Author Topic: Angle Snappn'  (Read 3019 times)
Angle Snappn'
« on: Fri, 08 April 2016, 13:49:51 »
Would you guys say..
Angle Snapping is better for OFFICE use ?
Because cad, spread sheet, etc, mostly straight lines....
/assuming your job isn't photoshop of course,
Re: Angle Snappn'
« Reply #1 on: Fri, 08 April 2016, 13:50:47 »
I don't like angle snapping for CAD work.
Offline dgneo
  • Supervillain
Re: Angle Snappn'
« Reply #2 on: Fri, 08 April 2016, 13:51:58 »
Can't stand angle snapping personally, no matter what the application.
Re: Angle Snappn'
« Reply #3 on: Fri, 08 April 2016, 13:52:50 »
Why not, ur doing straight lines and offsets no ?
Even if you use curves, they have to be function driven..
Re: Angle Snappn'
« Reply #4 on: Fri, 08 April 2016, 13:53:04 »
ok, but why?
Offline dgneo
  • Supervillain
Re: Angle Snappn'
« Reply #5 on: Fri, 08 April 2016, 13:54:22 »
ok, but why?
Just doesn't feel natural to me. Granted I do most of my work in Photoshop, but still, spread sheets, gaming, etc. not a fan at all. I much prefer to deal with imperfections.
Re: Angle Snappn'
« Reply #6 on: Fri, 08 April 2016, 14:00:06 »
It just doesn't feel right.
Re: Angle Snappn'
« Reply #7 on: Fri, 08 April 2016, 14:55:52 »
Like for example
Let's say you're dragging a horizontal line across the screen in solid works..   with angle snapping, there's almost no chance, that you'll have to make a y-correction..
However, without angle snapping,  the odds of the need for correction increases..
if fact both solidworks and autocad snaps lines to points precisely to prevent you from wasting time on corrections..   so it's like anglesnapping the anglesnapping..
But regardless.. you'd be more efficient drafting with angle snapping on ..
So, even if we say 1 out of 5 draw moves require the correction.. that adds up to alot if what you do is cad....
Re: Angle Snappn'
« Reply #8 on: Fri, 08 April 2016, 15:28:46 »
Like for example
But in AutoCAD I'm using object snaps and/or using ortho anyway and I turn those on and off on the fly so then if angle snapping is on it messes with the flow.
I can't describe it other than to say it doesn't feel natural.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Angle Snappn'
« Reply #9 on: Fri, 08 April 2016, 15:45:45 »
I've use hotkeys for angle snappin' for several months now. Technically not for office use though. The CGI program I have has built in 3D printing functionality, maybe that counts for something lol. I frequent Illustrator as well, does that count as office use? One day I'll learn how to AutoCAD
Offline munch
Re: Angle Snappn'
« Reply #10 on: Fri, 08 April 2016, 17:01:11 »
snapping is built into most/all CAD tools, and it works better than angle snapping.
Re: Angle Snappn'
« Reply #11 on: Fri, 08 April 2016, 17:10:10 »
that's not a proper comparison.
The shortcut snapping in the tool is to make things faster.
The angle snapping on the mouse, reduces the ODDS of the need for correction,  BECAUSE, even with the software snapping,  it could still overshoot..
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Angle Snappn'
« Reply #12 on: Fri, 08 April 2016, 17:18:49 »
Hmmm, maybe I'm butchering terminology again. I enter the target axis, then enter in the degree of rotation and voila, the face or whatever it is I'm working on snaps to the desired angle. The program itself looks like a mess because most of the alignments are done with hotkeys. Not having to remember all the measurements must be a godsend for models with more complexity.
Angle snapping via mouse seems unnecessary when most programs have some form of hotkey to aid the user
Offline jacobolus
Re: Angle Snappn'
« Reply #13 on: Fri, 08 April 2016, 17:31:48 »
Angle snapping at the hardware level is moronic. This is a software issue.
Offline munch
Re: Angle Snappn'
« Reply #14 on: Fri, 08 April 2016, 17:38:04 »
sure it is, you can press/hold shift or whichever button you set it to, and make it draw a completely straight line.
Re: Angle Snappn'
« Reply #15 on: Fri, 08 April 2016, 17:43:00 »
Angle-snapping mice are ridiculous. Anyone who makes a mouse that works that way should have his angle snapped off.
I find that when I use a mouse like that, I fight it. You should never have to fight the user interface.
