Author Topic: I Silenced My Topre Type Heaven in the Most Ghetto Way Possible  (Read 8921 times)
Offline mind_funeral
  • savior of lost fortunes
I recently bought a Topre Type Heaven off craigslist for $50.  And before I get a bunch of grief; NO, I'm not lying and NO, it isn't stolen this time!  :)) :))  My plan was to use it for work but I was constantly worrying about the noise of the sliders slapping the frame on the upstroke.  I have no idea if it was actually bothering Frank in the cubicle next to me, but the thought of thew possibility was making me anxious.  I read about some ways to silence Topre keys and I decided on o2dazone's method of using ****ty Harbor Freight hollow punches to make custom o-rings/landing pads.  Only instead of buying silicone sheet, I walked around the shop at work with some calipers looking for something around 15 to 20 mils thick.  I ended up finding some roofing tar paper (~17 mils) that we use to mask the floors during messy projects.  (For anyone thinking of doing this in a non-****ty way but while still saving some cash, I found this to be the cheapest rubber.  It's 40a durometer gum rubber sheet, 20 mils.)
On to the build! Here is the imgur album formatted build if you prefer that.
Cutting the O-Rings:  The dimensions I used are: 1/2" OD, 3/8" ID.  I cut the OD first and found out that I could double layer the paper and cut about 20 at once and push the circles out of the punch.  The ID has to be cut one at a time because of how dull and ****ty these Harbor Freight punches are (I even tried to sharpen them).  I found that if I hammered the ID too hard, the ring would break -- too soft and it would only punch about 80% of the perimeter.  The technique I settled on was a double tap with a medium-light blow.  104 rings were not fun to make...
Close up of the roofing tar paper I used.  This is the stuff they put on the plywood of your roof before they put shingles down.
Wooden cutting surface.  I used a piece of 1"x4" pine to serve as a cutting surface.  I would have preferred having something less soft  to get a cleaner cut, but this entire project was planned in about 15 mins.
The final o-rings.  You can see the ring surface is kind of cone shaped.  This is why I would have liked different cutting surface.  Now that I think about it, a thick plastic cutting board would have been perfect...
Disassembling the Topre Type Heaven.  Pretty easy to disassemble.  Only three screws along the back edge of the case, then three or four tabs on the bottom edge. I used a medium-thick guitar pick and pushed the tabs open.  Don't use a knife or screwdriver or you will **** the case.  Then there are a handful of silver screws that set the PCB/plate distance and a **** ton of black screws that help hold the PCB to the plate.
O-Rings Installed.  I found that you don't really need to use a screw driver to remove the Topre sliders.  I just pushed the top of the stem with the very tip of my finger until it released. Popped all the sliders back in and reassembled the board.
Unfortunately, I didn't think to take a video of how it sounded before I silenced it.
Here is a video I found of the sound of a stock Topre Type Heaven (with a much better mic than mine :'( ):
And here is the sound after silencing (my crappy video, Galaxy S6):
  Sorry about the end of the video, my desk is right next to the shredder  :))
In conclusion this cost me $8.99 for the punches (which I will probably use in the future for projects) and took about 2.5 hours.  I'm really happy with the way it turned out despite being really cheap and ghetto.  I wanted to share this project with the community to promote thinking out of the box.  I'm sure some very porous/low density paper will work too (think thick construction paper).  I did not lube this board but I can see that being a possible problem for o-rings that have absorption properties (paper or foam).  I think if I were to silence any other Topre that was a bit more high-end, I would use another material like gum rubber, silicone, or Dycem but for this keyboard that only cost me 50 bucks, this definitely works!!
My Type Heaven's name is now Roofus!
« Last Edit: Wed, 12 January 2022, 09:39:14 by mind_funeral »
Poker II.3 with Gateron Browns and SIP sockets,  Midnight/Twilight DCS
KBP V60 with Gateron Clears, EnjoyPBT Cyrillics
Topre Type Heaven
Offline exitfire401
  • The Force is Re/\l
Re: I Silenced My Topre Type Heaven in the Most Ghetto Way Possible
« Reply #1 on: Wed, 04 May 2016, 10:22:29 »
You didn't ghetto silence it, you MacGyver silenced it! Good job. Sounds good too. I'm a huge backer of the O2dazone mod, and didn't think of looking for similar materials to try. May have to try this with my next hhkb
« Reply #2 on: Wed, 04 May 2016, 10:45:46 »
I'm really into this mod. Not everything needs to be $1 brazillion dollars. Simple is always nice.
Offline chuckdee
« Reply #3 on: Wed, 04 May 2016, 10:49:06 »
This, most definitely!  Great job on that!
One question... why didn't you just ask Frank?  :p  I just ask because I have the same concern, and I just asked my cube mates, and they said it wasn't bad, so I saved myself some work.  :))
« Reply #4 on: Wed, 04 May 2016, 11:00:46 »
In my experience people often lie to be kind and then just end up getting fed up and bitter or passive agressive.  This is true with a lot of situations especially roommates; dishes piling up, trash not getting taken out, smokers' habits, loud music etc.  You tell your mate you're cool with it and you genuinely want to be but it eventually causes a fight.  I've done it myself before.  Anyway, I silenced it for my own peace of mind and I'm glad I did because the silenced Topre sounds soooo nice!
Topre Type Heaven
« Reply #5 on: Wed, 04 May 2016, 11:03:06 »
huehuehuehue brbrbrbr
Topre Type Heaven
Offline Olumin
  • "Guy walks into a doctor's office..."
