Author Topic: How to get rid of cat piss smells without replacing the entire carpet?  (Read 3361 times)
What I've tried and doesn't work:
Fabreeze
Candles
Spot cleaning
Hiring a steamer and pet deodorizing service
Replacing the padding underneath the carpet
Yell at it for a while
Offline tigersharkdude
Re: How to get rid of cat piss smells without replacing the entire carpet?
« Reply #1 on: Sat, 27 February 2016, 20:06:19 »
Replaced padding under the carpet, but not the carpet? Wtf?
Offline eat_the_food
  • MFW
« Reply #2 on: Sat, 27 February 2016, 20:08:35 »
Cat urine requires an enzyme cleaner to properly neutralize the ammonia, etc.. I've used Nature's Miracle with good results. YMMV as it will depend on the level of saturation however.
« Reply #3 on: Sat, 27 February 2016, 20:09:27 »
The apartment would charge for a full replacement so I replaced the padding around the edges of my room (where the smell is)
Mind you - this is not my scent. The place I moved into has a very strong odor in my room from the previous tenant but because it's a shared lease the manager refuse to do anything about it.
Offline Glenmael
« Reply #4 on: Sat, 27 February 2016, 20:10:39 »
Offline fanpeople
« Reply #5 on: Sat, 27 February 2016, 21:12:24 »
You need human asparagus piss to counter the cat piss.
Step one: eat about 5 kg of asparagus.
Step two: drink about 4 litres of water.
Step three: do not piss for about two days, do not drink any more water.
Step three.two: spend lots and lots of time in direct sunlight.
Step four: apply your piss to the problem area.
Step five: euphoria.
« Reply #6 on: Sat, 27 February 2016, 22:27:59 »
Only enzymes remove these odors.
- D Trump 2026-10-24
Offline Glenmael
« Reply #7 on: Sat, 27 February 2016, 23:30:02 »
haha! step five; repeat with pineapple jucie an j-zz to get rid of human piss?
Offline Pdub
« Reply #8 on: Sun, 28 February 2016, 09:19:25 »
In Mother Russia you destroy cat. Use its blood to clean carpet. Smell gone. Cool carpet.
« Reply #9 on: Sun, 28 February 2016, 10:09:58 »
Huh? You can't get the carpet washed?
« Reply #10 on: Sun, 28 February 2016, 10:54:45 »
I think they got the rug-doctor rental machine at the home-depot,  and they got a specific mix for animal odors i believe.. or maybe the regular one has the mix already.. not sure..
go check it out.
« Reply #11 on: Sun, 28 February 2016, 17:11:25 »
No Vac!
This sounds too good to be true, but I ordered 3 cans and have my fingers crossed.
Offline fknraiden
Offline Lanx
« Reply #13 on: Mon, 29 February 2016, 01:52:51 »
My friend says you need
natures miracle cat urine destroyer
You need the one specifically for cats, b/c the smell is so bad, you have to destroy it, that's why they named it like that.
Offline Glenmael
« Reply #14 on: Mon, 29 February 2016, 02:21:25 »
No Vac!
Seriously works :)
Offline ANightOnCloudNine
« Reply #15 on: Mon, 29 February 2016, 03:08:36 »
Windex and water mix, absorb quickly with a towel or something,
