. If you're really worried, after a day use a screwdriver or something to short the leads.
Re: Computer Sounds
« Reply #7 on: Wed, 24 February 2016, 15:57:54 »
wear gloves, ..