« Reply #6 on: Wed, 04 May 2016, 11:47:56 »
A bit unrelated, but what knife was that in the 5th picture?
« Reply #7 on: Wed, 04 May 2016, 13:31:51 »
Kershaw Chill.  Probably my favorite EDC due to the size, weight, and price.  3 inch blade, steel liners, and only 2oz.  8Cr13MoV steel is not bad at all.  One of the better Chinese steels.
Topre Type Heaven
Offline derb2k2
  • Something of a Topre ****..
« Reply #8 on: Wed, 04 May 2016, 15:16:28 »
ha! Definitely an interesting method here. Although there does appear to be some incongruity with the rings, looks and sounds effective.
Nice job!  :thumb:
HHKB | RF 45UB | Novatouch | Poker II Blue | QFR Browns | Rosewill RK-9000RE
« Reply #9 on: Wed, 04 May 2016, 15:49:53 »
Yeah, with the hollow punches I bought, it's really hard to find the center when punching the ID.  if you had a punch and die with a guide it would be so much easier.
Topre Type Heaven
Offline 0100010
  • Not Sure
« Reply #10 on: Wed, 04 May 2016, 17:56:20 »
Hate to ask - but does your board smell like tar now?
« Reply #12 on: Wed, 04 May 2016, 19:17:22 »
One question... why didn't you just ask Frank? I just ask because I have the same concern, and I just asked my cube mates, and they said it wasn't bad, so I saved myself some work.  :))
Exactly what I thought. They won't say so to your face until it absolutely drives them over the edge.
« Reply #13 on: Wed, 04 May 2016, 21:33:55 »
Nope! Smells normal.
And then it's too late.
Topre Type Heaven
Offline Bucake
« Reply #14 on: Wed, 04 May 2016, 21:54:43 »
sounds great, nice work! this was my plan in the first place but i couldn't find the right sizes for punchers around here
« Reply #15 on: Wed, 04 May 2016, 22:46:15 »
Will the roofing material deteriorate with use?
Being that it is cut out and will be on a moving part it seems like there is a chance it could eventually fall apart making a mess.
Maybe I'm thinking of different roofing material.
« Reply #16 on: Thu, 05 May 2016, 07:58:13 »
Try to look for hollow punches or leatherworking punches.  You may actually have a better time finding the right sized punches because the actual dimensions you want are: ID=8.2mm, OD=11mm.  I had to go with 3/8" and 1/2" because of 'murica. :/
It's 100% possible.  This is an experiment. Although it's some pretty tough stuff.  It's heat and water resistant.  As far as being part of a moving part, the ring itself should only be taking movement in the normal direction so I don't think it will be falling apart.  I will let you guys know if this ends up being a disaster haha.
Topre Type Heaven
Offline SBJ
  • Tactile pls
« Reply #17 on: Thu, 05 May 2016, 09:38:16 »
I have to agree with this!
I hope this thread inspires me to think out of the box for my future projects. I am still trying to learn all the customizations you can do to a mech, depending on what you want.
Now I just need to figure out what I want!
« Reply #18 on: Thu, 05 May 2016, 09:40:23 »
I really like mine as well. Definitely handy as hell to have around the workbench and day.
I kinda wish it did :))
Offline TopreFan333
« Reply #19 on: Thu, 05 May 2016, 11:31:00 »
Not an expert here, but I would imagine that anything that can survive a decade or more installed on a roof will do pretty well in a place where exposure to heat/cold/water/UV light is at an absolute minimum. And the mild stress of being lightly compacted between relatively soft pieces of plastic with 45g of force sounds pretty managable. But who knows, maybe after tens (hundreds?) of thousands of key presses, it could start to flake or something...
Offline Hyde
  • White Tofu Extraordinaire
« Reply #20 on: Sat, 07 May 2016, 22:43:54 »
Damn this sounds good, now I want to mod mine too.  :thumb:
Offline Belfong
« Reply #21 on: Sat, 07 May 2016, 22:58:45 »
crap, I didn't think to ask my co worker about the MX Blue and HHKB that I am rotating to use at work. I just assume people are ok with it. I mean, this is an office and it's open space and people are suppose to talk, make noise and what not. A few key stroke wouldn't bother anyone, would it? Anyway, sounds like I am subconsciously being selfish. Ugh, not good. I will go ask them tomorrow  :eek:
Cool mod. It's something I could see myself doing as well.
Offline Hyde
« Reply #22 on: Sun, 08 May 2016, 19:22:41 »
Typically I'm not worried about Topre because the loudness is about in line with typical rubber dome in any office anyway.
However MX Blue I'd ask to be sure.  :P
Offline cyd3r
« Reply #23 on: Tue, 19 July 2016, 06:56:50 »
I'm interested if the type feeling changed at all?
« Reply #24 on: Tue, 19 July 2016, 07:37:15 »
Not much.  Maybe just lifted the tactile point a bit.
Topre Type Heaven
« Reply #25 on: Fri, 01 March 2019, 13:47:14 »
Almost a 3 year necro just to let you folks know that Frank quit a long time ago and I type on a Dell AT101W or BTC-5100c at work these days.
I took the Topre Type Heaven home and was using it for a while before deciding to de-silence it.
I can say there was no smell, residue, breakage, jamming, deterioration, etc from the tar paper rings after almost 3 years of daily use (6-9 hours per day).
Topre Type Heaven
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #26 on: Sun, 03 March 2019, 07:02:28 »
I see you like the feels and no noise. I hope you’re enjoying typing on that thing.
Just my thoughts
