Author Topic: Chinese USB mini keyboard vacuums? Any good?  (Read 12467 times)
Offline ander
  • I type, therefore I am
« on: Wed, 13 April 2016, 02:45:29 »
Hey guys—have any of you tried these?:
New USB Mini Vacuum Dust Collector Cleaner Keyboard Brush for PC Computer Laptop
134280-0
Just wondered if they were any good, or if they were basically a toy... Thanks!
« Last Edit: Wed, 13 April 2016, 02:47:06 by ander »
Offline appleonama
  • Trollo en USA
Re: Chinese USB mini keyboard vacuums? Any good?
« Reply #1 on: Wed, 13 April 2016, 02:51:07 »
reported for spam
« Reply #2 on: Wed, 13 April 2016, 03:05:24 »
Hahahahahha..
This type of vac will have barely any suction..
They sell small brush attachment heads for FULL SIZE vacuums..
That is a much better choice..
But Overall.. People have had more success with "blowers"  although it does make a mess if there's large dust in ur keyboard.
« Reply #3 on: Wed, 13 April 2016, 03:17:32 »
get a Datavac
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
« Reply #4 on: Wed, 13 April 2016, 04:42:02 »
get a Datavac
Seconded, have one and it works WONDERS....has saved me hundreds in compressed air cans.
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
Offline Coreda
« Reply #5 on: Wed, 13 April 2016, 04:52:38 »
get a Datavac
To put things into perspective, even a powerful Datavac doesn't always blow everything out of a board. And from what I've read vacuums aren't as powerful as blowers, so I can't imagine the products in the OP would be terribly effective. Maybe for very light dust.
Offline ander
« Reply #6 on: Fri, 15 April 2016, 05:54:16 »
reported for spam
Huh? Are you serious? I genuinely just wanted to ask if anyone had used one of these. I couldn't believe something so cheap could be any good.
Well, I ordered one, since it was just a couple of bucks shipped... Should I review it here when I get it? Or will I be accused of spamming then too?  :?O
get a Datavac
Thanks for the suggestion. However, I seriously doubt I could spend $100 on a KB vacuum and stay married.
Offline need
« Reply #7 on: Fri, 15 April 2016, 16:00:02 »
I use this for drawing. It removes residues on the table left by the erasing rubber, and it works well for that kind of easy job.
There are two levels of intensity to choose from, also there's a tiny light underneath.
We got these at pound shops in the UK for a pound.
« Last Edit: Fri, 15 April 2016, 16:03:50 by need »
« Reply #8 on: Fri, 15 April 2016, 16:08:07 »
reported for spam
get a Datavac
100$?  It's 56$  http://www.amazon.com/Metro-Vacuum-ED500-500-Watt-Electric/dp/B001J4ZOAW/ref=sr_1_1?ie=UTF8&qid=1460754439&sr=8-1&keywords=datavac
And seriously that's like a few months of canned air...it will SAVE you money very very quickly :p
« Reply #9 on: Fri, 15 April 2016, 16:52:57 »
These mini vacs are more of a desk toy. They'll pick up light dust but that's about it.
Offline ander
« Reply #10 on: Fri, 15 April 2016, 19:13:23 »
There are two levels of intensity to choose from, also there's a tiny light underneath... We got these at pound shops in the UK for a pound.
Well, thanks for the input. It'll be interesting to see if this cheap little one's any good, KB-wise.
get a Datavac
100$?  It's 56$  http://www.amazon.com/Metro-Vacuum-ED500-500-Watt-Electric/dp/B001J4ZOAW/ref=sr_1_1?ie=UTF8&qid=1460754439&sr=8-1&keywords=datavac ...
That one's called a "MetrovAC"... I was looking at the "Datavac" you guys mentioned:
Data-Vac (reg. $149, on sale $85)
There's also the DataVac II "Pro", reg. $174, on sale $133
I guess the "spamming" thing has blown over? I haven't heard anything about it from moderators. Believe me, I hate anything spam-related.  :?P
« Reply #11 on: Fri, 15 April 2016, 19:26:15 »
get a Datavac
Product name  ED500 DataVac
Brand name is Metro Vacuum
So the product itself is the one commonly referred to as a Datavac :p
Both the ones you listed are also made BY metro Datavac is the product name itself and there are several models and variants.  So they are all datavacs all made by the same exact company just different models.
I use the cheaper one i linked above.
Offline ander
« Reply #12 on: Fri, 15 April 2016, 23:50:50 »
Great! You guys are so helpful, despite being obsessive 'n' everything.  :?D
Offline ander
« Reply #13 on: Sat, 16 April 2016, 04:07:25 »
I've been looking at these and similar products, and you're entirely right. Why bother with vacs of any kind? Blowers are the way to go. They're more powerful, and you don't have to keep cleaning them. I'll need to take keyboards and stuff outside and wear a mask, but who cares? I also understand that 20+ year-old board chow is great for gardens.  :?)
So, thanks for bringing me up to speed on this! – A.
Offline Asininity
« Reply #14 on: Sun, 17 April 2016, 15:48:52 »
It's also a lot of fun if you have cats.
« Reply #16 on: Sun, 17 April 2016, 16:17:40 »
Datavac is NOT worth that money..
Buy This for $7  and use your own vacuum, WAY WAY more powerful than a datavac
http://www.amazon.com/Micro-Vacuum-Attachment-Kit-Piece/dp/B000BSJCLY/ref=sr_1_1?ie=UTF8&qid=1460927594&sr=8-1&keywords=vacuum+cleaner+tiny+brush+attachment
but that's for sucking not blowing. Not all vacuums have a reverse airflow switch and inmy expierence sucking does not do a great job getting in the tiny spaces and crevices in electronic equipment.
« Reply #17 on: Sun, 17 April 2016, 16:29:20 »
+1
Offline ander
« Reply #18 on: Tue, 19 April 2016, 02:27:47 »
LOL. I don't think he'd forgive me. He hold grudges.
Offline Coreda
« Reply #19 on: Tue, 19 April 2016, 03:06:35 »
None of the vacuums I've had are as powerful as my Datavac. Prior to reading about the dangers of static discharges I used them for a while to clean the chassis but found them ineffective. Perhaps with the smaller attachments they'd be better but it's not really something I'm keen on risking.
Offline berserkfan
« Reply #20 on: Wed, 20 April 2016, 11:25:10 »
These mini vacuums are useless in my experience. Nearly anything powered by USB with moving parts isn't that great.
I use a vacuum cleaner with the suction turned down and the correct attachments.
Offline ander
« Reply #21 on: Thu, 05 May 2016, 03:58:37 »
In case anyone's interested, I ended up getting one of these:
EasyGo EGP-COM-011 Electric Compu Cleaner for Electronic Devices
It works just great! It was less expensive than the Datavac, includes several attachments, and weighs about a third as much (having a sturdy plastic enclosure rather than metal). I also prefer the rocker switch over the Davavac's stud switch, which doesn't seem quite as ergonomic.
Thanks again for your advice re blowing vs. sucking (LOL).
« Reply #22 on: Thu, 05 May 2016, 04:01:08 »
You can get a used air compressor at sears for the same price as the datavac.
Sometimes they have sales, and you can get a new one for $20 more.
Beats the crap out of the data vac..
Datavac is a n00b hype product.....
